2nd September 2006, 18:57 | #81 | Link | |
Hahahaha! I am still boycotting $metalica$ - If I understand correctly, they started out small and got greedy. #---back to topic---- Linkless distribution? I was always a big fan of BitTorrent... |
2nd September 2006, 21:15 | #82 | Link | |
My guess is that these are individualized files, but you got them under a previous IBX prior to the upgrade. Extraction of secondary keys could be problematic. Easiest workaround is to reget the licenses (most drastic solution - rename drmstore.hds in your DRM directory). Or, PM/Email me and you can help test support for secondary keys. For the VISTA error - that probably means that wmplayer.exe isn't where the program expects it to be found. What directory is wmplayer.exe in on a Vista system? What registry keys point to it? |
2nd September 2006, 21:33 | #83 | Link |
Thanks for the prompt reply.
the path for WMP under Vista (5536) is as follows: "C:\Program Files\Windows Media Player\wmplayer.exe" Wasn't sure exactly what you'd need in regaurds to the registry, so I'm including the following branch that makes references to the WMP defaults for Play and Open associations. Reg file is here.
PROUD DVD-RB Donator www.BadServo.com -- Visit me on the web. www.Exploitstation.com -- For all your Playstation 2 Modding/Hacking needs. "Obscurity is often mistaken for keen interpretation by people who should know better..." - Tycho |
3rd September 2006, 19:02 | #84 | Link |
Stating the obvious.
Dear Team,
I recently reinstalled windowsxp on my machine to try out fairuse4wm. My windows media player is 10.00.00.3802 I HAVE individualized my system [indivbox.key is version 11.0.5497.6285] I have succesfully recovered three keys using the ezdrm.com sample files. Fairuse4wm seems to be working fine, however, when i try to unDRM some video files downloaded from the net ;-p i get the response. 0 files converted 0 errors X warnings [where x is the number of files] and the warnings are: "[Path of the video] does not appear to be licensed to you." This error is correct. They aren;t licensed to me...but isn;t that the point or FairUse4WM? Isn't it supposed to rid me of the nessescity of lisencing these things? |
3rd September 2006, 21:41 | #85 | Link |
Country Member
@mcai8rw2
Your downloading of files and trying to unDRM them without them being licensed to you is a breach of rule 6. Please read the announcement at the top of this forum and the rules again. I do not expect your post will be replied to, given your circumstances. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
3rd September 2006, 22:25 | #86 | Link | ||
4th September 2006, 05:03 | #88 | Link |
Mirrored
v1.2 is mirrored at www.BG4G.net in the downloads section.
www.BG4G.net - By Gamers 4 Gamers |
4th September 2006, 06:52 | #89 | Link |
Well I tried with the new version but I still get the same error as I mentioned earlier...
E:\Legit Music\Mike Oldfield\Discovery\01 To France.wma UNABLE TO DECRYPT: Error reading 5974 bytes (5882) at offset 4501181 in file "E:\Legit Music\Mike Oldfield\Discovery\01 To France.wma". guess I will have to wait till 1.3 Brumfondl |
4th September 2006, 07:24 | #90 | Link | |
It *appears* that this file is truncated, given how much the code is trying to read, and how much it gets. SInce the space at the end is typically indexing information, you can get by without having it. The parser tries to be cautious though. I can just ignore the format and write out what I can for these portions? Should I risk writing out a corrupt file, or give errors so they can be corrected? For a -fix version, I'll try a policy of " if I can't read a whole block, I'll just ignore the entire block". This should be the least likely to break something else. Comments? Should I just keep the failing behavior? Last edited by viodentia; 4th September 2006 at 07:45. |
4th September 2006, 09:48 | #91 | Link |
I just tried 4 different files from 4 different directories. Results were:
