Old 13th June 2023, 23:21   #801  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I've looked at that video, looks like logo is animated whole clip, you can't deblend it.
Just use inpaint on it.
mode=Inpaint, Turbo=-1
Before:
After:
VoodooFX is offline   Reply With Quote
Old 16th June 2023, 02:50   #802  |  Link
drunksunk
Nice, ty.
I didn't see it useful anywhere with positive Analyze and in general it's a nonsensical "hack".
EDIT:
Just tested now, AnalyzeTh=45 produced similar reduction on artifacts on that circle without making worse the rest of deblend like Deep:
LWLibAvVideoSource("D:\zzz.mp4")
InpaintDelogo(mask="D:\mask.bmp", Loc="1570, 904, -28, -58", Mode="Deblend", Analyze=1, AnalyzeTh=45, dPP=-5)
It's amazing how good the result is with this setting, looks perfect almost everywhere except certain parts where you can slightly see the halo effect left by the logo. If I wanted to push a little further getting completely rid of the logo but risking the overlapping text becoming blurrier, what would be the setting to tweak for that?
drunksunk is offline   Reply With Quote
Old 16th June 2023, 03:30   #803  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Then you don't want to use "1" from Optimize2 argument which is enabled by default. Set Optimize2=2.
Old 8th July 2023, 08:37   #804  |  Link
drunksunk
Originally Posted by katzenjoghurt View Post
1) Get a better version of that video from here:
https://assets14.ign.com/videos/zenc...26343076-w.mp4
(It's a 817MB file with a 5000kbps encoding rather than your 3000kbps clip)
How did you manage to find the real video location on the website? When analyzing the network traffic, the best I can find is the .m3u file of the stream for reconstructing the file using ffmpeg, but somehow you managed to find the actual mp4 source and I wonder how you did that.
Example: https://www.ign.com/articles/2015/02...lved-ign-first
https://assets7.ign.com/videos/zenco...6350275-w.m3u8
Also, do you think this mask would work fine for all videos as long as the type of logo to remove is the same?
Old 17th July 2023, 00:33   #805  |  Link
drunksunk
Can somebody tell me how to improve my mask? I use this:
InpaintDelogo(Loc="1590,910,-10,0", mask="D:\Z_DELOGO\d\mask.bmp", Automask=1, Analyze=3)
But the logo gets removed well only for left half, while right half has some extra stuff that gets captured.
File is THIS
Old 17th July 2023, 13:50   #806  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Is that logo only last for 13 seconds?
These settings produce good basemask:
LWLibAvVideoSource("D:\file.mp4")
InpaintDelogo(Loc="1600,912,-20,-6", mask="D:\morbid.bmp", Automask=1, Analyze=-4, FrB=136, aMix=-5)
Old 19th July 2023, 21:26   #807  |  Link
drunksunk
What about this other video?
I used this:
InpaintDelogo(Loc="1540,870,-70,-30", mask="D:\Z_DELOGO\e\mask.bmp", Automask=1, Analyze=-4, aMix=-5)
But I noticed there are still some small white particles left. Trying to tweak the aMix does never trully give perfect result all-around.
Old 19th July 2023, 22:53   #808  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
What about you "answering" questions with questions?
Old 29th July 2023, 17:24   #809  |  Link
drunksunk
Yes, sorry that was only 13s indeed.
Old 29th July 2023, 18:02   #810  |  Link
drunksunk
I think I found a bug in InpaintDelogo when using portable (loose files) AviSynth+ installation instead of Windows installer: https://i.imgur.com/uLkcWJ9.png
Old 29th July 2023, 18:35   #811  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
It's not a bug, it's a message telling you what to do:
"Load 'ImageSeq.dll' with 'LoadPlugin' or install Avisynth+."
Old 29th July 2023, 18:52   #812  |  Link
drunksunk
The fact is that AviSynth+ is installed, but it's installed as loose files and it's references inside AvsPmod settings in "Custom AviSynth directory".
Old 29th July 2023, 19:19   #813  |  Link
drunksunk
After months I'm still unable to automask correctly...
What am I doing wrong? Mask looks perfect, but when applied the end result is garbage... https://i.imgur.com/wakI9KN.png
Automask=1, mode="Deblend", Analyze=2
Clip is THIS
Old 30th July 2023, 01:40   #814  |  Link
drunksunk
The problem is that there is no legend with alla the parameters, possible values and what they do.
Old 30th July 2023, 12:23   #815  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
The real fact is that you didn't installed AviSynth+, you just copied files and plugins are not autoloaded, in such case you need to load them manually with LoadPlugin().
The basemask is not important for the actual deblending process.
Automask just creates a black/white basemask which is enough only for Inpaint, for Deblend additional deblending masks are auto-created on the first run when Automask is not on.
With "Analyze=2" on this short clip you don't get good deblending masks, that's why you get the garbage result.
The real problem is that you don't read what is posted for you.
I remember answering you multiple times what and where to read.
After months I'm still unable to...
Unable to read posts!? Just kidding...
Old 30th July 2023, 13:38   #816  |  Link
drunksunk
I looked at GitHub, looked at first post, etc. but couldn't find the entire list of parameters like you can for ffmpeg and other tools, so I don't know what dPP, Interp, Optimize, AnalyzeTh, aMix, etc. do. Generally when you download an OSS tool you get either get a file with all the instructions or they have a website with the documentation on how to use the tool.
Could you please suggest what parameters should I use for the best result and why you chose those parameters to help me understand the thought process?
Old 30th July 2023, 14:24   #817  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I looked at...
Maybe 6th will be your lucky number.
Here you go, links to 5 previous answers I found:
https://forum.doom9.org/showthread.php?p=1987281
https://forum.doom9.org/showthread.php?p=1986329
https://forum.doom9.org/showthread.php?p=1986315
https://forum.doom9.org/showthread.php?p=1986299
Old 30th July 2023, 14:53   #818  |  Link
drunksunk
So, since the logo is almost completely opaque, I cannot use Deblend on it? With Inpaint I get much better results but there are still some leftover artifacts.
Old 30th July 2023, 15:18   #819  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I have no idea what you mean and I don't see any logical connection to the post you quoted.
Old 30th July 2023, 21:08   #820  |  Link
drunksunk
I meant that by looking at documentation in the script, I read that Deblend is only valid for transparent logos, while the video I provided has basically opaque logo so that doesn't work well. I tryed all previous settings and none of them could remove the logo without being slightly noticeable using the Inpaint mode.
delogo, hardsubs, ocr, remove, watermark
