Old 7th December 2023, 11:46   #1721  |  Link
dbtayag
Originally Posted by dbtayag View Post
This started with OPPENHEIMER and has continued with A HAUNTING IN VENICE. A little squiggle at the end of the letter is screwing up the OCR. I'm currently using NOCR.
Is there a way to do an OCR so the OCR would just ignore the little squiggle?
I was able to find a way to remove the squiggle. Right click > Image pre-processing > Binary image compare threshold lever > move left or right until squiggle is gone.
dbtayag is offline   Reply With Quote
Old 16th December 2023, 08:20   #1722  |  Link
markfilipak
markfilipak's Avatar
Location: Mansfield, Ohio (formerly San Jose, California)
Pre-Script:
I got an answer from a heavyweight:
https://forum.doom9.org/showthread.p...44#post1995144
Hi All, Thank you for SE. I like it!
I have a problem that needs some basic info.
Here is an IDX from mkvextract:
# VobSub index file, v7 (do not modify this line!)
palette: 000000, 0000ff, 00ff00, ff0000, ffff00, ff00ff, 00ffff, ffffff, 808000, 8080ff, 800080, 80ff80, 008080, ff8080, 555555, aaaaaa
langidx: 0
id: und, index: 0
timestamp: 00:00:10:135, filepos: 000000000
timestamp: 00:00:15:808, filepos: 000001800
timestamp: 00:02:18:889, filepos: 000003000
... and so forth
Problem: There's no end times for subtitle instances.
So, SE did the best it could and made this SRT:
00:00:10,135 --> 00:00:15,808
THE FIFTH ACT
2
00:00:15,808 --> 00:00:23,808
DEMONS
3
00:02:18,889 --> 00:02:21,892
Good day, Mr. Jacobi.
... and so forth
With no end times in the IDX, SE is 'bumping' the subtitles end-to-end, or it's putting up a subtitle for 8 seconds.
The fault is with mkvextract of course, not with SE.
Question 1: Where does the IDX format come from? -- Who can I contact?
Question 2: Is there another IDX format that has end times? -- I could cook up end times if I knew the format.
Question 3: Is there a way to change the 8 second default to 4 seconds?
Thanks again the SE, and thanks for this opportunity to ask,
Mark.
markfilipak is offline   Reply With Quote
Old 17th December 2023, 02:33   #1723  |  Link
markfilipak
Originally Posted by markfilipak View Post
Pre-Script:
https://forum.doom9.org/showthread.p...44#post1995144...
So it appears the problem _may_be_ with SE.
I'm giving SE an '.idx' that contains correct 'start' timestamps, and a '.sub' that contains the images & durations. So, it appears that SE may be misreading the durations or miscalculating the 'end' timestamps that it puts into the '.srt'. What are the odds of either of those, eh?
I'd be ready and willing to help but I can't parse a '.sub' because I don't know the struct. Can you help at that end of this problem?
Best Regards,
Mark.
Old 17th December 2023, 02:55   #1724  |  Link
markfilipak
Hey, I have another question: How can I do the integration of ffprobe/ffmpeg into SE?
They are already in my system. I've been using them for years. My Windows machine is not on the Internet, so downloading them inside SE is not possible. What do I do to achieve the integration?
I have exactly the same issue with MPV.
Thanks,
Mark.
Later: Thanks VoodoFX.
Old 17th December 2023, 18:06   #1725  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Copy it to "Subtitle Edit\ffmpeg" folder, at least that's where it is in the standalone.
VoodooFX is offline   Reply With Quote
Old 20th December 2023, 15:40   #1726  |  Link
Lucius Snow
The XML/PNG export for DCP SMPTE 2014 is full of bugs. Is there any way to fix it?
Lucius Snow is offline   Reply With Quote
Old 20th December 2023, 17:56   #1727  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Yes, describe it there -> https://github.com/SubtitleEdit/subtitleedit/issues
Old 23rd December 2023, 19:22   #1728  |  Link
Zetti
Thanks for new release:
https://github.com/SubtitleEdit/subt...ases/tag/4.0.3
Zetti is offline   Reply With Quote
Old 30th December 2023, 16:02   #1729  |  Link
GCRaistlin
GCRaistlin's Avatar
The topic's name is a little confusing.
