Old 5th May 2014, 06:44   #1  |  Link
Rouhi
how to extract bit rate and Frame rate in windows?
Hi
I have a folder containing 10,000 videos in format of mp4 and mpg. They have different bit rates. I want to provide a text file containing the list of each video name and it bit rate.
Do you have any suggestion?
My operating system is windows.
Cheers
Rouhi is offline   Reply With Quote
Old 5th May 2014, 10:00   #2  |  Link
QBhd
QB the Slayer
QBhd's Avatar
Mediainfo should be able to do what you want with a custom sheet.
QB
QBhd is offline   Reply With Quote
Old 5th May 2014, 12:52   #3  |  Link
therube
ffprobe from FFmepg.
You could set up a batch file to loop through each video getting its info.
Something like (pseudocode) ...
:loop
echo $filename >> out.TXT
ffprobe $filename 2>&1 | grep bitrate >> out.TXT
echo \n
:loop
therube is offline   Reply With Quote
Old 6th May 2014, 00:51   #4  |  Link
[ReX]
:loop
echo \n
:loop
I was bored, so I implemented this.
https://gist.github.com/BrunoReX/6eb38bd27f0ec83bb348
[ReX] is offline   Reply With Quote
Old 29th May 2014, 03:18   #5  |  Link
Rouhi
Thanks for your reply.
I am back again after long time. I want to rephrase the question. I want to extract the frame rate of a bunch of videos. I am in windows platform. Can i use ffmpeg or any other program to call in a loop and save the results in a text file?
Old 23rd June 2014, 15:17   #6  |  Link
[ReX]
Same approach, but now I've used the MediaInfo CLI since you don't need to parse the text with it.
https://gist.github.com/BrunoReX/fe8f659c31186328d317
bit rate
