Old 5th May 2023, 02:32   #761  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by drunksunk View Post
I tried this but I get error "increase analyzeth" and i increase to 100 but nothing changed.
OK, thanks for letting me know.
VoodooFX is offline   Reply With Quote
Old 7th May 2023, 01:25   #762  |  Link
drunksunk
Doesn't the same command work well for opaque logos?
drunksunk is offline   Reply With Quote
Old 7th May 2023, 13:06   #763  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Those settings are for a transparent logo [for that another video]. Anyway, for an "automask" run most of them are not used.
That error could mean that coords are wrong or there are no suitable frames to analyze. Set Analyze=3 to analyze all frames.
You better share the video or you'll have thousand other questions and I don't have a crystal ball to answer them.
Old 7th May 2023, 20:10   #764  |  Link
drunksunk
The video is this one: https://forum.doom9.org/showpost.php...&postcount=707
Old 7th May 2023, 20:14   #765  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
There is no video.
Old 10th May 2023, 01:36   #766  |  Link
drunksunk
Originally Posted by VoodooFX View Post
There is no video.
It's actually a video you edited yourself. Anywhere it was archived on Streamable so I reuploaded it here.
Old 11th May 2023, 01:13   #767  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I couldn't edit video you never shared. I edited your image!
Anyway this logo is not a logo but some special effect from game, whole area around those letters has some effects.
You better use DoomDelogo for this.
Old 11th May 2023, 09:57   #768  |  Link
drunksunk
I know for a fact that it's a logo added on top because I have another video which is identical but without the logo. The only issue is that it's lower quality.
Old 11th May 2023, 13:43   #769  |  Link
poisondeathray
How much "lower quality" ? Did you try align & merging them with a mask ?
Old 11th May 2023, 15:35   #770  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Then share this another video.
Old 11th May 2023, 16:42   #771  |  Link
poisondeathray
It looks like some of the artifacts are from motion interpolation. They correspond to the errors in other parts of the frame on the odd frames . The other artifacts around the logo are compression artifacts. The original video is 30fps .
Old 11th May 2023, 18:53   #772  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Whatever this is, for me it looks like there is some blend around area then inconsistent blur on to it. Nothing left to deblend, even if it was clean blend then clip is too short to build deblend mask.
Whole area needs to by treated as a one big hole, I don't even know what inpaint settings should be used on such, if found they probably would be very slow.
When I was thinking about "Turbo" argument I had idea to dowsample stuff then inpaint, maybe such approach would work here.
Old 17th May 2023, 02:34   #773  |  Link
drunksunk
Is it better to use InpaintDelogo before or after an AI Upscaler like Topaz AI Video?
Old 17th May 2023, 02:37   #774  |  Link
kedautinh12
I think before and if your video interlaced, you need deinterlaced before use InpaintDelogo
Old 17th May 2023, 10:46   #775  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Before. But better is to not use upscaler at all.
Old 17th May 2023, 22:00   #776  |  Link
drunksunk
I thought that with higher resolution and crispier edges the result would be better? Anyway, can't get a good mask out of this: https://i.imgur.com/6MrRVZu.png
Mask: https://i.imgur.com/Yej7xi2.png
Maybe I should create it manually with Photoshop?
I'm using this:
InpaintDelogo(Loc="1570,910,-30,-60", mask="D:\mask.bmp", Automask=1, aMix=-2, AnalyzeTh=100, mode="Deblend", dPP=-5, Interp=3, Optimize2=2)
Old 17th May 2023, 23:01   #777  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You are using parameters from another logo, this is not how it works. Read the manual!
Old 18th May 2023, 15:27   #778  |  Link
drunksunk
Do I just need to lower AnalyzeTh to fix it?
Old 18th May 2023, 18:55   #779  |  Link
katzenjoghurt
With AnalyzeTh=255 pretty much all frames should be analyzed.
Easier:
InpaintDelogo(Loc="1570,910,-30,-60", mask="D:\mask.bmp", mode="Deblend", Automask=1, Analyze=3)
Analyze=3 will also analyze all frames. Default is 2.
katzenjoghurt is offline   Reply With Quote
Old 18th May 2023, 21:42   #780  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
There is no magic button to "fix it", there are many ways for many different videos, you need to understand what the arguments do to get desired result.
Without video you are on your own.
delogo, hardsubs, ocr, remove, watermark