Bug: wrong picture is displayed for the character.
Steps to reproduce:
  1. Open .sup file.
  2. In subtitle 4, select the following:
  3. Then select the next letter:
    The picture is obviously wrong (the one for the previously viewed letter).
  4. Click "Add better match" and you'll see the right one:
I can't make SE to recognize these letters correctly at all in nOCR mode: it recognizes them both either as i or as I (or l), depending on what letter I have added last as "better match".
Windows 8.1 x64
Magically yours
Raistlin
GCRaistlin is offline   Reply With Quote
Old 31st December 2023, 18:51   #1730  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
This is not a bug. Ill look at the sup later, most likely the next year.
Old 8th January 2024, 16:25   #1731  |  Link
GCRaistlin
GCRaistlin's Avatar
Originally Posted by VoodooFX View Post
This is not a bug.
Isn't this the actual picture of the recognized letter?
How do I select the audio track in a loaded video file?
Windows 8.1 x64
Magically yours
Raistlin
Old 8th January 2024, 17:44   #1732  |  Link
GCRaistlin
GCRaistlin's Avatar
Audio gets out of sync while playing video file (6 secs) in SE.
Windows 8.1 x64
Magically yours
Raistlin
Old 9th January 2024, 00:07   #1733  |  Link
GCRaistlin
GCRaistlin's Avatar
Feature requests:
  1. Remember last used section (on the left) in Settings.
  2. Waveform/spectrogram | [ ] On double click, correct end if gap is too short.
    Currently, one should choose either to have the ability to fix too small gaps with mouse click or to have the ability to reduce the gap below minimal size using mouse in Waveform.
    With the new option on, double click on subtitle end should correct it if size of the next gap is below "Min. gap between subtitles in ms" value. That is, double click may move subtitle end to the left, never to the right.
Windows 8.1 x64
Magically yours
Raistlin
Old 14th January 2024, 18:54   #1734  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Small tip to MaestroSBT users:
Subtitle Edit seems to export .ass with font size in float.
But good old Maestro SBT does not know about float.
On import of Subtitle Edit .ass Maestro SBT complains:
"No styles were found.
Most likely, this is not a SSA V4 file.
If this is a SSA V2 file, you must open it
with Sub Station Alpha and save it as SSA V4."
.ass import from Aegisub 2.1.8 runs fine though.
Comparison of both scripts led me to assume the solution:
If Subtitle Edit exports .ass with fontsize "32.0", just handedit the ".0" away.
Old 23rd January 2024, 07:05   #1735  |  Link
TDS
Formally known as .......
TDS's Avatar
I have a lot of random problems with Subtitle Edit recognising this symbol, ....it's really "hit & miss", some will be copied, but more often that not, they can be any character it feels like
And its very time consuming manually adding them.
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 24th January 2024, 02:31   #1736  |  Link
Emulgator
Emulgator's Avatar
In case you mean OCR within SE: Which OCR machine do you use ?
If Tesseract, which version ?
Or nOCR ? Binary compare ? Google Cloud Vision API ?
Old 24th January 2024, 03:25   #1737  |  Link
TDS
TDS's Avatar
I think this was directed to me
I generally use the "Default, based on what is available"
I'm using the latest Tesseract, 5.3.3, SE asked for it after install / update.
So like I said, it's random, sometimes it will recognise all of them, and other's not very many at all
But I have had this issue to years, it's just that yesterday I was SE'ing a lot of subs with that music character.
Old 25th January 2024, 13:15   #1738  |  Link
Emulgator
Emulgator's Avatar
I had success once, IIRC with nOCR, and I would suggest to try that.
Old 25th January 2024, 15:04   #1739  |  Link
TDS
TDS's Avatar
I tried pretty much every available setting... didn't seem to make much difference
Thanks anyway.
Old 27th February 2024, 20:38   #1740  |  Link
tormento
Acid fr0g
tormento's Avatar
I have tried to export a sup to png+xml but you need to choose every image position, even if it's embedded in sup itself.
My goal is to divide upper and lower part of png and OCR them separately to deal with upper/lower anime subtitles.
Is possibile in any way to export png+xml having png as 1920x1080 AND proper subtitle positioning?
@turment on Telegram
