#22 | Link | |
LaTo INV.
UXADdegrain ![]() if someone have a better name... ![]() (MCdegrain/MCttempsmooth?) Last edited by LaTo; 26th July 2008 at 10:21. |
#24 | Link | ||
LaTo INV.
from fft3dgpu readme: Quote:
#28 | Link | |
LaTo INV.
New version: v7.29a
Source Protect=false (default) Protect=true I haven't tested much this option (only on this source), so default settings need to be tweaked a little... I haven't be abble to reproduce the star loss with martino's sample, maybe with very high settings ![]() Moreover I have not watched at MC_Spuds starfield parameter, maybe it's different but it works well (screenshot above)
#29 | Link |
Posts: n/a
LaTo,
I see you added the temporal Min/Max limiting to the sharpening. I don't think you should limit with both "contra" and the temporal min/max, it really should be one or the other. Otherwise, after "contra" limiting, the temporal min/max limit rarely does anything because the contra limits much more than the min/max. -G |
#30 | Link |
LaTo, with MoComp'ed Contra-Sharpening we must use advanced sharpening routines, not just the simple 3x3 kernel Contra-Sharpening.
Read Didie's long explanation here In my opinion, the Smode 4 from LSF is more suited. Code:
strength = default(strength, 100) Str=string(float(strength)/100.0) mt_lutxy(clp, clp.RemoveGrain(11,-1), "x y == x x x y - abs 16 / 1 2 / ^ 16 * "+Str+" \ * x y - 2 ^ x y - 2 ^ "+Str+" 100 * 25 / + / * x y - x y - abs / * + ?")
Greece PAL User... Last edited by Nikos; 2nd August 2008 at 16:07. |
#31 | Link | |
LaTo INV.
#33 | Link | |
LaTo INV.
#37 | Link |
In my opinion the s4R = (post==2) ? repair(s4,smB,1,-1,-1).Mergechroma(s4) : NOP() line is not suited because now we have almost the same effect as simple contra-sharpening.
If you want to repair a little try another mode, not the 1. The soothe(xx) is more appropriate here.
Greece PAL User... |
#40 | Link |
HDConvertToX author
Hi LaTo
i would like to add your Udegrain script to automkv, so first of all i will ask permission to include second question: could you suggest 4 default parameters usage (light grain/medium/heavy/sharp/... whatelse this script is capable...) ? thanks BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
| Thread Tools | |
| Display Modes | |
