#8121 | Link |
Pig on the wing
I was able to reproduce the bad frame in the deer scene with a 2-pass encode and a mix of your settings and --preset slower, but it did not happen with identical settings and CRF 1. I still don't know how you got pretty much identical results out of both passes as the avg bitrate for pass 1 was 37581 kbps and pass 2 ended up at 60238 kbps. I just tuned the settings slightly for some faster encoding, --limit-refs 3, --no-amp and --rskip 2 were the biggest changes.
By the way, if you want to get a stats file of the second and final pass, I think you can use --pass 3 instead of --pass 2. That will overwrite the stats file with the results from the current encode.
#8122 | Link | |
It is interesting how pass 1 has such a low bitrate, I get the same results. Then the estimate for pass 2 is about 10 Mbps (going from memory) higher than where it actually ends up. Does your CRF encode have the same keyframe pulsing as 2pass? The snow shot (Shot 5) with the fence is one, just stare at the top of the fence where the snow sits on it. The grass area on the bison shot. (Shot 16) Or the dirt/rocks, near the tree stump. (shot 47) What bitrate did CRF end up at? Would you mind posting the changes you made to setup CRF vs. 2pass? It is not something I have ever used with x264 or x265. Last edited by Stacey Spears; 25th April 2021 at 16:22. |
#8123 | Link |
This is a bit off topic, but these steps were used to create the montage, so I though it was worth sharing. Images 7 and 8 are the end results, prior to scaling down to UHD / HD resolutions of course. If this is not appropriate here, please let me know and I will remove it.
I thought some might be interested in this. I put together some TIFF images at each stage of processing that we do on our content so you can see how it evolved. The first six images are in the REDWideGamutRGB / Log3G10 space. The images are 7680x4320. One of the montage videos is Graded vs. Ungraded, which I hope some will find interesting as you rarely get to see how much work is done to make the images / videos look the way they do. If you are not used to looking at a log image, or wide gamut image, then you might find them odd looking. They will look flat and milky when looking at a log mage in gamma. Same when looking at an HDR image in gamma instead of PQ. https://www.dropbox.com/s/iemk0ukdil...xample.7z?dl=1 1. 00_Legacy.tif - This is the legacy demosaic algorithm. It was used 100% from 2007 - 2017, which is when IPP2 was released. Some still choose Legacy today. 2. 01_IPP2.tif - The order of operations changed to improve quality and it has a new demosaic algorithm that retains more detail than legacy. 3. 03_IPP2_TNR.tif - This is the IPP2 image with temporal noise reduction applied. 4. 04_IPP2_TNR_Decon_Mask_C00.tif - This mask is showing the pixels that deconvolution will touch, which is every pixel in this example. 5. 05_IPP2_TNR_Decon_Mask_C05.tif - This mask shows the settings I used. This way I avoid the noise in the sky getting sharper. 6. 06_IPP2_TNR_Decon.tif - This is IPP2 w/ temporal noise reduction and deconvolution. 7. 07_IPP2_TNR_Decon_Grade_HDR.tif - This is image number 6 graded for HDR (New disc) 8. 08_IPP2_TNR_Decon_Grade_SDR.tif - This is image number 6 graded for SDR (New disc) Not sure why I skipped over number 2. Last edited by Stacey Spears; 25th April 2021 at 16:50. |
#8124 | Link |
Stacy,
The deer scene error is caused from --no-cutree in your Encode_HDR_Montage_HD_2pass_90.bat file. Remove that and it cleans up a lot of the areas that have weird pixel issues. Some things I would suggest, lower subme to at least 4 or default of 2, raise both keyint, and min-keyint (lots of bits wasted on I frames that don't compress as much), --b-adapt 0 with to low of keyint's can cause a pulsating issue as well, since it is fixed length GOP, random size GOP are harder to see clean crisp I frames because you are not seeing them at the same intervals Hope that helps. |
#8125 | Link | ||||
Pig on the wing
1st pass: in:877 out:877 type:I q:12.00 q-aq:8.56 q-noVbv:12.00 q-Rceq:312.57 tex:1854107 mv:81619 misc:8710 icu:8160.00 pcu:0.00 scu:0.00 sc:1 ; in:881 out:878 type:P q:12.00 q-aq:8.39 q-noVbv:12.00 q-Rceq:268.43 tex:979467 mv:33511 misc:11910 icu:99.48 pcu:6890.41 scu:1170.10 sc:0 ; in:879 out:879 type:B q:13.00 q-aq:9.89 q-noVbv:13.14 q-Rceq:268.43 tex:453163 mv:23512 misc:10933 icu:5.54 pcu:4624.25 scu:3530.21 sc:0 ; The 3rd (actually second but with --pass 3 to update the stats file) pass: in:877 out:877 type:I q:14.86 q-aq:10.36 q-noVbv:-8.54 q-Rceq:222.02 tex:3080701 mv:198493 misc:7562 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:881 out:878 type:P q:0.00 q-aq:0.13 q-noVbv:-8.62 q-Rceq:222.02 tex:3427499 mv:52581 misc:3872 icu:1937.24 pcu:6173.14 scu:49.61 sc:0 ; in:879 out:879 type:B q:1.14 q-aq:0.30 q-noVbv:1.14 q-Rceq:222.02 tex:2602273 mv:36488 misc:5751 icu:116.61 pcu:7713.47 scu:329.93 sc:0 ; Quote:
Or if you want to run a CRF encode and get the stats file, use --pass 1 but don't give the bitrate. EDIT: just tested a multipass encode of 1000 frames without the VBV settings and no issues with the deer frame, it's clean. So it definitely is the VBV which causes the issue.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 25th April 2021 at 18:22. |
#8126 | Link | |
Should I try --b-adapt 1 or 2? I will: 1. Remove --no-cutree 2. Set --b-adapt 2 3. Set --subme 4 4. Add pass 3 And then kick off a new encode. Thank you. Last edited by Stacey Spears; 25th April 2021 at 19:08. |
#8127 | Link |
Pig on the wing
Those look good. You can replace --pass 2 directly by --pass 3, the only difference is that --pass 3 will update the stats file. So set a new name for it or copy the original if you want to compare.
#8128 | Link | |
Luckily each pass takes long enough that it is easy to copy the stats file before its overwritten. ![]() Last edited by Stacey Spears; 25th April 2021 at 19:54. |
#8129 | Link |
Pig on the wing
I'd try maybe --ipratio 1.2 --pbratio 1.1 since you seem to have a good headroom. Aq-mode 0 or 1 would be my choice.
#8130 | Link |
@Stacey Spears: Have you tried a different encoder yet ?
The keyframe pulsing at frame ~600 is caused because x265 is too afraid to pump bits into the I-Frames, so they are encoded with a really high quantizer in comparison to the surrounding frames. Likely related to VBV settings. The broken lower part at the deer at frame ~920 are caused because otherwise the frame would exceed the bits allocated for the frame. The encoder entered the "emergency mode". x265 can only spend so much bits on a frame when frame threading is enabled and video buffer limits have to be honored. |
#8132 | Link | |
Pig on the wing
#8133 | Link |
Interesting findings.