E:\Legit Music\Massive Attack\Collected\04 Teardrop.wma UNABLE TO DECRYPT: Error reading 5976 bytes (5884) at offset 5336363 in file "E:\Legit Music\Massive Attack\Collected\04 Teardrop.wma". E:\Legit Music\Mike Oldfield\Discovery\01 To France.wma UNABLE TO DECRYPT: Error reading 5974 bytes (5882) at offset 4501181 in file "E:\Legit Music\Mike Oldfield\Discovery\01 To France.wma". E:\Legit Music\Mike Oldfield\Earth Moving\01 Holy.wma UNABLE TO DECRYPT: Error reading 5974 bytes (5882) at offset 4484983 in file "E:\Legit Music\Mike Oldfield\Earth Moving\01 Holy.wma". E:\Legit Music\Tall Dwarfs\Fifty Flavours Of Glue\01 Gluey_ Gluey.wma UNABLE TO DECRYPT: Error reading 5976 bytes (5884) at offset 2559477 in file "E:\Legit Music\Tall Dwarfs\Fifty Flavours Of Glue\01 Gluey_ Gluey.wma". Seems like a pattern Brumfondl |
4th September 2006, 13:35 | #92 | Link | |
I've only once had the problem and then it was when I accidentally tried to convert a file that was still downloading. (So like viodentia said, truncated file) Anyhow, nice work viodentia! This program has been a lifesaver. And 1.2 is working great with WMP11 beta 2. (I've been trying to avoid getting the updated IBX just in case, so I can't say how it works with that.) Josh Last edited by josh2; 4th September 2006 at 14:56. |
4th September 2006, 13:49 | #93 | Link |
Country Member
@josh2
You are new here, so I will direct you to the announcement at the top of this forum and rule 6. @all - I do not want to see discussion about downloaded media files in this thread. This thread is about a technical product. Please confine your discussions to that subject. Regards
4th September 2006, 17:32 | #95 | Link |
Brumfondi, it does seem like you have a fairly consistent problem. Please PM me.
You can also try this version (not really an officlal release, just ignores these read failures) https://uploads.sgul.ac.uk/uploads/5134382/ver12fix.zip This may cause the files to stop working in other ways though Last edited by viodentia; 4th September 2006 at 19:21. |
4th September 2006, 19:03 | #96 | Link |
My end-run for DRM'd audio is Total Recorder. So far it has worked with .WMA, iTunes and Audible, the only three formats I've been exposed to. It can convert at less than real time (8x on this laptop with Audible). I can also capture any audio stream with it, sometimes accelerated (WinAmp streams usually capture at twice normal speed). I set LAME to a VBR profile of 64-224 kbits and let it run. iTunes usually encode to about 160 kb, Audible to 80, internet streams up to 200, etc...Depends on the source.
4th September 2006, 20:22 | #97 | Link |
Trouble is, it's a lossy conversion whenever you do anything like that. (Total Recorder, SoundTaxi, Tunebite, MuvAudio, etc) FairUse4WM is much faster than any of those (nearly instant.. mere seconds per album), and is completely lossless.
Yeah, they're decent programs but if you can get this to work (which for most situations is pretty painless) it's much better. If only there was a tool like this for iTunes 6.. (QTFairUse is OK, but way way to slow.) |
4th September 2006, 21:56 | #99 | Link |
Error messages...
The error messages I seem to get are:
C:\Documents and Settings\WildmanCAL\My Documents\My Music\WMA files\Savatage - Gutter Ballet.WMA UNABLE TO DECRYPT: Size Error: 11008306382 cannot be truncated to -1876595506. C:\Documents and Settings\WildmanCAL\My Documents\My Music\WMA files\Musicmatch\a-ha - The Sun Always Shines On T.V..WMA UNABLE TO DECRYPT: Size Error: 1509990125154 cannot be truncated to -1838363038. C:\Documents and Settings\WildmanCAL\My Documents\My Music\WMA files\Musicmatch\a-ha - Hunting High And Low.WMA UNABLE TO DECRYPT: Error reading 20891756 bytes (716237) at offset 4562948 in file "C:\Documents and Settings\WildmanCAL\My Documents\My Music\WMA files\Musicmatch\a-ha - Hunting High And Low.WMA". C:\Documents and Settings\WildmanCAL\My Documents\My Music\WMA files\Musicmatch\a-ha - Take On Me.WMA UNABLE TO DECRYPT: Size Error: 1375470407266 cannot be truncated to 1080872546. These tracks are from Musicmatch are Windows Media v9 and have been legally purchased by me. Last edited by WildmanCAL; 5th September 2006 at 00:36. |
4th September 2006, 23:39 | #100 | Link |
Grouchy User
Sounds like this program isn't handling ASF files correctly, or perhaps some services didn't follow the ASF specification.
http://www.microsoft.com/windows/win...ASFViewer.aspx Microsoft provides this tool to verify ASF compliance (both WMA and WMV should verify under this program). |
