Old 24th January 2020, 19:50   #301  |  Link
a5180007
Originally Posted by maxibon View Post
Could someone check please?, TSMuxer hide subtitles when I try to replace the spa (latin) with spa (spain).
@maxibon my bad. This is a consequence of the 3d-plane patch, I've pushed the fix.
a5180007 is offline   Reply With Quote
Old 25th January 2020, 11:22   #302  |  Link
maxibon
Thank you so much @a5180007 please let me know when implemented
maxibon is offline   Reply With Quote
Old 26th January 2020, 15:53   #303  |  Link
a5180007
@maxibon please try latest bintray build nightly-2020-01-26--01-10-07.zip
Old 26th January 2020, 19:16   #304  |  Link
maxibon
Hi
I´ve tried with latest build and doesn't work yet;-(
By the way chapters doesn't work as well, doesn't keep original times
Regards
Old 27th January 2020, 16:16   #305  |  Link
Mike-uk
Hi, Hopefully this is the correct place to ask for tsmuxer help
ive encoded a .m2ts file to a smaller H265 file ( ive tried mp4 and mkv) using handbrake with nvenc, the resulting file plays fine, I can seek to any time of the file quickly and cleanly
the problem is if I use tsmuxer to mux to m2ts, if I try and seek to any time in the file it creats a pixulated image for 2 seconds with mphc then goes back to normal ?? vlc pauses for a few seconds befor resuming, the file just doesn't feel right
any idea why
Thanks
Mike-uk is offline   Reply With Quote
Old 27th January 2020, 21:24   #306  |  Link
a5180007
@Mike-uk you need to add x265 options --aud --hrd --repeat-header
Edit: --repeat-headers
Old 27th January 2020, 22:51   #307  |  Link
Mike-uk
Hi, adding thouse to handbrake seem to make no difference ?
Old 28th January 2020, 08:58   #308  |  Link
a5180007
@Mike-uk Please cut the first 5 MB of the m2ts with an hex editor, and send me the link to download.
Old 28th January 2020, 09:08   #309  |  Link
a5180007
Hi
Regards
@maxibon please zip and send me your .meta with original and modified .mpls and .clpi.
Old 28th January 2020, 14:49   #310  |  Link
Mike-uk
hi ive sent you the output of tsmuxer, m2ts file
Old 28th January 2020, 17:57   #311  |  Link
a5180007
@Mike-uk as suspected there is no AUD nal in your hevc stream. Please encode with x265 options --aud --hrd --repeat-headers.
If handbrake doesn't allow these options, use another frontend, or ffmpeg/x265 cli.
Old 28th January 2020, 23:18   #312  |  Link
Mike-uk
ok thanks for looking
ok handbrake should except commands to the encoder but don't see to work
Old 29th January 2020, 22:37   #313  |  Link
glc650
Just downloaded 2020-01-28--01-08-41 for mac but whenever I try to import a video I get the following error:
https://1drv.ms/u/s!AnsGKXR_EKR0hEP-...G_Upz?e=A0auoI
This is after running ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)" < /dev/null 2> /dev/null brew install freetype brew install in terminal.
Thanks,
->g.
glc650 is offline   Reply With Quote
Old 30th January 2020, 00:19   #314  |  Link
glc650
Thanks,
->g.
Never mind, for some reason the command in the readme was truncated on my system (I tried FF and Safari). Once I checked the web page's source I could see the full command.
Any plans to support TrueHD/Atmos?
Old 30th January 2020, 02:02   #315  |  Link
filler56789
SuperVirus
filler56789's Avatar
Hummm, the tsMuxeR readme.md says:
MacOS
This ZIP file for MacOS can just be unzipped and the executables can be used after installing a couple of dependencies.
I know "nothing" about MacOS, except that it is a kind of Unix, so I have to ask:
¿is it impossible to create static builds of tsMuxeR for the Mac operating system(s)?
filler56789 is offline   Reply With Quote
Old 30th January 2020, 12:20   #316  |  Link
varekai
varekai's Avatar
adding .sup subtitles out of sync
Hello!
Thanks justdan96 for picking up the torch and continuing the development of this one-of-a-kind software.
Really appreciate it, I use it a lot for my videos and Blu-ray.
As long as I've been using it I've had this problem.
Creating a subtitle .sup file using easySUP by Mr. Dean Kasabow.
Using tsMuxer:
In "Input" -> "add" adding an .mpls or .m2ts (24.000 FPS) video file and adding a .sup (24.000 FPS) subtitle file.
Output to Blu-ray folder.
The output subtitle is out of sync, it starts OK but then gradually goes out of sync.
I can't figure out what I'm doing wrong?
Could it be a bug in tsMuxer?
If I use a mediaplayer like PotPlayer or MPC-HC and load the .sup subtitle sync is perfect.
Any input is highly appreciated.
Best regards,
varekai
Edit: Problem solved, not a tsMuxer bug... sorry...
varekai is offline   Reply With Quote
Old 30th January 2020, 14:06   #317  |  Link
koka
justdan96, in COMPILING.md add ninja for ## Windows (Msys2):
pacman -Sy --needed $MINGW_PACKAGE_PREFIX-toolchain \
$MINGW_PACKAGE_PREFIX-cmake \
$MINGW_PACKAGE_PREFIX-freetype \
$MINGW_PACKAGE_PREFIX-zlib \
$MINGW_PACKAGE_PREFIX-ninja
and instead of
cmake . --build
use
cmake --build .
Thank you for your efforts!
koka is offline   Reply With Quote
Old 30th January 2020, 17:11   #318  |  Link
a5180007
@maxibon Nothing wrong with the files you sent me. The issue is you keep the original mpls with subtitle PIDs 0x12A0, 0x12A1 etc. , whereas tsMuxer creates new mpls/clpi/m2ts with PIDs 0x1200, 0x1201 etc. If you want to keep the original mpls, you have to modify the PIDs in the mpls with e.g. BDEdit or an hex editor.
I don't get how the original chapter times could be modified if you keep the original mpls: could you please expand ?
Old 30th January 2020, 17:31   #319  |  Link
filler56789
SuperVirus
Why he (thinks he) needs "ninja" for using MSYS2 on Windows or/and for compiling tsMuxeR is beyond me.
Old 30th January 2020, 19:18   #320  |  Link
koka
filler56789, before use:
cmake ../ -G Ninja
need install it:
pacman -S $MINGW_PACKAGE_PREFIX-ninja