It reminds me somehow on the x264 discussion here: https://forum.doom9.org/showthread.p...89#post1848989 |
#8134 | Link | |
Pig on the wing
#8135 | Link | |
When I have the Sony, and possible Ateme, encodes I will share them so everyone can compare the results to x265. If the x265 devs take some time to investigate and address the issue(s), I will share the UHD source as well so that it can be used for future CODEC comparisons, if there is interest of course. Its ~260 GBs in 10-bit 4:2:0. Same for the full resolution (7680x3420). Last edited by Stacey Spears; 26th April 2021 at 14:44. |
#8136 | Link | |
It is here: https://drive.google.com/file/d/1-Uz...ew?usp=sharing I set the average rate to 80M and video buffer rate to 100M. GOP is closed and keyframe interval is fixed. The encoder has problems reaching the average rate because of the low resolution of the sequence. I did a lossless HEVC encode and it ended up being ~9.2GB, this encode is ~4.5GB. If someone wants to see a lower average rate encode - I am staying around here for a while, just request. I don't know if the encode is really HEVC BluRay compliant, please advise, this currently interests me the most. Maybe we should start a new thread if we diverge from x265 to general encoding of high rate HEVC using different encoders.... |
#8137 | Link | |
I have since made some changes, which you posted about using. (preset slower, limit refs to 3, etc...) In that case the stats file is a lot different between pass 1 and pass 3. I want to encode the first 1000 frames, as you did, and track down what is making pass 3 the same vs. different. While I wait for that 3 pass encode to finish, I wanted to share some stats file differences between the HD and UHD encodes, both targeting 90 Mbps. This is frame 590, the shot with the fence in the snow. I do need to break into three posts due to length. HD Stats Pass 1 Code:
in:590 out:590 type:I q:32.65 q-aq:24.73 q-noVbv:9.56 q-Rceq:0.98 tex:2362738 mv:322911 misc:8316 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:594 out:591 type:P q:24.13 q-aq:16.24 q-noVbv:24.45 q-Rceq:0.98 tex:2802507 mv:65130 misc:17084 icu:251.10 pcu:6673.32 scu:1235.59 sc:0 ; in:592 out:592 type:B q:24.00 q-aq:22.54 q-noVbv:24.45 q-Rceq:0.98 tex:2135 mv:2263 misc:2657 icu:4.03 pcu:93.19 scu:8062.79 sc:0 ; in:591 out:593 type:b q:24.00 q-aq:23.66 q-noVbv:24.45 q-Rceq:0.98 tex:1212 mv:1070 misc:1244 icu:0.00 pcu:170.00 scu:7990.00 sc:0 ; in:593 out:594 type:b q:24.00 q-aq:23.79 q-noVbv:24.45 q-Rceq:0.98 tex:1497 mv:613 misc:952 icu:0.00 pcu:284.84 scu:7875.16 sc:0 ; in:598 out:595 type:P q:22.00 q-aq:14.14 q-noVbv:22.45 q-Rceq:0.98 tex:724517 mv:20146 misc:29920 icu:31.23 pcu:3160.99 scu:4967.78 sc:0 ; in:596 out:596 type:B q:22.00 q-aq:20.38 q-noVbv:22.00 q-Rceq:0.98 tex:2700 mv:5692 misc:4673 icu:0.25 pcu:287.87 scu:7871.88 sc:0 ; in:595 out:597 type:b q:22.00 q-aq:21.67 q-noVbv:22.00 q-Rceq:0.98 tex:1306 mv:2392 misc:2169 icu:0.00 pcu:341.51 scu:7818.49 sc:0 ; in:597 out:598 type:b q:22.00 q-aq:21.71 q-noVbv:22.00 q-Rceq:0.98 tex:1656 mv:1427 misc:1580 icu:0.00 pcu:398.93 scu:7761.07 sc:0 ; in:602 out:599 type:P q:20.00 q-aq:12.14 q-noVbv:20.45 q-Rceq:0.98 tex:1260706 mv:26360 misc:28813 icu:14.10 pcu:4541.39 scu:3604.50 sc:0 ; in:600 out:600 type:B q:20.00 q-aq:18.31 q-noVbv:20.00 q-Rceq:0.98 tex:5446 mv:11262 misc:8326 icu:0.00 pcu:455.35 scu:7704.65 sc:0 ; in:599 out:601 type:b q:20.00 q-aq:19.67 q-noVbv:20.00 q-Rceq:0.98 tex:2422 mv:4193 misc:3666 icu:0.00 pcu:295.93 scu:7864.07 sc:0 ; in:601 out:602 type:b q:20.00 q-aq:19.58 q-noVbv:20.00 q-Rceq:0.98 tex:2857 mv:2804 misc:2831 icu:0.00 pcu:355.11 scu:7804.89 sc:0 ; in:606 out:603 type:P q:18.00 q-aq:9.99 q-noVbv:18.45 q-Rceq:0.98 tex:1771367 mv:42536 misc:31538 icu:14.36 pcu:5179.59 scu:2966.06 sc:0 ; in:604 out:604 type:B q:18.00 q-aq:16.09 q-noVbv:18.00 q-Rceq:0.98 tex:7529 mv:16065 misc:10904 icu:0.25 pcu:637.94 scu:7521.81 sc:0 ; in:603 out:605 type:b q:18.00 q-aq:17.47 q-noVbv:18.00 q-Rceq:0.98 tex:4214 mv:6237 misc:5051 icu:0.00 pcu:272.76 scu:7887.24 sc:0 ; in:605 out:606 type:b q:18.00 q-aq:17.52 q-noVbv:18.00 q-Rceq:0.98 tex:4142 mv:3512 misc:3854 icu:4.03 pcu:450.31 scu:7705.66 sc:0 ; in:610 out:607 type:P q:16.00 q-aq:8.07 q-noVbv:16.45 q-Rceq:0.98 tex:2048147 mv:40697 misc:28198 icu:8.56 pcu:5704.70 scu:2446.74 sc:0 ; in:608 out:608 type:B q:16.00 q-aq:14.10 q-noVbv:16.00 q-Rceq:0.98 tex:16180 mv:20156 misc:13966 icu:0.00 pcu:835.90 scu:7324.10 sc:0 ; in:607 out:609 type:b q:16.00 q-aq:15.54 q-noVbv:16.00 q-Rceq:0.98 tex:6289 mv:9631 misc:7120 icu:4.03 pcu:327.66 scu:7828.31 sc:0 ; in:609 out:610 type:b q:16.00 q-aq:15.34 q-noVbv:16.00 q-Rceq:0.98 tex:7507 mv:6508 misc:5773 icu:0.00 pcu:400.44 scu:7759.56 sc:0 ; in:613 out:611 type:P q:14.00 q-aq:10.87 q-noVbv:14.45 q-Rceq:0.98 tex:149569 mv:27015 misc:20631 icu:4.28 pcu:1307.61 scu:6848.10 sc:0 ; in:612 out:612 type:B q:14.00 q-aq:12.12 q-noVbv:14.00 q-Rceq:0.98 tex:45918 mv:20063 misc:13717 icu:0.00 pcu:1103.87 scu:7056.13 sc:0 ; in:611 out:613 type:b q:14.00 q-aq:13.77 q-noVbv:14.00 q-Rceq:0.98 tex:13451 mv:12476 misc:8502 icu:0.00 pcu:1041.91 scu:7118.09 sc:0 ; in:614 out:614 type:I q:32.74 q-aq:24.80 q-noVbv:15.17 q-Rceq:0.98 tex:2319615 mv:326495 misc:8189 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:618 out:615 type:P q:28.00 q-aq:20.28 q-noVbv:27.76 q-Rceq:0.98 tex:1172141 mv:38582 misc:18528 icu:112.83 pcu:4053.30 scu:3993.87 sc:0 ; in:616 out:616 type:B q:27.00 q-aq:25.85 q-noVbv:26.76 q-Rceq:0.98 tex:1288 mv:1832 misc:1712 icu:0.50 pcu:110.06 scu:8049.44 sc:0 ; in:615 out:617 type:b q:28.00 q-aq:28.00 q-noVbv:27.76 q-Rceq:0.98 tex:47 mv:290 misc:202 icu:0.00 pcu:216.09 scu:7943.91 sc:0 ; in:617 out:618 type:b q:28.00 q-aq:28.00 q-noVbv:27.76 q-Rceq:0.98 tex:79 mv:256 misc:149 icu:0.00 pcu:215.08 scu:7944.92 sc:0 ; in:622 out:619 type:P q:26.00 q-aq:18.25 q-noVbv:25.76 q-Rceq:0.98 tex:541182 mv:21561 misc:28746 icu:28.21 pcu:2836.86 scu:5294.93 sc:0 ; in:620 out:620 type:B q:26.00 q-aq:25.46 q-noVbv:26.00 q-Rceq:0.98 tex:799 mv:2535 misc:2298 icu:0.00 pcu:105.02 scu:8054.98 sc:0 ; in:619 out:621 