Old 31st May 2010, 05:56   #1  |  Link
narke
Help using avidemux to convert MKV to AVI
I found from China, I cannot access www.avidemux.org, so I get no means to read avidemux documents. But my purpose of using avidemux is very simple: to convert mkv movie to avi format.
Can anyone give me a simple instruction for using avidemux to do this job? For this moment, I get following questions:
1. how should i use the 'video' and 'audio' boxes located in the left of the screen?
2. I think I should select 'avi' in the output box, right? but when I open the 'configure' window for the 'avi' format, i found it will split the output file. Can this behavior be disabled? I don't want to get a set of split files, since my subtitle file is a single big one.
3. When I played with my mkv file, the avidemux had ever warned me that the file is detected as H.264, and ask me if or not to use another mode (and, if so, i will lost frame accuracy). What do I do?
Thanks in advance.
narke is offline
Old 31st May 2010, 05:59   #2  |  Link
What is the MKV file and where did you get it?
Guest is offline
Old 31st May 2010, 16:19   #3  |  Link
narke
mkv is a container format, see: http://en.wikipedia.org/wiki/Matroska
narke is offline
Old 31st May 2010, 16:37   #4  |  Link
Closing thread for evasive answer. PM with a proper answer to my questions to get your thread reopened.
What is the content of the MKV file and where did you get it?
Guest is offline
avi, avidemux, mkv
