Old 17th September 2019, 07:27   #881  |  Link
stax76
stax76's Avatar
Can someone with Intel GPU tell me what following PowerShell command prints:
Get-WmiObject -class Win32_VideoController | Select-Object Caption
stax76 is offline
Old 17th September 2019, 09:05   #882  |  Link
NikosD
On my Win 10 machine using a Core i5-6500 gave me this:
Caption
Intel(R) HD Graphics 530
Perfect!
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 17th September 2019, 10:11   #883  |  Link
stax76
stax76's Avatar
@NikosD
Thanks, the Intel drop down items should now be hidden.
2.0.4.4 Beta
  • fix: nfo files with non xml content caused an exception
  • fix: if subtitle and audio titles contained illegal
    file system characters then these characters were replaced
    with an underscore and thus being lost, now the characters
    are escaped/unescaped and thus preserved
  • fix: update x265 switch --refine-mv
  • fix: in the nvenc dialog, Intel decoding options were present
    even when no Intel GPU is present
  • new: a link to the web site has been added to the menu
  • new: option to check online for new stable version once per day
  • new: avs plugin HDRTools
  • new: avs, vs plugin DGHDRtoSDR
  • new: ffms2 parameter colorspace has menu support in the avs code editor
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/f/s!ArwKS_ZUR01gySQIE1QCL2i9F_uR
stax76 is offline
Old 17th September 2019, 11:29   #884  |  Link
NikosD
2.0.4.4 Beta
I can't test right now the fix because I have no discrete GPU here, but I tried the opposite.
I have a PC with no discrete GPU - only Intel's iGPU - but I can choose nVidia H.264 & H.265 encoders or AMD H.264 & H.265 encoders from the first screen and I can see the decoders too in the drop-down of course.
Now that you have the ability to hide options depending on the presence or not of an iGPU, maybe it would be useful the opposite too.
To hide nVidia's and AMD's encoders and decoders for systems with no discrete cards.
NikosD is offline
Old 17th September 2019, 15:34   #885  |  Link
stax76
stax76's Avatar
In the main window, it's useful to see that staxrip supports these encoders and how the options look like, users can customize several types of profiles directly from the menus, choose 'Edit Profiles'.
stax76 is offline
Old 17th September 2019, 17:21   #886  |  Link
NikosD
Originally Posted by Patman View Post
Hello everybody. Unfortunately the dxva2 function can not be used in the current version of staxrip.
Right.
Works like a charm.
2.0.4.4 Beta
Fixed.
Fair enough!
NikosD is offline
Old 17th September 2019, 17:54   #887  |  Link
Patman
Patman's Avatar
Works like a charm.
Thank you for downloading and using my files.
What do you think about a button that detects GPU's and shows only the encoders which are supported by the GPU/GPU's? Without pressing button nothing happend. All encoders and options are shown. Only an idea
Patman is offline
Old 17th September 2019, 19:13   #888  |  Link
chipxtreme
NVEnc 4.48 is out
chipxtreme is offline
Old 17th September 2019, 20:32   #889  |  Link
Natty
Noob
need GUI for --selective-sao options in x265. it enables --sao directly if not set to zero. eg- --selective-sao 0
Natty is offline
Old 17th September 2019, 21:54   #890  |  Link
Patman
Patman's Avatar
Originally Posted by chipxtreme View Post
NVEnc 4.48 is out
https://github.com/staxrip/staxrip/issues/58
https://github.com/staxrip/staxrip/issues/60
Patman is offline
Old 17th September 2019, 21:57   #891  |  Link
stax76
stax76's Avatar
NVEnc 4.48 is out
Will be included in the next build, thanks.
GUI support will be available in the next build, I hope Wolfberry makes a new build.
stax76 is offline
Old 18th September 2019, 01:50   #892  |  Link
ZeroCool22
ZeroCool22's Avatar
I can update manually the NVEnc on the StaxRip-x64-2.0.4.4-beta or it will cause some problem?
ZeroCool22 is offline
Old 18th September 2019, 11:50   #893  |  Link
Z'Hadum
One Short Question:
I recently upgraded to 2.0.4 from 2.0.2:
With the new Version I get the following error from eac3to:
Audio encoding 1 using eac3to 3.34 failed with exit code: -1073741515 (0xC0000135)
The exit code might be a system error code: The program can't start because hs is missing from your computer. Try reinstalling the program to fix this problem.
What is "hs"?
I think I have to reinstall something?
Thx in advance!
Z'Hadum is offline
Old 18th September 2019, 17:50   #894  |  Link
Patman
Patman's Avatar
Yes you can do that. No problems are caused by this method.
Gesendet von meinem HMA-L09 mit Tapatalk
Tools for StaxRip | x264 - x265
Patman is offline
Old 18th September 2019, 20:53   #895  |  Link
Patman
Patman's Avatar
Originally Posted by Z'Hadum View Post
One Short Question:
What is "hs"?
Thx in advance!
Hi Z'Hadum,
this could be due to Microsoft Visual C ++ and .Net Framework. Update both and give notice again. Since version 2.0.2.6 .Net-Framework 4.8 is used in Staxrip.
Patman is offline
Old 18th September 2019, 21:40   #896  |  Link
stax76
stax76's Avatar
@Z'Hadum
Please post the command line used by eac3to and mediainfo of the input file, both can be found in the log file, maybe post the full log file on pastebin.
You can also try downloading an old staxrip version and then use the eac3to files from there, few weeks ago two eac3to libraries were updated, I think it was flac and dts.
stax76 is offline
Old 19th September 2019, 06:19   #897  |  Link
JKyle
App Digger
JKyle's Avatar
NVEnc 4.49 is released today.
JKyle is offline
Old 19th September 2019, 18:22   #898  |  Link
Patman
Patman's Avatar
Hi @ all,
I've updated my builds of MP4Box, x265 and ffmpeg (with dxva2 support). For these who are intresteted.
Builds
Patman is offline
Old 19th September 2019, 19:56   #899  |  Link
JKyle
App Digger
JKyle's Avatar
Hi @ all,
Builds
Wow! Thanks for sharing your assets.
I decided to use your MP4Box instead of Wolfberry's 'cuz Wolfberry's seems to insert an unwanted build number into the video stream metadata of the output mp4 file.
I pm'ed Wolfberry but I don't know when he will fix it.
BTW, your version of ffmpeg is very slim compared to the Wolfberry built ffmpeg, which is more than 90MiB in size.
Can you please explain what makes the big difference?
JKyle is offline
Old 20th September 2019, 05:15   #900  |  Link
ZeroCool22
ZeroCool22's Avatar
When it comes to reduce the size of the video using H265 i have a doubt, i already have my config done but sometimes the resulting video size is a little more bigger than what i would wish.
So the only way to get a more low size video is playing with the quality sliders, but Staxrip is not like other converters that have 1 quality slider, it have 3, so here is my question, i should increase the 3 sliders or only play with 1 of them?
Thx in advance!
aac, hdr, hevc, nvenc, staxrip, x264, x265