type:b q:26.00 q-aq:26.05 q-noVbv:26.00 q-Rceq:0.98 tex:158 mv:951 misc:909 icu:0.00 pcu:251.85 scu:7908.15 sc:0 ; in:621 out:622 type:b q:26.00 q-aq:25.96 q-noVbv:26.00 q-Rceq:0.98 tex:315 mv:641 misc:590 icu:0.00 pcu:298.95 scu:7861.05 sc:0 ; in:626 out:623 type:P q:24.00 q-aq:16.08 q-noVbv:23.76 q-Rceq:0.98 tex:1059164 mv:29050 misc:31322 icu:39.79 pcu:4044.24 scu:4075.97 sc:0 ; in:624 out:624 type:B q:24.00 q-aq:23.09 q-noVbv:24.00 q-Rceq:0.98 tex:1299 mv:5739 misc:4323 icu:0.00 pcu:206.27 scu:7953.73 sc:0 ; in:623 out:625 type:b q:24.00 q-aq:23.68 q-noVbv:24.00 q-Rceq:0.98 tex:888 mv:2411 misc:2154 icu:0.00 pcu:227.93 scu:7932.07 sc:0 ; in:625 out:626 type:b q:24.00 q-aq:23.81 q-noVbv:24.00 q-Rceq:0.98 tex:602 mv:1005 misc:1017 icu:0.00 pcu:288.37 scu:7871.63 sc:0 ; in:630 out:627 type:P q:22.00 q-aq:14.11 q-noVbv:21.76 q-Rceq:0.98 tex:1390404 mv:35178 misc:31387 icu:30.73 pcu:4608.13 scu:3521.14 sc:0 ; in:628 out:628 type:B q:22.00 q-aq:20.82 q-noVbv:22.00 q-Rceq:0.98 tex:2155 mv:9697 misc:6795 icu:0.25 pcu:252.10 scu:7907.64 sc:0 ; in:627 out:629 type:b q:22.00 q-aq:21.43 q-noVbv:22.00 q-Rceq:0.98 tex:1404 mv:3607 misc:3162 icu:0.00 pcu:205.01 scu:7954.99 sc:0 ; in:629 out:630 type:b q:22.00 q-aq:21.94 q-noVbv:22.00 q-Rceq:0.98 tex:984 mv:1500 misc:1561 icu:0.00 pcu:332.95 scu:7827.05 sc:0 ; in:634 out:631 type:P q:20.00 q-aq:12.20 q-noVbv:19.76 q-Rceq:0.98 tex:1371847 mv:33025 misc:30889 icu:18.39 pcu:4678.15 scu:3463.47 sc:0 ; in:632 out:632 type:B q:20.00 q-aq:18.47 q-noVbv:20.00 q-Rceq:0.98 tex:4457 mv:11976 misc:8300 icu:0.00 pcu:451.57 scu:7708.43 sc:0 ; in:631 out:633 type:b q:20.00 q-aq:19.63 q-noVbv:20.00 q-Rceq:0.98 tex:2124 mv:4908 misc:4063 icu:0.00 pcu:375.26 scu:7784.74 sc:0 ; in:633 out:634 type:b q:20.00 q-aq:19.50 q-noVbv:20.00 q-Rceq:0.98 tex:2748 mv:2582 misc:2707 icu:0.00 pcu:399.94 scu:7760.06 sc:0 ; in:637 out:635 type:P q:18.00 q-aq:14.70 q-noVbv:17.76 q-Rceq:0.98 tex:54523 mv:11585 misc:13551 icu:0.25 pcu:524.86 scu:7634.89 sc:0 ; in:636 out:636 type:B q:18.00 q-aq:16.06 q-noVbv:18.00 q-Rceq:0.98 tex:11752 mv:7230 misc:6632 icu:0.00 pcu:807.69 scu:7352.31 sc:0 ; in:635 out:637 type:b q:18.00 q-aq:17.58 q-noVbv:18.00 q-Rceq:0.98 tex:3613 mv:4417 misc:3808 icu:0.00 pcu:890.55 scu:7269.45 sc:0 ; in:638 out:638 type:I q:32.65 q-aq:24.73 q-noVbv:19.61 q-Rceq:0.98 tex:2318699 mv:330385 misc:8411 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:642 out:639 type:P q:29.00 q-aq:21.42 q-noVbv:29.01 q-Rceq:0.98 tex:758451 mv:28317 misc:20004 icu:51.38 pcu:3276.59 scu:4832.03 sc:0 ; in:640 out:640 type:B q:29.00 q-aq:28.93 q-noVbv:29.01 q-Rceq:0.98 tex:199 mv:2403 misc:1725 icu:0.00 pcu:184.86 scu:7975.14 sc:0 ; in:639 out:641 type:b q:29.00 q-aq:28.91 q-noVbv:29.01 q-Rceq:0.98 tex:140 mv:394 misc:409 icu:0.00 pcu:60.95 scu:8099.05 sc:0 ; in:641 out:642 type:b q:28.00 q-aq:27.84 q-noVbv:28.00 q-Rceq:0.98 tex:201 mv:362 misc:262 icu:0.00 pcu:281.82 scu:7878.18 sc:0 ; in:646 out:643 type:P q:27.00 q-aq:19.17 q-noVbv:26.50 q-Rceq:0.98 tex:614185 mv:25269 misc:29464 icu:34.76 pcu:3058.24 scu:5067.01 sc:0 ; in:644 out:644 type:B q:27.00 q-aq:26.40 q-noVbv:27.00 q-Rceq:0.98 tex:593 mv:2142 misc:1956 icu:0.25 pcu:59.69 scu:8100.06 sc:0 ; in:643 out:645 type:b q:27.00 q-aq:26.96 q-noVbv:27.00 q-Rceq:0.98 tex:256 mv:875 misc:840 icu:0.00 pcu:158.41 scu:8001.59 sc:0 ; in:645 out:646 type:b q:27.00 q-aq:26.75 q-noVbv:27.00 q-Rceq:0.98 tex:415 mv:606 misc:593 icu:0.00 pcu:350.58 scu:7809.42 sc:0 ; in:650 out:647 type:P q:25.00 q-aq:17.16 q-noVbv:24.50 q-Rceq:0.98 tex:809770 mv:25665 misc:30624 icu:35.26 pcu:3429.72 scu:4695.02 sc:0 ; in:648 out:648 type:B q:25.00 q-aq:24.00 q-noVbv:25.00 q-Rceq:0.98 tex:1057 mv:3914 misc:3173 icu:0.00 pcu:113.33 scu:8046.67 sc:0 ; in:647 out:649 type:b q:25.00 q-aq:24.88 q-noVbv:25.00 q-Rceq:0.98 tex:450 mv:1238 misc:1206 icu:0.00 pcu:187.63 scu:7972.37 sc:0 ; in:649 out:650 type:b q:25.00 q-aq:24.99 q-noVbv:25.00 q-Rceq:0.98 tex:384 mv:741 misc:814 icu:0.00 pcu:250.34 scu:7909.66 sc:0 ; in:654 out:651 type:P q:23.00 q-aq:15.18 q-noVbv:22.50 q-Rceq:0.98 tex:1166046 mv:28097 misc:30656 icu:29.72 pcu:4218.01 scu:3912.27 sc:0 ; in:652 out:652 type:B q:23.00 q-aq:22.01 q-noVbv:23.00 q-Rceq:0.98 tex:1979 mv:6842 misc:5082 icu:0.00 pcu:215.84 scu:7944.16 sc:0 ; in:651 out:653 type:b q:23.00 q-aq:22.60 q-noVbv:23.00 q-Rceq:0.98 tex:1057 mv:2257 misc:2084 icu:0.00 pcu:281.57 scu:7878.43 sc:0 ; in:653 out:654 type:b q:23.00 q-aq:22.69 q-noVbv:23.00 q-Rceq:0.98 tex:940 mv:1441 misc:1369 icu:0.00 pcu:436.46 scu:7723.54 sc:0 ; in:658 out:655 type:P q:21.00 q-aq:13.19 q-noVbv:20.50 q-Rceq:0.98 tex:1112119 mv:28565 misc:31763 icu:17.63 pcu:4007.47 scu:4134.90 sc:0 ; in:656 out:656 type:B q:21.00 q-aq:19.60 q-noVbv:21.00 q-Rceq:0.98 tex:2863 mv:8182 misc:6199 icu:0.00 pcu:362.41 scu:7797.59 sc:0 ; in:655 out:657 type:b q:21.00 q-aq:20.56 q-noVbv:21.00 q-Rceq:0.98 tex:1383 mv:3331 misc:3065 icu:0.00 pcu:206.52 scu:7953.48 sc:0 ; in:657 out:658 type:b q:21.00 q-aq:20.69 q-noVbv:21.00 q-Rceq:0.98 tex:1504 mv:2113 misc:2176 icu:0.00 pcu:369.72 scu:7790.28 sc:0 ; in:661 out:659 type:P q:19.00 q-aq:15.81 q-noVbv:18.50 q-Rceq:0.98 tex:37120 mv:6955 misc:10331 icu:0.25 pcu:329.42 scu:7830.33 sc:0 ; in:660 out:660 type:B q:19.00 q-aq:17.41 q-noVbv:19.00 q-Rceq:0.98 tex:7122 mv:5023 misc:4883 icu:0.25 pcu:802.40 scu:7357.35 sc:0 ; in:659 out:661 type:b q:19.00 q-aq:18.50 q-noVbv:19.00 q-Rceq:0.98 tex:2784 mv:3355 misc:2847 icu:0.25 pcu:861.84 scu:7297.91 sc:0 ; in:662 out:662 type:I q:32.60 q-aq:24.68 q-noVbv:21.61 q-Rceq:0.98 tex:2307803 mv:332618 misc:8220 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:666 out:663 type:P q:30.00 q-aq:22.09 q-noVbv:29.53 q-Rceq:0.98 tex:391205 mv:16887 misc:19470 icu:32.24 pcu:2264.40 scu:5863.36 sc:0 ; in:664 out:664 type:B q:30.00 q-aq:29.92 q-noVbv:29.53 q-Rceq:0.98 tex:118 mv:1302 misc:875 icu:0.00 pcu:148.34 scu:8011.66 sc:0 ; in:663 out:665 type:b q:30.00 q-aq:30.00 q-noVbv:29.53 q-Rceq:0.98 tex:38 mv:313 misc:343 icu:0.00 pcu:133.48 scu:8026.52 sc:0 ; in:665 out:666 type:b q:29.00 q-aq:29.00 q-noVbv:29.00 q-Rceq:0.98 tex:58 mv:237 misc:215 