16th March 2018, 19:04 | #521 | Link |
make sure all plugins and the used scripts (like SMDegrain that needed with tv_range=true(Default)) are uptodate
See My Avisynth Stuff |
16th March 2018, 19:22 | #522 | Link | |
edit: and I just test this with mpc Code:
SetMemoryMax(1536) SetMTMode(6,16) # changing MT mode ColorBars(width=640, height=480).converttoyv12() RequestLinear(rlim=60,clim=60) # deinterlacing SetMTMode(2) # changing MT mode AssumeTFF() QTGMC(Preset="Placebo", ediThreads=2) SelectEven() distributor() return last but I didn't expected more with something didn't update for years (avs MT), and with these Threads in 32 process! edit2: Code:
SetMemoryMax(1536) SetMTMode(6,4) # changing MT mode ColorBars(width=640, height=480).converttoyv12() RequestLinear(rlim=60,clim=60) # deinterlacing SetMTMode(2) # changing MT mode AssumeTFF() QTGMC(Preset="Placebo", ediThreads=1) SelectEven() distributor()
See My Avisynth Stuff Last edited by real.finder; 16th March 2018 at 19:35. |
16th March 2018, 19:38 | #523 | Link |
Thanks! I totally forgot about that version.
-> That fixed it. Seeing that SD content with Placebo eats around 1.2GB RAM, the mvtools2 crashs might be due to some memory limit when using HD content. I also checked my other tool versions. # MVTools2 (2.7.26 or above) got: 2.7.26.0 # MaskTools2 (v2.2.7 or above) got: 2.2.14.0 # NNEDI3 (0.9.4.6 or above) had: 0.9.4.0, got now: v0.9.4.48 (didn't change color) # RgTools got: 0.96.7 from https://github.com/pinterf/RgTools/releases/tag/0.96 but dll reports 0.96.0 # SMDegrain (3.1.2.91s or above) unless you set tv_range=false got: v3.1.2d from http://www.mediafire.com/file/9kd7d6...n+v.3.1.2d.zip # AnimeIVTC (2.20 or above) if you work with YUY2 source got: v2.20 2017-02-09 mod # NNEDI2, NNEDI, EEDI3, EEDI2, TDeInt - if selected directly or via a source-match preset got: NNEDI2 v1.6.0.0 got: NNEDI v1.3.0.0 got: EEDI2 v0.9.2.0 got: TDeint v1.1.0.0 # yadifmod2 - for Preset="Ultra Fast" or if selected directly got: v0.0.4 from https://github.com/chikuzen/yadifmod.../0.0.4%2F0.0.0 # FFT3DFilter - if selected for noise processing got v2.4.0.0 # dfttest (1.9.4 or above) - if selected for noise processing got: v1.9.4.0 # KNLMeansCL - if selected for noise processing got: v1.1.1 # AddGrainC - if NoiseDeint="Generate" selected for noise bypass got: v1.7.1.0 # chikuzen PlanarTools - if you work with YUY2 source (not necessarily required but may improve speed) got: v0.3.0 => Is there a newer SMDegrain version than 3.1.2d? Where can I find it? I thought https://forum.videohelp.com/threads/...ising-Solution was the 'official' home of SMDegrain,.. Cu Selur Ps.: HD content does work with Placebo and 32bit when limiting the threads to <=4. Last edited by Selur; 16th March 2018 at 19:52. |
16th March 2018, 21:31 | #524 | Link | |
and for mt things, I just note you didn't use SetMTMode(1) with distributor(), and that will make it slower and maybe more ram needed and for most tools and encoders (like x264) they don't even need distributor() in first place (they call it internally) you can see my mod of mpp (mp_pipeline) too, if you still care about non plus avs (as avs mt) but anyway I recommend last avs+, the mt mode in it is more stable and uptodate than avs mt, and it's recommend whether you use mt or not since it less ram usage and faster in most cases and has many new things, and there are 64 avs+ that can use more than 4G of ram without crash and it's faster than 32 in most cases
17th March 2018, 00:02 | #525 | Link |
Thanx Real.Finder, your work is much appreciated, we loves you, thanx.
