#21 | Link | |
#22 | Link |
member
Yes, VirtualDub(Mod) and AVI_IO use the wrapper.
http://www.doom9.org/capture/capturing.html On my system they only work after running a WDM capture program, like VVCR or ATI MMC. I use VirtualDubMod because VVCR creates AVI files with internal audio and video offsets. VFW capture apps don't do this. |
#26 | Link |
Yet another bugfix version.
This one fixes 'minor' bugs when writing Matroska files, so I recommand you to dowload this version if you make Matroska files. It also fixes some other issues (the ticks in the trackbar, some problems when decompressing audio in specific cases). |
#27 | Link |
Problem with Save As... and Preview ouput from start...
I'm using the recent bugfix release of VirtualDubMod 1.5.10.1 build 2389. If I use the Save As (F7), or or Preview output from start (ctrl-F5) functions with an AVS file they work unless I have refreshed the AVS editor.
Example: I open a very simple AVS such as AVISource("D:\Capture.avi") Everything works fine until I open the script editor. Just pressing F5 for refresh is enough to cause the problem. Now if I try to save or preview from the start the dub box flashes on the monitor and then disappears. I've swapped 1.5.10.1 with 1.5.4.1 a couple of times and get the same results, 1.5.4.1 works fine. That's for all the hard work, in general I like the new release. Mike. |
#28 | Link | |
Re: Problem with Save As... and Preview ouput from start...
Seems like a little bug is remaining there. Actually when you refresh it set the selection start on the first frame, but also the selection end on this frame. i.e. it selects 0 frames to be processed ^^; Will fix that ASAP. [EDIT]Fixed in our CVS. You will have to wait a bit for the next bugfix to get it [/EDIT]
#29 | Link | |
#30 | Link | |
ffdshow/AviSynth wrangler
Re: Re: Problem with Save As... and Preview ouput from start...
I can't be the only one experiencing this, can I? *wonders* (Seems to me as if something only got half-initialized since starting playback solves it, but why it would break on ALT-TABbing is beyond me... )I'm using Windows 2000, the latest bugfix version (Dec 9th) of VDubMod and AviSynth 2.53 on a P4 2.4GHz with the following script: Code:
MPEG2Source("e:\DVD\WitchHunterRobin_1\WitchHunterRobin_01\VIDEO_TS\Video.d2v",cpu=0,iPP=true,idct=6)
a=last
b=last.ConvertToYUY2()
a=a.Telecide(order=1,guide=0,gthresh=5,post=1,hints=true,back=0,vthresh=15,show=false)
a=a.KernelDeint(order=1,sharp=true,twoway=false,threshold=3,map=false)
a=a.Decimate(cycle=5,mode=0,show=false)
b=b.ConvertFPS(23.976).ConvertToYV12()
a.Trim(0,3984-1) + b.Trim(3984,6144-1) + a.Trim(6144,32400-1) + b.Trim(32400,0)
Crop(4,4,712,474)
UnDot()
MipSmooth(preset="AnimeHQ",temporal=0,temporal_chroma=0)
TemporalSoften(4,4,8,15,2)
LanczosResize(640,480)
np: Kid606 - The Illness (Album Version) (Kill Sound Before Sound Kills You) |
#31 | Link |
No such problem here :/
Could you try to delete the settings in the registry ? Launch regedit and delete [HKEY_CURRENT_USER]->[Software]->[Freeware]->[VirtualDubMod]. Note that this will reset all your preferences to default values. |
#32 | Link | |
![]() Not that I can't redo the configuration in about 30 seconds... ![]() EDIT: And while I'm on a roll anyway - it's quite useful that you can start playing the video using SPACE, but I can't find a key to stop playing using the keyboard, but I guess that's quite handy. How about making hitting SPACE again stop playback if the video is currently playing? 2nd EDIT: Actually, I just found out what made it crash - if I disable "Display output video" either in the preferences or in the options menu prior to opening the video file (as I always do, as I'm only ever using Fast Recompress in conjunction with AviSynth), it crashes. If I turn the output pane on, it works. I guess that should help to track the cause down... (And actually, the same thing happens in the original VirtualDub 1.5.10, now that I've tried it - OOPS. Well, gotta go file a bug report against that as well.)np: Triosk Meets Jan Jelinek - Mis-Leader (1+3+1) Last edited by Leak; 14th December 2003 at 13:04. |
#34 | Link | |
Rumour has that Microsoft is building a 64 bit version of XP for X86 CPU's, dunno when it's going to be released though. |
#37 | Link | |
Hi everybody. A little gift for you
(the new one is build 2407 )Quote:
For this system to be enabled the admins of a project must all agree, and we (ChistianHJW, Belgabor and myself) all agreed on donating 100% of your donations to the Open Source community (see details on the page) ![]() Merry Christmas ^_^ |
#38 | Link |
Brazilian Anime Ripper
I found a problem and I don't know if it is a avisynth or virtualdubmod error.
I opened a AVS in virtualdubmod. At the same time this AVS is opened in notepad. After open in virtualdubmod, I change some filters settings (Convolution3d("animeHQ") instead Convolution3d("animelq") for example) and when I choose "Refresh" in Edit menu, the audio was gone. The only way to audio open again is open AVS file from File/Open menu, the refresh function can't open audio again. Sometimes it's not occuring after the first AVS change, but in the second or thrid. This problem is occuring in virtualdubmod 1.5.4.1 too. |
#39 | Link |
Script Editor 1.5.10.1 crash
I can't use the script editor with Vdubmod 1.5.10.1 (even the latest release - build 2407
). Vdubmod 1.5.4.1 was working fine...Loading a script with File->Open video file (.avs file) is ok, but when I click Tools->Script editor it always crashes. Please check the crashinfo.txt at SourceForge (http://sourceforge.net/tracker/index...89&atid=512619). The only way I can see the script editor is when there is no .avs file loaded, but when I try to do something like open, save or revert, it crashes too. I'm using Win98SE+AMD Athlon XP 2200+ with an Epox 8RDA+ motherboard. The Avisynth version is 2.53. Is there anybody else having the same problem ?
#40 | Link |
i have the same problem
Hi i have exactly the same problem. If i open the AVS Editor before i load an avs everything works. But after i loaded a simple avs and opened then the AVS Editor VirtualDubMod crashes with a typical close or details Windows error. I`am using VirtualDubMod 1.5.10.1 build 2407 and Avisynth 2.53.
System: AMD 1600+ Win98 SE |
| Thread Tools | |
| Display Modes | |