icu:0.00 pcu:145.82 scu:8014.18 sc:0 ; in:670 out:667 type:P q:27.00 q-aq:19.15 q-noVbv:27.26 q-Rceq:0.98 tex:1013220 mv:32938 misc:30300 icu:47.85 pcu:4291.30 scu:3820.84 sc:0 ; in:668 out:668 type:B q:27.00 q-aq:26.42 q-noVbv:27.00 q-Rceq:0.98 tex:753 mv:4591 misc:3304 icu:0.00 pcu:137.51 scu:8022.49 sc:0 ; in:667 out:669 type:b q:27.00 q-aq:26.98 q-noVbv:27.00 q-Rceq:0.98 tex:180 mv:1008 misc:959 icu:0.00 pcu:124.67 scu:8035.33 sc:0 ; in:669 out:670 type:b q:27.00 q-aq:26.90 q-noVbv:27.00 q-Rceq:0.98 tex:229 mv:566 misc:524 icu:0.00 pcu:311.54 scu:7848.46 sc:0 ; in:674 out:671 type:P q:25.00 q-aq:17.21 q-noVbv:25.26 q-Rceq:0.98 tex:1083700 mv:38463 misc:31783 icu:39.29 pcu:4039.70 scu:4081.01 sc:0 ; in:672 out:672 type:B q:25.00 q-aq:23.75 q-noVbv:25.00 q-Rceq:0.98 tex:1421 mv:6754 misc:4925 icu:0.50 pcu:188.64 scu:7970.86 sc:0 ; in:671 out:673 type:b q:25.00 q-aq:24.58 q-noVbv:25.00 q-Rceq:0.98 tex:628 mv:2760 misc:2379 icu:0.25 pcu:155.39 scu:8004.36 sc:0 ; in:673 out:674 type:b q:25.00 q-aq:24.60 q-noVbv:25.00 q-Rceq:0.98 tex:516 mv:1083 misc:1035 icu:0.00 pcu:250.34 scu:7909.66 sc:0 ; in:678 out:675 type:P q:23.00 q-aq:15.17 q-noVbv:23.26 q-Rceq:0.98 tex:1465435 mv:43623 misc:30519 icu:38.79 pcu:5045.60 scu:3075.61 sc:0 ; in:676 out:676 type:B q:23.00 q-aq:22.07 q-noVbv:23.00 q-Rceq:0.98 tex:2102 mv:11615 misc:7575 icu:4.28 pcu:242.79 scu:7912.93 sc:0 ; in:675 out:677 type:b q:23.00 q-aq:22.83 q-noVbv:23.00 q-Rceq:0.98 tex:868 mv:4363 misc:3469 icu:0.00 pcu:125.93 scu:8034.07 sc:0 ; in:677 out:678 type:b q:23.00 q-aq:22.56 q-noVbv:23.00 q-Rceq:0.98 tex:1040 mv:1578 misc:1682 icu:0.00 pcu:400.70 scu:7759.30 sc:0 ; in:682 out:679 type:P q:21.00 q-aq:13.17 q-noVbv:21.26 q-Rceq:0.98 tex:1354912 mv:39755 misc:31668 icu:17.88 pcu:4662.28 scu:3479.84 sc:0 ; in:680 out:680 type:B q:21.00 q-aq:19.13 q-noVbv:21.00 q-Rceq:0.98 tex:3682 mv:11364 misc:8085 icu:0.00 pcu:352.34 scu:7807.66 sc:0 ; in:679 out:681 type:b q:21.00 q-aq:20.94 q-noVbv:21.00 q-Rceq:0.98 tex:1951 mv:4446 misc:3804 icu:0.00 pcu:218.36 scu:7941.64 sc:0 ; in:681 out:682 type:b q:21.00 q-aq:20.67 q-noVbv:21.00 q-Rceq:0.98 tex:2231 mv:2217 misc:2349 icu:0.00 pcu:346.80 scu:7813.20 sc:0 ; in:685 out:683 type:P q:19.00 q-aq:15.90 q-noVbv:19.26 q-Rceq:0.98 tex:64531 mv:11918 misc:15140 icu:1.01 pcu:551.56 scu:7607.44 sc:0 ; in:684 out:684 type:B q:19.00 q-aq:17.35 q-noVbv:19.00 q-Rceq:0.98 tex:8333 mv:6071 misc:5632 icu:0.00 pcu:836.40 scu:7323.60 sc:0 ; in:683 out:685 type:b q:19.00 q-aq:18.66 q-noVbv:19.00 q-Rceq:0.98 tex:2378 mv:3890 misc:3307 icu:0.00 pcu:918.76 scu:7241.24 sc:0 ; in:686 out:686 type:I q:32.73 q-aq:24.82 q-noVbv:22.28 q-Rceq:0.98 tex:2272721 mv:336478 misc:8154 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; |
#8138 | Link |
HD Stats Pass 3
in:590 out:590 type:I q:35.85 q-aq:27.95 q-noVbv:6.74 q-Rceq:0.98 tex:2434054 mv:227251 misc:9511 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:594 out:591 type:P q:7.00 q-aq:0.01 q-noVbv:6.80 q-Rceq:0.98 tex:11112740 mv:299729 misc:4935 icu:2949.44 pcu:5178.07 scu:32.49 sc:0 ; in:592 out:592 type:B q:6.00 q-aq:4.03 q-noVbv:5.80 q-Rceq:0.98 tex:1464416 mv:18144 misc:25872 icu:0.25 pcu:3824.37 scu:4335.38 sc:0 ; in:591 out:593 type:b q:6.00 q-aq:5.96 q-noVbv:5.80 q-Rceq:0.98 tex:677596 mv:37133 misc:25141 icu:0.00 pcu:2686.50 scu:5473.50 sc:0 ; in:593 out:594 type:b q:6.00 q-aq:5.98 q-noVbv:5.80 q-Rceq:0.98 tex:423269 mv:34377 misc:22158 icu:0.00 pcu:1960.67 scu:6199.33 sc:0 ; in:598 out:595 type:P q:7.00 q-aq:0.01 q-noVbv:6.79 q-Rceq:0.98 tex:4184604 mv:58795 misc:15859 icu:3.53 pcu:7266.68 scu:889.79 sc:0 ; in:596 out:596 type:B q:7.00 q-aq:5.13 q-noVbv:7.00 q-Rceq:0.98 tex:648103 mv:42639 misc:25616 icu:0.25 pcu:2409.72 scu:5750.03 sc:0 ; in:595 out:597 type:b q:7.00 q-aq:6.94 q-noVbv:7.00 q-Rceq:0.98 tex:267850 mv:57541 misc:23942 icu:0.00 pcu:1925.91 scu:6234.09 sc:0 ; in:597 out:598 type:b q:7.00 q-aq:6.91 q-noVbv:7.00 q-Rceq:0.98 tex:263074 mv:56154 misc:24962 icu:0.00 pcu:2021.87 scu:6138.13 sc:0 ; in:602 out:599 type:P q:7.00 q-aq:0.02 q-noVbv:6.79 q-Rceq:0.98 tex:3672075 mv:87155 misc:16717 icu:2.27 pcu:6921.64 scu:1236.09 sc:0 ; in:600 out:600 type:B q:7.00 q-aq:5.10 q-noVbv:7.00 q-Rceq:0.98 tex:635851 mv:60861 misc:27041 icu:0.00 pcu:2761.05 scu:5398.95 sc:0 ; in:599 out:601 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:261604 mv:64684 misc:25420 icu:0.00 pcu:2226.12 scu:5933.88 sc:0 ; in:601 out:602 type:b q:7.00 q-aq:6.96 q-noVbv:7.00 q-Rceq:0.98 tex:254308 mv:58216 misc:24680 icu:0.00 pcu:2023.63 scu:6136.37 sc:0 ; in:606 out:603 type:P q:7.00 q-aq:0.01 q-noVbv:6.79 q-Rceq:0.98 tex:3655254 mv:99916 misc:16120 icu:2.52 pcu:6946.33 scu:1211.16 sc:0 ; in:604 out:604 type:B q:7.00 q-aq:5.10 q-noVbv:7.00 q-Rceq:0.98 tex:625295 mv:63970 misc:28045 icu:0.25 pcu:2839.63 scu:5320.12 sc:0 ; in:603 out:605 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:266139 mv:67373 misc:25801 icu:0.00 pcu:2352.04 scu:5807.96 sc:0 ; in:605 out:606 type:b q:7.00 q-aq:6.97 q-noVbv:7.00 q-Rceq:0.98 tex:252535 mv:58687 misc:24555 icu:0.00 pcu:2038.74 scu:6121.26 sc:0 ; in:610 out:607 type:P q:7.00 q-aq:0.01 q-noVbv:6.79 q-Rceq:0.98 tex:3597650 mv:98632 misc:16446 icu:1.26 pcu:6876.56 scu:1282.18 sc:0 ; in:608 out:608 type:B q:7.00 q-aq:5.14 q-noVbv:7.00 q-Rceq:0.98 tex:612758 mv:59891 misc:27674 icu:0.25 pcu:2759.54 scu:5400.21 sc:0 ; in:607 out:609 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:258194 mv:65971 misc:25936 icu:0.00 pcu:2335.67 scu:5824.33 sc:0 ; in:609 out:610 type:b q:7.00 q-aq:6.93 q-noVbv:7.00 q-Rceq:0.98 tex:262086 mv:56838 misc:24438 icu:0.00 pcu:1966.71 scu:6193.29 sc:0 ; in:613 out:611 type:P q:7.00 q-aq:4.03 q-noVbv:6.78 q-Rceq:0.98 tex:1440796 mv:89741 misc:26375 icu:0.25 pcu:4472.13 scu:3687.61 sc:0 ; in:612 out:612 type:B q:7.00 q-aq:5.09 q-noVbv:7.00 q-Rceq:0.98 tex:629560 mv:69409 misc:27596 icu:0.00 pcu:2987.47 scu:5172.53 sc:0 ; in:611 out:613 type:b q:7.00 q-aq:6.96 q-noVbv:7.00 q-Rceq:0.98 tex:242681 mv:60975 misc:24814 icu:0.00 pcu:2256.34 scu:5903.66 sc:0 ; in:614 out:614 type:I q:33.29 q-aq:25.42 q-noVbv:6.66 q-Rceq:0.98 tex:2337982 