17th March 2018, 07:50 | #526 | Link | |
What filters/scripts to you use SetMTMode(1) with? I gave up on AVS+ a while ago and switched to Vapoursynth instead. I only use Avisynth mainly for some old filters and update and test it for the Hybrid users. Cu Selur Ps.: Thanks for the link. Last edited by Selur; 17th March 2018 at 08:07. |
17th March 2018, 23:55 | #527 | Link | |
but anyway, mostly internal core filters work with the mode 1, you can see what work with MT_NICE_FILTER in avs+ since they almost same
18th March 2018, 09:05 | #528 | Link | |
18th March 2018, 22:34 | #529 | Link | |
1st May 2018, 16:39 | #530 | Link |
I'm having issues with QTGMC. First, my script:
SetMemoryMax(1000) SetMTMode(5, 0) Import("C:\Program Files (x86)\AviSynth\plugins\QTGMC.avsi") Import("C:\Program Files (x86)\AviSynth\plugins\SMDegrain_v3.1.2.93s.avsi") Import("C:\Program Files (x86)\AviSynth\plugins\LimitedSharpenFaster.avs") LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\masktools2.dll") LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\mvtools2.dll") LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\RgTools.dll") LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\nnedi3.dll") v=LWLibavVideoSource("J:\01-Miami.mkv") #or DSS2 or LSmashVideoSource a=NicAC3Source("J:\01-Miami.ac3") AudioDub(v,a) ConvertToYV12(interlaced=true) Trim(140,47315) AssumeTFF() Spline64Resize(640,480) AddBorders(188, 0, 188, 0, color=$000000) SetMTMode(mode=2) QTGMC(Preset="Slower", SourceMatch=3, Lossless=2, EdiThreads=2) Spline64Resize(1280,720) I have tried this on two different computers (both Windows 10) and using DSS2 and LWLibavVideoSource/LSmashVideoSource with no luck. Any idea what might be causing the crashes and why the pre-rendering job option is the only way it works? Thanks. |
1st May 2018, 16:52 | #531 | Link | |
Like this: Code:
(AVIsource("F:\Temp\TAB_1.avi", audio = false, pixel_type = "YV12") + \ AVIsource("F:\Temp\TAB_2.avi", audio = false, pixel_type = "YV12") + \ AVIsource("F:\Temp\TAB_3.avi", audio = false, pixel_type = "YV12") + \ AVIsource("F:\Temp\TAB_4.avi", audio = false, pixel_type = "YV12")) |
1st May 2018, 16:57 | #532 | Link | |
And the order is not the best, I would not put any resize before QTGMC and would do this ; Code:
(...) AudioDub(v,a) AssumeTFF() Trim(140,47315) ConvertToYV12(interlaced=true) SetMTMode(mode=2) QTGMC(Preset="Slower", SourceMatch=3, Lossless=2, EdiThreads=2) Spline64Resize(960,720) AddBorders(160, 0, 160, 0, color=$000000) |
1st May 2018, 21:46 | #533 | Link |
Well, I'm still just a noob at all this, but I have worked with about a dozen PAL videos now using QTGMC, and this multicore script has always worked well for me. At times it has run for MANY hours de-interlacing PAL video.
LoadPlugin("C:\DGDecNV2053\DGDecodeNV.dll") SetWorkingDir("C:\Program Files (x86)\AviSynth\plugins") SetMTMode(5,6) DGSource("F:\Test Space\Disney Rarities\title00.dgi") SetMTMode(2) QTGMC(FPSDivisor=1,Preset="Placebo",Edithreads=4) Crop(8,2,-8,-2) |
2nd May 2018, 16:29 | #534 | Link | |
If you split an encode into "parts" by adding Trim() to copies of a script, so each copy encodes a different section of the video, you can append the encoded sections with MKVToolNix easily enough, as long as you add --stitchable to the x264 command line. I don't aim for a particular file size or use 2 pass encoding though. If you do then you'd have to eventually encode the entire video as a whole. |
2nd May 2018, 17:19 | #535 | Link |
I think the problem is that you are still using "old" MT implementation + 32 bit version of AviSynth. (2GiB memory limit)
QTGMC works fine in AviSynth+ MT x64.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd May 2018 at 17:23. |
2nd May 2018, 17:58 | #537 | Link | |
I'll give AVS+ a try and see what happens. |
2nd May 2018, 18:39 | #538 | Link |
For best performance limit Prefetch value to number of physical cores.
5th June 2018, 11:14 | #540 | Link |
No.
1. Analysing the interlacing attributes requires a video clip (preferably with steady horizontal motion) of at least a second duration, not just one single frame. 2. Attachments in this forum have to be approved by a moderator which takes time. Better use an external file hoster. Last edited by LigH; 5th June 2018 at 11:17. |
