Old 30th July 2023, 21:30   #821  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
If you mean "bilibili" logo then it's transparent, there is not enough good frames for analysis, even if there were enough, that AV1 video is so much damaged by compression that you wouldn't get good Deblend results anyway.
Actually all videos you posted here are very low or low quality, just use Inpaint on them.
VoodooFX is offline   Reply With Quote
Old 30th July 2023, 22:09   #822  |  Link
drunksunk
Are there extra parameters I could you to improve the final result or just an Analyze=2 and then apply the mask with mode=Inpaint is all I can do? I tried also DoomDelogo but that's worse.
drunksunk is offline   Reply With Quote
Old 30th July 2023, 22:56   #823  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Check if Turbo=-1 makes it better.
Old 3rd August 2023, 22:42   #824  |  Link
TrickyTrix
I used InpaitDelogo with great results a few times with Inpaint mode.
Now I wanted to try Deblend mode on https://www.youtube.com/watch?v=XOiZGSkjygs (ignore the color logo in the beginning and in the end because I'll edit that out later)
My script:
LWLibAvVideoSource("F:\Sheepish_wolf\The_Sheepish_Wolf_(1942).mp4")
InpaintDelogo(automask=0, mask="F:\Sheepish_wolf\logomask.bmp", Loc="1510,886,-178,-100", mode="Deblend")
Mask is created with: InpaintDelogo(automask=0, mask="F:\Sheepish_wolf\logomask.bmp", Loc="1510,886,-178,-100")
Is it normal that you can see transparent defects on dark surfaces after running the script (for instance from 49 to 51 sec)? It's great as is, but I have to ask
TrickyTrix is offline   Reply With Quote
Old 4th August 2023, 06:53   #825  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Share the masks.
Deblend defects are expected on the low quality videos from Youtube.
Old 4th August 2023, 16:36   #826  |  Link
TrickyTrix
Here is the mask.
Old 4th August 2023, 16:47   #827  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Don't use attachments in this forum, you can upload to wetransfer or mega ect.
By "masks" I meant .ebmp file.
Old 4th August 2023, 19:00   #828  |  Link
TrickyTrix
Here it is:
https://mega.nz/file/8sURVQIb#_n7LlV...Hma50FAKoTspWs
Old 4th August 2023, 19:51   #829  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Don't know why but I got a lil bit better masks: https://we.tl/t-ULUDdL4gQV
Original vs My vs Yours [with Interp=0, dPP=0 to see pure deblend effect]:
Maybe you didn't excluded non-logo/logo-animation parts when doing analysis. [.mp4 I downloaded is ~180MB]
Originally Posted by TrickyTrix View Post
...can see transparent defects...
I guess it's like on the 2970 frame:
It looks like usual Youtube "damage", you could ask the utube uploader for the original undamaged video.
"Optimize2=2, IntSpd=3, dPP=-5" can make it look better like this:
But it will make blurry detailed areas where deblending is OK.
You can apply different delogo settings on different parts of video by using Trim().
EDIT:
You can use .ebmp file directly with mask argument -> mask="D:\_mask.bmp_InpaintDelogo3_1510-886-178-100_A2-30.ebmp"
Old 6th August 2023, 00:07   #830  |  Link
drunksunk
If you can get Deblend mode to just fades the logo a bit but not fully remove it, what setting do you need to tweak to make the removal harder and remove that last bit of transparency? video is this https://t.ly/YXgW1
Old 7th August 2023, 17:34   #831  |  Link
color
color's Avatar
It has worked perfectly with one color logos, but this...I can get rid of the white (blended away), but the black one is more problematic.
https://we.tl/t-mSWMlUf1yy
I am using the standard thingie:
InpaintDelogo(mask="logo.bmp", Loc="760,580,-90,-50", Mode="Deblend", Automask=0)
Automatic Colorization
color is offline   Reply With Quote
Old 7th August 2023, 23:32   #832  |  Link
kedautinh12
With this logo, i think use mode Inpaint is better
Old 8th August 2023, 00:45   #833  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
If you can't deblend it then you can't. Use Inpaint.
Old 8th August 2023, 00:59   #834  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Both black and white areas looks same for me.
Before vs After [frame 13585 after trim]:
LWLibAvVideoSource("D:\New File (12).avi")
Trim(118,30904) # Exclude non logo/logo animation for analysis
InpaintDelogo(mode="Deblend", mask="D:\CN.bmp", Loc="12,18,-18,-16")
Old 8th August 2023, 08:51   #835  |  Link
color
color's Avatar
Thats what I use, but it looks a bit like this I mean.
I missed the image, sorry:
optimizer does blur it a little and makes it a little bit more invisible, but not that great.
frame 025794 when using the "trim"
Old 8th August 2023, 17:39   #836  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Then use Inpaint. Read there about utube videos -> https://forum.doom9.org/showthread.php?p=1990401
Old 8th August 2023, 18:07   #837  |  Link
color
color's Avatar
Then use Inpaint. Read there about utube videos -> https://forum.doom9.org/showthread.php?t=176860
hmm, well inpaint does not look so good. It was recorded directly from tv, but I guess its not enought to get better results. It need to be raw as well.
Old 8th August 2023, 18:17   #838  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Did you captured original digital stream or recorded it to some lossless codec?
Old 8th August 2023, 18:23   #839  |  Link
color
color's Avatar
Capture the original stream on the hard drive in my DVD-recorder (when I had that one, many years ago), I did choose 720p as resolution, I thought it would give better result, it was more than 10 years ago now. I don't remember if it was through hdmi or scart however, but If i remember correctly hdmi was the only way to be able to save 720, It did give better result when selecting to burn on dvd it gave crisper image than using 576 at the beginning when recording...
Old 8th August 2023, 18:54   #840  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
So, not the original digital stream and not lossless.
delogo, hardsubs, ocr, remove, watermark