mv:302928 misc:8834 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:618 out:615 type:P q:7.00 q-aq:0.01 q-noVbv:6.72 q-Rceq:0.98 tex:10973153 mv:183249 misc:6015 icu:1365.79 pcu:6774.31 scu:19.90 sc:0 ; in:616 out:616 type:B q:6.00 q-aq:3.88 q-noVbv:5.72 q-Rceq:0.98 tex:1454460 mv:16242 misc:25956 icu:0.50 pcu:3835.70 scu:4323.79 sc:0 ; in:615 out:617 type:b q:6.00 q-aq:5.98 q-noVbv:5.72 q-Rceq:0.98 tex:708985 mv:35368 misc:25141 icu:0.00 pcu:2751.99 scu:5408.01 sc:0 ; in:617 out:618 type:b q:6.00 q-aq:5.98 q-noVbv:5.72 q-Rceq:0.98 tex:420046 mv:34759 misc:22474 icu:0.00 pcu:1905.01 scu:6254.99 sc:0 ; in:622 out:619 type:P q:7.00 q-aq:0.02 q-noVbv:6.72 q-Rceq:0.98 tex:4258091 mv:56643 misc:15464 icu:3.78 pcu:7342.99 scu:813.23 sc:0 ; in:620 out:620 type:B q:7.00 q-aq:5.06 q-noVbv:7.00 q-Rceq:0.98 tex:655097 mv:42611 misc:25300 icu:0.25 pcu:2409.72 scu:5750.03 sc:0 ; in:619 out:621 type:b q:7.00 q-aq:7.00 q-noVbv:7.00 q-Rceq:0.98 tex:259786 mv:56489 misc:23649 icu:0.00 pcu:1872.77 scu:6287.23 sc:0 ; in:621 out:622 type:b q:7.00 q-aq:6.95 q-noVbv:7.00 q-Rceq:0.98 tex:264567 mv:53038 misc:24476 icu:0.00 pcu:1861.44 scu:6298.56 sc:0 ; in:626 out:623 type:P q:7.00 q-aq:0.01 q-noVbv:6.72 q-Rceq:0.98 tex:4230694 mv:85242 misc:14242 icu:3.78 pcu:7271.97 scu:884.25 sc:0 ; in:624 out:624 type:B q:7.00 q-aq:5.12 q-noVbv:7.00 q-Rceq:0.98 tex:624785 mv:53503 misc:26579 icu:0.00 pcu:2593.57 scu:5566.43 sc:0 ; in:623 out:625 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:264471 mv:63642 misc:25794 icu:0.00 pcu:2161.64 scu:5998.36 sc:0 ; in:625 out:626 type:b q:7.00 q-aq:6.97 q-noVbv:7.00 q-Rceq:0.98 tex:266207 mv:56854 misc:24536 icu:0.00 pcu:1954.87 scu:6205.13 sc:0 ; in:630 out:627 type:P q:7.00 q-aq:0.02 q-noVbv:6.71 q-Rceq:0.98 tex:4266794 mv:85812 misc:13966 icu:1.51 pcu:7304.21 scu:854.28 sc:0 ; in:628 out:628 type:B q:7.00 q-aq:5.07 q-noVbv:7.00 q-Rceq:0.98 tex:647859 mv:51065 misc:26650 icu:0.00 pcu:2549.24 scu:5610.76 sc:0 ; in:627 out:629 type:b q:7.00 q-aq:6.99 q-noVbv:7.00 q-Rceq:0.98 tex:266340 mv:61590 misc:24803 icu:0.00 pcu:1992.40 scu:6167.60 sc:0 ; in:629 out:630 type:b q:7.00 q-aq:6.99 q-noVbv:7.00 q-Rceq:0.98 tex:264022 mv:55224 misc:24703 icu:0.00 pcu:1944.55 scu:6215.45 sc:0 ; in:634 out:631 type:P q:7.00 q-aq:0.01 q-noVbv:6.71 q-Rceq:0.98 tex:4091313 mv:86549 misc:14374 icu:1.76 pcu:7304.71 scu:853.53 sc:0 ; in:632 out:632 type:B q:7.00 q-aq:5.09 q-noVbv:7.00 q-Rceq:0.98 tex:641508 mv:51583 misc:27686 icu:0.00 pcu:2698.59 scu:5461.41 sc:0 ; in:631 out:633 type:b q:7.00 q-aq:6.99 q-noVbv:7.00 q-Rceq:0.98 tex:264289 mv:60926 misc:24755 icu:0.00 pcu:2079.54 scu:6080.46 sc:0 ; in:633 out:634 type:b q:7.00 q-aq:6.94 q-noVbv:7.00 q-Rceq:0.98 tex:270107 mv:55517 misc:24628 icu:0.00 pcu:1952.36 scu:6207.64 sc:0 ; in:637 out:635 type:P q:7.00 q-aq:4.02 q-noVbv:6.71 q-Rceq:0.98 tex:1568588 mv:83218 misc:26104 icu:0.00 pcu:4621.23 scu:3538.77 sc:0 ; in:636 out:636 type:B q:7.00 q-aq:5.11 q-noVbv:7.00 q-Rceq:0.98 tex:624232 mv:66453 misc:27631 icu:0.00 pcu:2853.48 scu:5306.52 sc:0 ; in:635 out:637 type:b q:7.00 q-aq:6.95 q-noVbv:7.00 q-Rceq:0.98 tex:246549 mv:59410 misc:24570 icu:0.00 pcu:2140.49 scu:6019.51 sc:0 ; in:638 out:638 type:I q:35.06 q-aq:27.19 q-noVbv:6.58 q-Rceq:0.98 tex:2511473 mv:246752 misc:9377 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:642 out:639 type:P q:7.00 q-aq:0.01 q-noVbv:6.65 q-Rceq:0.98 tex:11128541 mv:277687 misc:4540 icu:2624.30 pcu:5503.47 scu:32.24 sc:0 ; in:640 out:640 type:B q:6.00 q-aq:3.95 q-noVbv:5.65 q-Rceq:0.98 tex:1509456 mv:17386 misc:26144 icu:1.26 pcu:3955.08 scu:4203.66 sc:0 ; in:639 out:641 type:b q:6.00 q-aq:5.94 q-noVbv:5.65 q-Rceq:0.98 tex:765024 mv:35466 misc:26224 icu:0.00 pcu:2927.02 scu:5232.98 sc:0 ; in:641 out:642 type:b q:6.00 q-aq:5.81 q-noVbv:5.65 q-Rceq:0.98 tex:418326 mv:37153 misc:22470 icu:0.00 pcu:1906.01 scu:6253.99 sc:0 ; in:646 out:643 type:P q:7.00 q-aq:0.02 q-noVbv:6.65 q-Rceq:0.98 tex:4279066 mv:57053 misc:15481 icu:4.28 pcu:7304.21 scu:851.51 sc:0 ; in:644 out:644 type:B q:7.00 q-aq:5.02 q-noVbv:7.00 q-Rceq:0.98 tex:674350 mv:41790 misc:25534 icu:0.00 pcu:2507.44 scu:5652.56 sc:0 ; in:643 out:645 type:b q:7.00 q-aq:6.90 q-noVbv:7.00 q-Rceq:0.98 tex:271810 mv:55567 misc:23759 icu:0.00 pcu:1879.07 scu:6280.93 sc:0 ; in:645 out:646 type:b q:7.00 q-aq:6.99 q-noVbv:7.00 q-Rceq:0.98 tex:266929 mv:56058 misc:24502 icu:0.00 pcu:2010.53 scu:6149.47 sc:0 ; in:650 out:647 type:P q:7.00 q-aq:0.02 q-noVbv:6.65 q-Rceq:0.98 tex:3662313 mv:82857 misc:17295 icu:2.01 pcu:6911.82 scu:1246.16 sc:0 ; in:648 out:648 type:B q:7.00 q-aq:5.11 q-noVbv:7.00 q-Rceq:0.98 tex:622850 mv:61315 misc:27513 icu:0.25 pcu:2756.52 scu:5403.23 sc:0 ; in:647 out:649 type:b q:7.00 q-aq:6.95 q-noVbv:7.00 q-Rceq:0.98 tex:256161 mv:63066 misc:25146 icu:0.00 pcu:2096.41 scu:6063.59 sc:0 ; in:649 out:650 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:257582 mv:56258 misc:23998 icu:0.00 pcu:1922.39 scu:6237.61 sc:0 ; in:654 out:651 type:P q:7.00 q-aq:0.02 q-noVbv:6.64 q-Rceq:0.98 tex:3472724 mv:98754 misc:17313 icu:3.02 pcu:6805.04 scu:1351.94 sc:0 ; in:652 out:652 type:B q:7.00 q-aq:5.03 q-noVbv:7.00 q-Rceq:0.98 tex:622978 mv:65414 misc:27858 icu:0.00 pcu:2861.29 scu:5298.71 sc:0 ; in:651 out:653 type:b q:7.00 q-aq:6.92 q-noVbv:7.00 q-Rceq:0.98 tex:251307 mv:66363 misc:25536 icu:0.00 pcu:2243.75 scu:5916.25 sc:0 ; in:653 out:654 type:b q:7.00 q-aq:6.94 q-noVbv:7.00 q-Rceq:0.98 tex:252957 mv:58093 misc:24344 icu:0.00 pcu:1931.45 scu:6228.55 sc:0 ; in:658 out:655 type:P q:7.00 q-aq:0.01 q-noVbv:6.64 q-Rceq:0.98 tex:3360027 mv:103990 misc:17556 icu:0.76 pcu:6733.76 scu:1425.48 sc:0 ; in:656 out:656 type:B q:7.00 q-aq:5.06 q-noVbv:7.00 q-Rceq:0.98 tex:613138 mv:67150 misc:28021 icu:0.00 pcu:2912.41 scu:5247.59 sc:0 ; in:655 out:657 type:b q:7.00 q-aq:6.97 q-noVbv:7.00 q-Rceq:0.98 tex:249854 mv:66469 misc:25763 icu:0.00 pcu:2316.53 scu:5843.47 sc:0 ; in:657 out:658 type:b q:7.00 q-aq:6.98 q-noVbv:7.00 q-Rceq:0.98 tex:243932 mv:58848 misc:24637 icu:0.00 pcu:2106.99 scu:6053.01 sc:0 ; in:661 out:659 type:P q:7.00 q-aq:4.06 q-noVbv:6.64 q-Rceq:0.98 tex:1322302 