#61 | Link |
契約者
Hmm, I don't think they are artifacts. The video source is a still image under 185mbps bitrate... it should be virtually lossless. Image taken with old build have straight lines which Is expected. Bot on another screenshow... I never seen such artifacts, pattern looks too perfect to me and doesn't even reminds any kind of macroblocks.
It will be nice to hear someone else's opinion on this. Last edited by Keiyakusha; 17th July 2012 at 10:36. |
#62 | Link | |
I will check it. update: it works fine- great work ![]()
#63 | Link |
So now- does ffms2 has to index all files, even those with I frames only- like ProRes, uncompressed?
Indexing is bit slow- I have 0.5% CPU usage. Some QT reference files are also not working same way as in QT player. Last edited by kolak; 17th July 2012 at 17:10. |
#64 | Link | ||
You can check transfer speed using performance monitor (assuming you are using win7). If indexing uses more than half available bandwidth then I think it is normal. Quote:
PS: The previous version can't read color matrix flag from source file, I just compiled a build that fixed that.
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 |
#65 | Link |
Sorry- indexing is fine, I'm just not patient enough
![]() It reads at about 100MB/sec. Gigabit on Win7 works at full speed- not at 50% like it use to be on XP. One thing- in some cases info jumps from 0 to 99% straight away, but sometimes it works fine. These are all I frame only files- ProRes, DNxHD, uncompressed. It took about 6 minutes to do 130GB ProRes on my local RAID, so it's ok. Files, which I refer to are reference files to AVID MXF files (reference files are created by 3rd party software CalibratedQ). I noticed that nothing based on ffmpeg can open them- ffmpeg, ffmbc etc. They do work fine in QT player. Thanks for the new build- reading ProRes, DNxHD was fine anyway (at least for my samples), but good to have it working as it should. Last edited by kolak; 18th July 2012 at 10:42. |
#66 | Link |
Cool, updated http://avisynth.org/mediawiki/High_b..._with_Avisynth
#67 | Link | |
But I think we need to mention that ffms in the first post is linked with libav, and the second one is linked with ffmbc. The first version may be better for general video files, but have bug on decoding DNxHD files. The second one fixed the bug, and may have better support for professional video formats.
#69 | Link | |
#71 | Link |
That's OK, it was just my typo (and bad grammar :P ). The paragraph is clearer now, thanks.
#72 | Link | |
I have a problem loading the patched ffms2.dll.
I'm using Avisynth 2.60 and Virtualdub 1.10.3 (32bit). I have ffms2.dll, ffmsindex.exe and FFMS2.avsi in my Avisynth plugins folder. Opening my avs file in Virtualdub gives the following error: Quote:
I've tried both versions: ffmbc and libav. I used LoadCPlugin for ffmbc which I believe is correct. I admit I lean towards the newbie side. Any ideas? Many thanks. |
#73 | Link | |
#76 | Link |
Yes, hacks are the same as ones in previous versions.
#77 | Link |
That's great, thanks.
I would just like to check that everything is okay as I'm not sure exactly what the LSB part should look like. I'm opening a 10bit 4:2:2 v210 clip. Viewing in Virtualdub shows green for the LSB part with just the brightest highlights that are in the video coming through (white only). In other words, just the very highest luma values. Is this how it should be? |
#78 | Link | |
#79 | Link |
Thanks again SAPikachu.
I've a problem with f3kdb_dither though. My source video is v210 4:2:2 10bit as mentioned. With the following code: Code:
FFVideoSource("test.avi", enable10bithack = true)
f3kdb_dither(input_depth = 10)
Any ideas why that is? Thanks for any help. |
| Tags |
| avisynth, black frames, detecting, dnxhd, mov |
| Thread Tools | |
| Display Modes | |
