#901 | Link | |
https://github.com/Asd-g/AviSynthPlu...ter/MCTD_.avsi |
#902 | Link | |
#903 | Link |
You can click on the "history" for the commits
https://github.com/Asd-g/AviSynthPlu...ter/MCTD_.avsi MCTD_.avsi: fix sharpening internal masks (high bit depth) https://github.com/Asd-g/AviSynthPlu...6c69f12c8bd347 |
#904 | Link | |
https://github.com/Asd-g/AviSynthPlu...CTD_.avsi#L359 |
#905 | Link | |
Why did you add internal multithreading to MCTD? What benefit does using prefetch internal to the filter vs. letting AVISynth+ do it after the filter with prefetch? I don't see any improvement from using it. I couldn't find a ncpu setting that gave a higher FPS than a prefetch() statement at the end of my script. Additionally, using the internal multithreading in MCTD prevents multithreading any filters in the script after MCTD (I think). With a minimal script of a source, crop, converting to 16bits, & MCTD I got the best performance with ncpu=1 and prefetch(14). ncpu=-6 is the best value I found for the internal multithreading, but it is slightly slower. ncpu=1 & prefetch(14): Code:
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021 AviSynth+ 3.7.2 (r3661, 3.7, x86_64) (3.7.2.0) Number of frames: 1000 Length (hh:mm:ss.ms): 00:00:41.708 Frame width: 1920 Frame height: 804 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 1000 (0 - 999) FPS (min | max | average): 0.609 | 117646 | 14.44 Process memory usage (max): 5315 MiB Thread count: 47 CPU usage (average): 86.7% Time (elapsed): 00:01:09.242 Code:
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021 AviSynth+ 3.7.2 (r3661, 3.7, x86_64) (3.7.2.0) Number of frames: 1000 Length (hh:mm:ss.ms): 00:00:41.708 Frame width: 1920 Frame height: 804 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 1000 (0 - 999) FPS (min | max | average): 0.447 | 32.07 | 13.89 Process memory usage (max): 4514 MiB Thread count: 87 CPU usage (average): 85.7% Time (elapsed): 00:01:11.984 ncpu=1 & prefetch(14): Code:
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021 AviSynth+ 3.7.2 (r3661, 3.7, x86_64) (3.7.2.0) Number of frames: 1000 Length (hh:mm:ss.ms): 00:00:41.708 Frame width: 1920 Frame height: 804 Framerate: 23.976 (24000/1001) Colorspace: YUV420P10 Frames processed: 1000 (0 - 999) FPS (min | max | average): 0.315 | 357140 | 13.96 Process memory usage (max): 5913 MiB Thread count: 52 CPU usage (average): 86.9% Time (elapsed): 00:01:11.631 Code:
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021 AviSynth+ 3.7.2 (r3661, 3.7, x86_64) (3.7.2.0) Number of frames: 1000 Length (hh:mm:ss.ms): 00:00:41.708 Frame width: 1920 Frame height: 804 Framerate: 23.976 (24000/1001) Colorspace: YUV420P10 Frames processed: 1000 (0 - 999) FPS (min | max | average): 0.380 | 27.16 | 12.89 Process memory usage (max): 4636 MiB Thread count: 98 CPU usage (average): 71.3% Time (elapsed): 00:01:17.590 1) Explain that the default value of 1 disables internal multithreading? (I think this is true) 2) I think the instruction should say "Do not use prefetch() after MCTD if you have enabled internal multithreading." instead of what it says now. 3) Perhaps warn that a good starting value for ncpu is not the value they had been using in their subsequent prefetch statement. I do see it says to start at -2 and decrement by 2 until they find optimal performance, but I think many people will think they if they had been using prefetch(8) they should start with ncpu=-8. I get optimal performance with ncpu=-6 and prefetch(14) respectively. |
#906 | Link | |
| Thread Tools | |
| Display Modes | |