mv:96329 misc:26845 icu:0.00 pcu:4411.69 scu:3748.31 sc:0 ; in:660 out:660 type:B q:7.00 q-aq:5.00 q-noVbv:7.00 q-Rceq:0.98 tex:619953 mv:72925 misc:27948 icu:0.00 pcu:3057.99 scu:5102.01 sc:0 ; in:659 out:661 type:b q:7.00 q-aq:6.97 q-noVbv:7.00 q-Rceq:0.98 tex:243788 mv:62459 misc:24797 icu:0.00 pcu:2346.76 scu:5813.24 sc:0 ; in:662 out:662 type:I q:34.83 q-aq:26.95 q-noVbv:6.51 q-Rceq:0.98 tex:2538831 mv:246661 misc:9399 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; in:666 out:663 type:P q:7.00 q-aq:0.01 q-noVbv:6.58 q-Rceq:0.98 tex:11076213 mv:268956 misc:4843 icu:2488.80 pcu:5639.97 scu:31.23 sc:0 ; in:664 out:664 type:B q:6.00 q-aq:3.97 q-noVbv:5.58 q-Rceq:0.98 tex:1486925 mv:18242 misc:26471 icu:0.50 pcu:3878.01 scu:4281.48 sc:0 ; in:663 out:665 type:b q:6.00 q-aq:5.99 q-noVbv:5.58 q-Rceq:0.98 tex:678492 mv:36952 misc:25070 icu:0.00 pcu:2709.67 scu:5450.33 sc:0 ; in:665 out:666 type:b q:6.00 q-aq:5.81 q-noVbv:5.58 q-Rceq:0.98 tex:433970 mv:35594 misc:22401 icu:0.00 pcu:2029.17 scu:6130.83 sc:0 ; in:670 out:667 type:P q:7.00 q-aq:0.01 q-noVbv:6.58 q-Rceq:0.98 tex:4694160 mv:56490 misc:14094 icu:1.76 pcu:7423.84 scu:734.40 sc:0 ; in:668 out:668 type:B q:7.00 q-aq:5.04 q-noVbv:7.00 q-Rceq:0.98 tex:663964 mv:34842 misc:24178 icu:0.00 pcu:2353.56 scu:5806.44 sc:0 ; in:667 out:669 type:b q:7.00 q-aq:6.88 q-noVbv:7.00 q-Rceq:0.98 tex:277659 mv:59940 misc:24996 icu:0.00 pcu:2020.36 scu:6139.64 sc:0 ; in:669 out:670 type:b q:7.00 q-aq:6.93 q-noVbv:7.00 q-Rceq:0.98 tex:296364 mv:55286 misc:24639 icu:0.00 pcu:1960.16 scu:6199.84 sc:0 ; in:674 out:671 type:P q:7.00 q-aq:0.01 q-noVbv:6.58 q-Rceq:0.98 tex:4979860 mv:76713 misc:12252 icu:1.51 pcu:7559.84 scu:598.65 sc:0 ; in:672 out:672 type:B q:7.00 q-aq:5.16 q-noVbv:7.00 q-Rceq:0.98 tex:676086 mv:41193 misc:25366 icu:0.00 pcu:2358.09 scu:5801.91 sc:0 ; in:671 out:673 type:b q:7.00 q-aq:6.79 q-noVbv:7.00 q-Rceq:0.98 tex:283987 mv:60124 misc:25784 icu:0.00 pcu:2041.76 scu:6118.24 sc:0 ; in:673 out:674 type:b q:7.00 q-aq:6.99 q-noVbv:7.00 q-Rceq:0.98 tex:308569 mv:53876 misc:25427 icu:0.00 pcu:1961.17 scu:6198.83 sc:0 ; in:678 out:675 type:P q:7.00 q-aq:0.01 q-noVbv:6.57 q-Rceq:0.98 tex:5046505 mv:72877 misc:12368 icu:0.50 pcu:7624.56 scu:534.93 sc:0 ; in:676 out:676 type:B q:7.00 q-aq:5.01 q-noVbv:7.00 q-Rceq:0.98 tex:720323 mv:34567 misc:26228 icu:0.00 pcu:2760.55 scu:5399.45 sc:0 ; in:675 out:677 type:b q:7.00 q-aq:6.86 q-noVbv:7.00 q-Rceq:0.98 tex:298688 mv:58927 misc:25199 icu:0.00 pcu:1991.90 scu:6168.10 sc:0 ; in:677 out:678 type:b q:7.00 q-aq:6.97 q-noVbv:7.00 q-Rceq:0.98 tex:310062 mv:53343 misc:26226 icu:0.00 pcu:2082.56 scu:6077.44 sc:0 ; in:682 out:679 type:P q:7.00 q-aq:0.01 q-noVbv:6.57 q-Rceq:0.98 tex:4448168 mv:75434 misc:13841 icu:2.27 pcu:7473.20 scu:684.53 sc:0 ; in:680 out:680 type:B q:7.00 q-aq:4.99 q-noVbv:7.00 q-Rceq:0.98 tex:670567 mv:40258 misc:26180 icu:0.00 pcu:2569.39 scu:5590.61 sc:0 ; in:679 out:681 type:b q:7.00 q-aq:6.95 q-noVbv:7.00 q-Rceq:0.98 tex:281306 mv:57083 misc:23788 icu:0.00 pcu:1883.60 scu:6276.40 sc:0 ; in:681 out:682 type:b q:7.00 q-aq:6.93 q-noVbv:7.00 q-Rceq:0.98 tex:281914 mv:56638 misc:25673 icu:0.00 pcu:2072.24 scu:6087.76 sc:0 ; in:685 out:683 type:P q:7.00 q-aq:4.00 q-noVbv:6.56 q-Rceq:0.98 tex:1760105 mv:83266 misc:26082 icu:0.00 pcu:5016.39 scu:3143.61 sc:0 ; in:684 out:684 type:B q:7.00 q-aq:5.04 q-noVbv:7.00 q-Rceq:0.98 tex:645621 mv:58941 misc:27825 icu:0.00 pcu:2866.58 scu:5293.42 sc:0 ; in:683 out:685 type:b q:7.00 q-aq:6.96 q-noVbv:7.00 q-Rceq:0.98 tex:256500 mv:56784 misc:24274 icu:0.00 pcu:2091.63 scu:6068.37 sc:0 ; in:686 out:686 type:I q:34.96 q-aq:27.18 q-noVbv:6.44 q-Rceq:0.98 tex:2511364 mv:247085 misc:9487 icu:8160.00 pcu:0.00 scu:0.00 sc:0 ; |
#8139 | Link |
UHD Stats Pass 1
in:590 out:590 type:I q:20.74 q-aq:19.07 q-noVbv:7.65 q-Rceq:721.59 tex:9417908 mv:980056 misc:41732 icu:32400.00 pcu:0.00 scu:0.00 sc:0 ; in:594 out:591 type:P q:16.05 q-aq:13.66 q-noVbv:16.05 q-Rceq:571.97 tex:7245125 mv:98876 misc:59443 icu:145.00 pcu:26658.50 scu:5596.50 sc:0 ; in:592 out:592 type:B q:17.19 q-aq:15.26 q-noVbv:17.19 q-Rceq:571.97 tex:218923 mv:65960 misc:45517 icu:17.75 pcu:3284.00 scu:29098.25 sc:0 ; in:591 out:593 type:b q:18.32 q-aq:16.73 q-noVbv:18.32 q-Rceq:571.97 tex:52628 mv:41290 misc:30810 icu:9.25 pcu:2257.75 scu:30133.00 sc:0 ; in:593 out:594 type:b q:18.32 q-aq:16.43 q-noVbv:18.32 q-Rceq:571.97 tex:49388 mv:14207 misc:18359 icu:8.50 pcu:3079.25 scu:29312.25 sc:0 ; in:598 out:595 type:P q:15.05 q-aq:13.03 q-noVbv:15.05 q-Rceq:469.28 tex:2348076 mv:78526 misc:84169 icu:22.25 pcu:13824.00 scu:18553.75 sc:0 ; in:596 out:596 type:B q:16.69 q-aq:14.90 q-noVbv:16.69 q-Rceq:469.28 tex:134754 mv:50241 misc:46115 icu:8.00 pcu:5064.25 scu:27327.75 sc:0 ; in:595 out:597 type:b q:18.07 q-aq:16.93 q-noVbv:18.07 q-Rceq:469.28 tex:27584 mv:28668 misc:20765 icu:3.50 pcu:2482.25 scu:29914.25 sc:0 ; in:597 out:598 type:b q:17.57 q-aq:16.44 q-noVbv:17.57 q-Rceq:469.28 tex:48859 mv:23761 misc:22307 icu:2.00 pcu:3999.25 scu:28398.75 sc:0 ; in:602 out:599 type:P q:14.05 q-aq:12.03 q-noVbv:14.05 q-Rceq:402.28 tex:2928217 mv:100708 misc:92580 icu:15.75 pcu:16145.75 scu:16238.50 sc:0 ; in:600 out:600 type:B q:15.69 q-aq:13.89 q-noVbv:15.69 q-Rceq:402.28 tex:319405 mv:78139 misc:67356 icu:2.50 pcu:7348.50 scu:25049.00 sc:0 ; in:599 out:601 type:b q:17.07 q-aq:15.81 q-noVbv:17.07 q-Rceq:402.28 tex:47050 mv:46821 misc:30085 icu:0.25 pcu:3696.25 scu:28703.50 sc:0 ; in:601 out:602 type:b q:16.57 q-aq:15.07 q-noVbv:16.57 q-Rceq:402.28 tex:72563 mv:39870 misc:32645 icu:0.75 pcu:4540.25 scu:27859.00 sc:0 ; in:606 out:603 type:P q:13.05 q-aq:10.98 q-noVbv:13.05 q-Rceq:361.88 tex:4218902 mv:144499 misc:99008 icu:12.50 pcu:19832.25 scu:12555.25 sc:0 ; in:604 out:604 type:B q:14.69 q-aq:13.00 q-noVbv:14.69 q-Rceq:361.88 tex:380283 mv:110437 misc:79189 icu:7.00 pcu:7821.00 scu:24572.00 sc:0 ; in:603 out:605 type:b q:16.07 q-aq:14.57 q-noVbv:16.07 q-Rceq:361.88 tex:69764 mv:67593 misc:40990 icu:0.50 pcu:3846.25 scu:28553.25 sc:0 ; in:605 out:606 type:b q:15.57 q-aq:13.89 q-noVbv:15.57 q-Rceq:361.88 tex:154199 mv:53354 