30th March 2019, 16:24 | #81 | Link |
I found it difficult too, even with 15 years coding experience and I hope I could make it at least a little bit more accessible.
My goal with mpv.net is adding a few features I need for myself and help people a little bit if I can. Other than that generally I like learning new languages, toolkits and frameworks etc., for mpv.net I've learned quite a bit about C# and WPF and found it quite nice after mastering difficulties I had before. Next on my table is C++, Rust, TypeScript, Python and F#. Last edited by stax76; 30th March 2019 at 18:17. |
31st March 2019, 23:02 | #82 | Link |
cosmic entity
one little thing i noticed while testing.
open player, drops youtube link on it, video plays fine, all good BUT it does not go Fullscreen anymore. neither with "F", nor mouse double klick or via menue. Only happens with youtube videos, normal movies/files are fine and fullscreen works via double klick. not shure why that is, if you need more info, lemme know and ill get back to you Greetz edit: is there a way to make the player "ask" me what format/resolution etc. i want when loading a youtube link? or do i have to set that up somewhere? Thanks Last edited by BetA13; 31st March 2019 at 23:06. |
1st April 2019, 04:28 | #83 | Link | |
For youtube it should be possible to put options to the mpv.conf file. https://mpv.io/manual/master/#options-ytdl-format I hope it's OK, apparently it uses the best quality for default. For the next release I've built an installer. |
1st April 2019, 12:10 | #84 | Link |
### 2.2
- messages boxes had always the info icon even if a different icon (error, warning, question) was intended - instead of silently do nothing on unknown commands there is now a error message listing available commands and showing the location of the default bindings, this helps when commands are removed or renamed - there was a problem fixed that made the cursor hidden when it should be visible - dragging a youtube URL on mpv.net would break certain input related features - there is now an installer with file extension registration (limited on Win 10) available - WM_APPCOMMAND media keys were not working in the input (shortcut) editor and there were no defaults for prev and next defined https://github.com/stax76/mpv.net/releases |
1st April 2019, 18:18 | #86 | Link |
Oh sorry, I had made a change and tested it 2-3 times and it was OK. Tried it now again and yes it's still broken. Potentially it's gonna be difficult to fix because probably it requires deep win32 knowledge, I'll give it a try, there is a tool called spy++ useful for this kind of issue.
What is very simple to do is to check the clipboard for a YouTube URL when the mpv.net window gets focus/activation and show a message box then confirming to play the URL. |
1st April 2019, 19:09 | #87 | Link |
There was a simple bug where code was executed that should only run for files and not for URL's, this caused an exception and unfortunately there was a second problem, the exception handling not working properly.
4th April 2019, 18:29 | #88 | Link |
### 2.3 (2019-04-04)
- dragging a youtube URL on mpv.net would still break something, it should work now - when the main window gets focus/activation it will check the clibboard for a YouTube video and ask to play it - libmpv updated - changing to normal size from fullscreen resulted in a too large window in some circumstances - some default key bindings and menu structure have changed and the input.conf file has a description added on top <https://github.com/stax76/mpv.net/blob/master/mpv.net/Resources/input.conf.txt> - the file association code was completely rewriten, it's now contained within mpvnet.exe instead of a separate application and it adds a few more keys - various new info added to the wiki: <https://github.com/stax76/mpv.net/wiki> - On Top feature was implemented using mpv's native property 'ontop', default bindings at: <https://github.com/stax76/mpv.net/blob/master/mpv.net/Resources/input.conf.txt> https://github.com/stax76/mpv.net/releases |
6th April 2019, 15:15 | #90 | Link |
2.4 (2019-04-06)
8th April 2019, 03:29 | #93 | Link |
2.5 (2019-04-08)
9th April 2019, 04:04 | #97 | Link |
I hope this release is more stable then the previous two.
2.6
10th April 2019, 16:08 | #98 | Link |
Please someone confirms that the last release 2.6 actually starts on Win 7, I'm too lazy to set up a test environment. The last release has a manifest added which is a potential source of incompatibility.
10th April 2019, 16:43 | #99 | Link |
cosmic entity
one second, im at it..
edit: First start took around 3 seconds. second start took under 1 second, all is fine at my end.. works just fine for me Windows 7 64bit Pro edit2: The Configurator is also fine now THANK YOU !!! Last edited by BetA13; 10th April 2019 at 16:49. |
10th April 2019, 20:06 | #100 | Link |
Thanks for testing! I get a white background, is your black background a windows setting or maybe changed by a 3rd party app?
The elements that previously had a too light color on Win 7 are now hard coded as Dark Slate Gray on systems prior Win 10, on Win 10 it uses the system theme/accent color. Hard coding it was easier than getting the system theme color, I had used a new method that didn't work on Win 7 but there is an old method that still could be implemented and probably works on Win 7, this old method is used in StaxRip. This is how things look on Win 10 using Dark mode and Orange accent: https://postimg.cc/JsVmB6QM The screenshot also shows how radio buttons look in the settings dialog of Win 10 using dark mode. mpv.net might support dark mode or color themes soon, I started experimenting with it today. |