misc:50439 icu:1.00 pcu:8745.00 scu:23654.00 sc:0 ; in:610 out:607 type:P q:12.05 q-aq:9.98 q-noVbv:12.05 q-Rceq:338.10 tex:5194839 mv:165803 misc:98955 icu:14.75 pcu:22139.75 scu:10245.50 sc:0 ; in:608 out:608 type:B q:13.69 q-aq:11.96 q-noVbv:13.69 q-Rceq:338.10 tex:577864 mv:134501 misc:87394 icu:1.00 pcu:8756.75 scu:23642.25 sc:0 ; in:607 out:609 type:b q:15.07 q-aq:13.37 q-noVbv:15.07 q-Rceq:338.10 tex:129067 mv:96798 misc:53364 icu:1.25 pcu:4710.75 scu:27688.00 sc:0 ; in:609 out:610 type:b q:14.57 q-aq:12.87 q-noVbv:14.57 q-Rceq:338.10 tex:230880 mv:83463 misc:58083 icu:0.75 pcu:6478.75 scu:25920.50 sc:0 ; in:613 out:611 type:P q:11.05 q-aq:8.99 q-noVbv:11.05 q-Rceq:322.71 tex:5693012 mv:188790 misc:101052 icu:18.25 pcu:23061.75 scu:9320.00 sc:0 ; in:612 out:612 type:B q:12.52 q-aq:10.77 q-noVbv:12.52 q-Rceq:322.71 tex:905538 mv:173938 misc:99593 icu:5.25 pcu:10436.25 scu:21958.50 sc:0 ; in:611 out:613 type:b q:13.99 q-aq:12.45 q-noVbv:13.99 q-Rceq:322.71 tex:234576 mv:135219 misc:70400 icu:1.75 pcu:6403.00 scu:25995.25 sc:0 ; in:614 out:614 type:I q:21.02 q-aq:19.36 q-noVbv:10.81 q-Rceq:711.56 tex:8919685 mv:968621 misc:41386 icu:32400.00 pcu:0.00 scu:0.00 sc:0 ; in:618 out:615 type:P q:18.88 q-aq:16.46 q-noVbv:18.88 q-Rceq:565.49 tex:2799880 mv:56916 misc:71148 icu:68.75 pcu:15558.00 scu:16773.25 sc:0 ; in:616 out:616 type:B q:20.02 q-aq:17.83 q-noVbv:20.02 q-Rceq:565.49 tex:110495 mv:50303 misc:37207 icu:26.50 pcu:2554.00 scu:29819.50 sc:0 ; in:615 out:617 type:b q:21.15 q-aq:19.43 q-noVbv:21.15 q-Rceq:565.49 tex:19512 mv:16766 misc:15041 icu:7.50 pcu:1472.50 scu:30920.00 sc:0 ; in:617 out:618 type:b q:21.15 q-aq:19.60 q-noVbv:21.15 q-Rceq:565.49 tex:22118 mv:9902 misc:11770 icu:12.50 pcu:2035.50 scu:30352.00 sc:0 ; in:622 out:619 type:P q:17.88 q-aq:15.86 q-noVbv:17.88 q-Rceq:465.10 tex:1473509 mv:69570 misc:75329 icu:28.00 pcu:10446.50 scu:21925.50 sc:0 ; in:620 out:620 type:B q:19.52 q-aq:17.40 q-noVbv:19.52 q-Rceq:465.10 tex:60857 mv:36698 misc:30066 icu:34.00 pcu:3284.50 scu:29081.50 sc:0 ; in:619 out:621 type:b q:20.90 q-aq:20.03 q-noVbv:20.90 q-Rceq:465.10 tex:10112 mv:15468 misc:11904 icu:0.50 pcu:1651.00 scu:30748.50 sc:0 ; in:621 out:622 type:b q:20.40 q-aq:18.89 q-noVbv:20.40 q-Rceq:465.10 tex:18531 mv:11189 misc:11477 icu:1.50 pcu:2858.75 scu:29539.75 sc:0 ; in:626 out:623 type:P q:16.88 q-aq:14.98 q-noVbv:16.88 q-Rceq:403.25 tex:2501031 mv:114114 misc:91022 icu:25.50 pcu:15447.00 scu:16927.50 sc:0 ; in:624 out:624 type:B q:18.52 q-aq:16.65 q-noVbv:18.52 q-Rceq:403.25 tex:137489 mv:51871 misc:46946 icu:5.50 pcu:5322.25 scu:27072.25 sc:0 ; in:623 out:625 type:b q:19.90 q-aq:19.07 q-noVbv:19.90 q-Rceq:403.25 tex:10638 mv:22959 misc:16154 icu:1.25 pcu:1832.25 scu:30566.50 sc:0 ; in:625 out:626 type:b q:19.40 q-aq:17.95 q-noVbv:19.40 q-Rceq:403.25 tex:25665 mv:16503 misc:15633 icu:1.50 pcu:3283.25 scu:29115.25 sc:0 ; in:630 out:627 type:P q:15.88 q-aq:13.95 q-noVbv:15.88 q-Rceq:366.03 tex:3424538 mv:177159 misc:100818 icu:39.00 pcu:18913.00 scu:13448.00 sc:0 ; in:628 out:628 type:B q:17.52 q-aq:16.05 q-noVbv:17.52 q-Rceq:366.03 tex:120182 mv:76582 misc:56582 icu:9.50 pcu:5767.50 scu:26623.00 sc:0 ; in:627 out:629 type:b q:18.90 q-aq:18.08 q-noVbv:18.90 q-Rceq:366.03 tex:21301 mv:33974 misc:21742 icu:0.25 pcu:2607.25 scu:29792.50 sc:0 ; in:629 out:630 type:b q:18.40 q-aq:16.88 q-noVbv:18.40 q-Rceq:366.03 tex:39023 mv:22268 misc:19983 icu:0.50 pcu:3603.75 scu:28795.75 sc:0 ; in:634 out:631 type:P q:14.88 q-aq:12.98 q-noVbv:14.88 q-Rceq:342.51 tex:3609715 mv:185166 misc:103209 icu:22.50 pcu:19499.25 scu:12878.25 sc:0 ; in:632 out:632 type:B q:16.52 q-aq:14.81 q-noVbv:16.52 q-Rceq:342.51 tex:238353 mv:98798 misc:73415 icu:3.75 pcu:6427.50 scu:25968.75 sc:0 ; in:631 out:633 type:b q:17.90 q-aq:16.68 q-noVbv:17.90 q-Rceq:342.51 tex:29740 mv:46310 misc:27812 icu:0.25 pcu:3039.75 scu:29360.00 sc:0 ; in:633 out:634 type:b q:17.40 q-aq:15.69 q-noVbv:17.40 q-Rceq:342.51 tex:57690 mv:32825 misc:27877 icu:0.25 pcu:4382.00 scu:28017.75 sc:0 ; in:637 out:635 type:P q:13.88 q-aq:11.91 q-noVbv:13.88 q-Rceq:325.14 tex:3460038 mv:158479 misc:101680 icu:20.50 pcu:18189.25 scu:14190.25 sc:0 ; in:636 out:636 type:B q:15.35 q-aq:13.63 q-noVbv:15.35 q-Rceq:325.14 tex:379193 mv:113269 misc:80118 icu:5.75 pcu:7556.50 scu:24837.75 sc:0 ; in:635 out:637 type:b q:16.82 q-aq:15.46 q-noVbv:16.82 q-Rceq:325.14 tex:46405 mv:63600 misc:38532 icu:0.25 pcu:3900.00 scu:28499.75 sc:0 ; in:638 out:638 type:I q:20.99 q-aq:19.32 q-noVbv:13.67 q-Rceq:711.92 tex:8896344 mv:970390 misc:41414 icu:32400.00 pcu:0.00 scu:0.00 sc:0 ; in:642 out:639 type:P q:18.93 q-aq:16.59 q-noVbv:18.93 q-Rceq:567.78 tex:2552005 mv:69386 misc:76288 icu:55.50 pcu:15176.00 scu:17168.50 sc:0 ; in:640 out:640 type:B q:20.06 q-aq:18.22 q-noVbv:20.06 q-Rceq:567.78 tex:112905 mv:52989 misc:38762 icu:21.50 pcu:2946.00 scu:29432.50 sc:0 ; in:639 out:641 type:b q:21.20 q-aq:19.76 q-noVbv:21.20 q-Rceq:567.78 tex:16728 mv:18405 misc:15537 icu:2.50 pcu:1139.25 scu:31258.25 sc:0 ; in:641 out:642 type:b q:21.20 q-aq:19.98 q-noVbv:21.20 q-Rceq:567.78 tex:20026 mv:10150 misc:11915 icu:1.75 pcu:2091.75 scu:30306.50 sc:0 ; in:646 out:643 type:P q:16.93 q-aq:14.90 q-noVbv:16.93 q-Rceq:466.88 tex:3453938 mv:113190 misc:91953 icu:57.25 pcu:18479.00 scu:13863.75 sc:0 ; in:644 out:644 type:B q:19.06 q-aq:17.43 q-noVbv:19.06 q-Rceq:466.88 tex:55483 mv:58182 misc:40500 icu:10.00 pcu:3085.25 scu:29304.75 sc:0 ; in:643 out:645 type:b q:20.70 q-aq:19.80 q-noVbv:20.70 q-Rceq:466.88 tex:9654 mv:20986 misc:14965 icu:6.00 pcu:1345.50 scu:31048.50 sc:0 ; in:645 out:646 type:b q:19.70 q-aq:18.68 q-noVbv:19.70 q-Rceq:466.88 tex:25414 mv:13221 misc:13880 icu:10.50 pcu:2711.00 scu:29678.50 sc:0 ; in:650 out:647 type:P q:14.93 q-aq:12.75 q-noVbv:14.93 q-Rceq:400.07 tex:4860434 mv:112723 misc:92018 icu:38.25 pcu:21269.25 scu:11092.50 sc:0 ; in:648 out:648 type:B q:17.06 q-aq:15.36 q-noVbv:17.06 q-Rceq:400.07 tex:181971 mv:88697 misc:66339 icu:12.25 pcu:4751.25 scu:27636.50 sc:0 ; in:647 out:649 type:b q:18.70 q-aq:18.05 q-noVbv:18.70 q-Rceq:400.07 tex:17448 mv:35552 misc:23648 icu:0.50 pcu:1938.25 scu:30461.25 sc:0 ; in:649 out:650 type:b q:17.70 q-aq:16.18 q-noVbv:17.70 q-Rceq:400.07 tex:49749 mv:23784 misc:23905 icu:7.25 pcu:4414.00 scu:27978.75 sc:0 ; in:654 out:651 type:P q:12.93 q-aq:10.74 q-noVbv:12.93 q-Rceq:359.37 tex:6346580 mv:139910 misc:90402 icu:41.00 pcu:24633.75 scu:7725.25 sc:0 ; in:652 out:652 type:B q:15.06 q-aq:13.47 q-noVbv:15.06 q-Rceq:359.37 tex:328093 mv:117717 misc:82173 icu:1.25 pcu:6665.50 scu:25733.25 sc:0 ; in:651 out:653 type:b q:16.70 q-aq:15.41 q-noVbv:16.70 q-Rceq:359.37 tex:47873 mv:65283 misc:38875 icu:5.50 pcu:2853.50 scu:29541.00 sc:0 ; in:653 out:654 type:b q:15.70 q-aq:14.17 q-noVbv:15.70 q-Rceq:359.37 tex:122081 mv:53270 misc:43604 icu:0.25 pcu:5083.00 scu:27316.75 sc:0 ; in:658 out:655 type:P q:10.93 q-aq:8.72 q-noVbv:10.93 q-Rceq:335.85 tex:8136039 mv:171716 misc:87596 icu:28.25 pcu:27253.25 scu:5118.50 sc:0 ; in:656 out:656 type:B q:13.06 q-aq:11.38 q-noVbv:13.06 q-Rceq:335.85 tex:702323 mv:150229 misc:94949 icu:2.25 pcu:8872.75 scu:23525.00 sc:0 ; in:655 out:657 type:b q:14.70 q-aq:13.03 q-noVbv:14.70 q-Rceq:335.85 tex:159634 mv:116822 misc:61641 icu:0.50 pcu:4930.50 scu:27469.00 sc:0 ; in:657 out:658 type:b q:13.70 q-aq:12.15 q-noVbv:13.70 q-Rceq:335.85 tex:353740 mv:105045 misc:71443 icu:1.00 pcu:7244.00 scu:25155.00 sc:0 ; in:661 out:659 type:P q:8.93 q-aq:6.77 q-noVbv:8.93 q-Rceq:321.52 tex:10085655 mv:212847 misc:81959 icu:33.75 pcu:28963.00 scu:3403.25 sc:0 ; in:660 out:660 type:B q:10.73 q-aq:8.96 q-noVbv:10.73 q-Rceq:321.52 tex:1701220 mv:210087 misc:112924 icu:3.00 pcu:12724.00 scu:19673.00 sc:0 ; in:659 out:661 type:b q:12.53 q-aq:10.95 q-noVbv:12.53 q-Rceq:321.52 tex:494534 mv:186503 misc:91622 icu:0.25 pcu:7750.25 scu:24649.50 sc:0 ; in:662 out:662 type:I q:20.91 q-aq:19.25 q-noVbv:12.84 q-Rceq:711.40 tex:8915234 mv:970048 misc:41228 icu:32400.00 pcu:0.00 scu:0.00 sc:0 ; in:666 out:663 type:P q:19.38 q-aq:16.96 q-noVbv:19.38 q-Rceq:565.91 tex:1524170 mv:44877 misc:68638 icu:39.50 pcu:11065.25 scu:21295.25 sc:0 ; in:664 out:664 type:B q:20.51 q-aq:18.63 q-noVbv:20.51 q-Rceq:565.91 tex:87690 mv:33189 misc:28763 icu:17.00 pcu:2707.00 scu:29676.00 sc:0 ; in:663 out:665 type:b q:21.65 q-aq:20.91 q-noVbv:21.65 q-Rceq:565.91 tex:11465 mv:11524 misc:10883 icu:1.00 pcu:991.00 scu:31408.00 sc:0 ; in:665 out:666 type:b q:21.65 q-aq:20.31 q-noVbv:21.65 q-Rceq:565.91 tex:19446 mv:7853 misc:9471 icu:6.50 pcu:1917.50 scu:30476.00 sc:0 ; in:670 out:667 type:P q:17.38 q-aq:15.30 q-noVbv:17.38 q-Rceq:469.86 tex:3976949 mv:121189 misc:90081 icu:59.50 pcu:20252.75 scu:12087.75 sc:0 ; in:668 out:668 type:B q:19.51 q-aq:17.88 q-noVbv:19.51 q-Rceq:469.86 tex:47541 mv:61272 misc:40779 icu:20.50 pcu:2869.00 scu:29510.50 sc:0 ; in:667 out:669 type:b q:21.15 q-aq:20.17 q-noVbv:21.15 q-Rceq:469.86 tex:9628 mv:22542 misc:15445 icu:0.25 pcu:1248.25 scu:31151.50 sc:0 ; in:669 out:670 type:b q:20.15 q-aq:18.67 q-noVbv:20.15 q-Rceq:469.86 tex:21903 mv:11465 misc:12803 icu:4.75 pcu:2190.50 scu:30204.75 sc:0 ; in:674 out:671 type:P q:15.38 q-aq:13.37 q-noVbv:15.38 q-Rceq:413.48 tex:5801742 mv:234587 misc:96440 icu:40.25 pcu:24936.25 scu:7423.50 sc:0 ; in:672 out:672 type:B q:17.51 q-aq:15.80 q-noVbv:17.51 q-Rceq:413.48 tex:145165 mv:92370 misc:66726 icu:8.50 pcu:5054.50 scu:27337.00 sc:0 ; in:671 out:673 type:b q:19.15 q-aq:18.09 q-noVbv:19.15 q-Rceq:413.48 tex:20184 mv:41919 misc:25512 icu:1.75 pcu:2380.00 scu:30018.25 sc:0 ; in:673 out:674 type:b q:18.15 q-aq:16.41 q-noVbv:18.15 q-Rceq:413.48 tex:69539 mv:24097 misc:26707 icu:3.50 pcu:4566.75 scu:27829.75 sc:0 ; in:678 out:675 type:P q:13.38 q-aq:11.38 q-noVbv:13.38 q-Rceq:381.19 tex:7447218 mv:281964 misc:92415 icu:42.75 pcu:26994.75 scu:5362.50 sc:0 ; in:676 out:676 type:B q:15.51 q-aq:13.74 q-noVbv:15.51 q-Rceq:381.19 tex:296535 mv:119988 misc:81663 icu:3.50 pcu:5912.00 scu:26484.50 sc:0 ; in:675 out:677 type:b q:17.15 q-aq:15.73 q-noVbv:17.15 q-Rceq:381.19 tex:56922 mv:80495 misc:42571 icu:4.00 pcu:3064.50 scu:29331.50 sc:0 ; in:677 out:678 type:b q:16.15 q-aq:14.56 q-noVbv:16.15 q-Rceq:381.19 tex:137139 mv:43862 misc:40403 icu:0.50 pcu:4287.50 scu:28112.00 sc:0 ; in:682 out:679 type:P q:11.38 q-aq:9.29 q-noVbv:11.38 q-Rceq:353.80 tex:8839319 mv:244640 misc:87670 icu:32.50 pcu:28147.25 scu:4220.25 sc:0 ; in:680 out:680 type:B q:13.51 q-aq:11.86 q-noVbv:13.51 q-Rceq:353.80 tex:616643 mv:150017 misc:96701 icu:2.00 pcu:7981.50 scu:24416.50 sc:0 ; in:679 out:681 type:b q:15.15 q-aq:13.41 q-noVbv:15.15 q-Rceq:353.80 tex:148321 mv:110886 misc:58298 icu:2.00 pcu:4329.50 scu:28068.50 sc:0 ; in:681 out:682 type:b q:14.15 q-aq:12.35 q-noVbv:14.15 q-Rceq:353.80 tex:364847 mv:86474 misc:65944 icu:1.25 pcu:6469.00 scu:25929.75 sc:0 ; in:685 out:683 type:P q:9.38 q-aq:7.32 q-noVbv:9.38 q-Rceq:332.22 tex:10016105 mv:232399 misc:82305 icu:41.00 pcu:29078.00 scu:3281.00 sc:0 ; in:684 out:684 type:B q:11.18 q-aq:9.47 q-noVbv:11.18 q-Rceq:332.22 tex:1575095 mv:199183 misc:109967 icu:1.75 pcu:12011.75 scu:20386.50 sc:0 ; in:683 out:685 type:b q:12.98 q-aq:11.32 q-noVbv:12.98 q-Rceq:332.22 tex:442900 mv:175938 misc:87557 icu:1.00 pcu:7063.25 scu:25335.75 sc:0 ; in:686 out:686 type:I q:20.91 q-aq:19.25 q-noVbv:12.77 q-Rceq:713.22 tex:8935011 mv:977406 misc:41075 icu:32400.00 pcu:0.00 scu:0.00 sc:0 ; The question I have is, why are the HD encoded I frames at QP 35 while the UHD are at QP 20. Since the bitrates are the same, I would hope that HD would at least be the same as UHD. I will redo all of this with the same exact settings for HD and UHD for a more apples to apples comparison. It will take a few days to complete. I first want to figure out what setting is making pass 3 identical to pass 1 in terms of stats file. The other setting I changed was to remove --slow-firstpasss from pass 1 AND to also remove --multi-pass-opt-analysis from pass 3. It throws a warning that you can't use this and reports that it disabled it. Dumb question, can pass 3 use --slow-firstpass? It does not throw a warning if I include it. Just not sure if it actually does anything for pass 3. Last edited by Stacey Spears; 27th April 2021 at 15:44. |
#8140 | Link | |
