Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 16th March 2008, 14:54   #1  |  Link
graysky
graysky's Avatar
new HD x264 video encoding benchmark
Techarp is hosting a new HD x264 benchmark. Have a look and run it on your system to help populate the data table.
Basically, you run the test encode of an HD sample (1280x720) and it will report back frames-per-second values for your machine @ it's clock/overclock level. You can run it at your stock settings and at your overclock settings to see how your machine compares to others in the database.
My goal is to have a representative set of data for many different chips and chipsets. Please just report your results here in this thread. I will keep the data at that url to keep things simple.
Thanks all and enjoy!
The following image will be updated automatically as new data comes in. It doesn't display any results, but it does show the number of data points collected so far and how they break down by CPU type:
graysky is offline   Reply With Quote
Old 16th March 2008, 15:11   #2  |  Link
I don't get it. It seems simpler to me if we enter our results directly at the site. Why do you want to be a middleman?
Old 16th March 2008, 16:14   #3  |  Link
graysky
graysky's Avatar
@neuron2 - Please feel free to do so if you have an account on techarp (accounts are free). Some people don't like to register at new places when they already have accounts. By asking peeps to post to the doom9 thread, it just makes it easier for them to post results at all.
I'm not the middleman, I'm the only person compiling the data. The good folks at TA have graciously agreed to host the file and the results.
Old 16th March 2008, 16:27   #4  |  Link
I see. Thank you for your explanation.
Old 16th March 2008, 16:33   #5  |  Link
graysky
graysky's Avatar
@neuron2 - no problem. Thank you for your work with dgindex
Old 18th March 2008, 21:34   #6  |  Link
graysky
graysky's Avatar
...3 days and no one has an interest?
Old 20th March 2008, 03:28   #7  |  Link
Konrad Klar
Konrad Klar's Avatar
---------- RUN1PASS1.LOG
encoded 1442 frames, 32.37 fps, 3905.08 kb/s
---------- RUN2PASS1.LOG
encoded 1442 frames, 32.78 fps, 3905.08 kb/s
---------- RUN3PASS1.LOG
encoded 1442 frames, 32.47 fps, 3905.08 kb/s
---------- RUN4PASS1.LOG
encoded 1442 frames, 32.65 fps, 3905.08 kb/s
---------- RUN1PASS2.LOG
encoded 1442 frames, 8.26 fps, 3942.92 kb/s
---------- RUN2PASS2.LOG
---------- RUN3PASS2.LOG
encoded 1442 frames, 8.29 fps, 3942.92 kb/s
---------- RUN4PASS2.LOG
encoded 1442 frames, 8.28 fps, 3942.92 kb/s
E6600, 9x333, P965, DDR2, 5-5-5-15 @ 416 MHz, Windows 2003 Server Enterprise Edition SP2.
Last edited by Konrad Klar; 20th March 2008 at 14:57. Reason: Corrected typo in timings, 5-5-5-11 was wrong.
Konrad Klar is offline   Reply With Quote
Old 20th March 2008, 13:31   #8  |  Link
lucassp
encoded 1442 frames, 18.54 fps, 3905.08 kb/s
encoded 1442 frames, 19.20 fps, 3905.08 kb/s
encoded 1442 frames, 19.21 fps, 3905.08 kb/s
encoded 1442 frames, 19.13 fps, 3905.08 kb/s
encoded 1442 frames, 4.46 fps, 3942.92 kb/s
TL-58, 9.5x200, RS690M, 2GB DDR2@667 5-5-5-15 2T, Windows XP Pro
lucassp is offline   Reply With Quote
Old 20th March 2008, 15:44   #9  |  Link
Dr.Khron
Dr.Khron's Avatar
Eh, ever since I built the new PC, I've been catching up on all the games from the last two years that my PC was too slow to play... Hell, I havn't even OC'ed the new box yet, havn't needed to.
I'm in the midst of a QuakeWars addiction right now, when it dries up in a few days, I'll give your new benchmark a go. It'll be a good excuse to do some OCing and tweaking. I should be able to get a significant boost out of my machine with the stock cooler.
Dr.Khron is offline   Reply With Quote
Old 20th March 2008, 21:08   #10  |  Link
graysky
graysky's Avatar
thanks for the data, guys. Will update shortly.
Old 30th March 2008, 12:47   #11  |  Link
Southstorm
20yr Videographer
encoded 1442 frames, 12.84 fps, 3905.08 kb/s
encoded 1442 frames, 12.88 fps, 3904.07 kb/s
encoded 1442 frames, 12.89 fps, 3905.08 kb/s
encoded 1442 frames, 3.30 fps, 3941.77 kb/s
encoded 1442 frames, 3.31 fps, 3942.27 kb/s
Prescott 550, 17x200, 915G, DDR, 3-3-3-8 @ 200MHz, XP Home SP2
Southstorm is offline   Reply With Quote
Old 3rd April 2008, 17:22   #12  |  Link
deekey777
encoded 1442 frames, 20.62 fps, 3905.08 kb/s
encoded 1442 frames, 20.77 fps, 3905.08 kb/s
encoded 1442 frames, 20.83 fps, 3905.08 kb/s
encoded 1442 frames, 20.80 fps, 3905.08 kb/s
encoded 1442 frames, 4.67 fps, 3942.92 kb/s
encoded 1442 frames, 4.68 fps, 3942.92 kb/s
A64 X2 3600+ (S939), 10x200, DDR400, WinXP SP2, ASRock 939DUAL-VSTA (ULi 1695)
deekey777 is offline   Reply With Quote
Old 4th April 2008, 09:59   #13  |  Link
graysky
graysky's Avatar
@deekey777- which 3600+ do you have (codename)?
Old 4th April 2008, 11:24   #14  |  Link
deekey777
It's A64 X2 3600+ wit 2x2,0 GHz and 2x256 kB L2 cache for S939.
Codename? Hm, Everest says, it's a Manchester.
Old 4th April 2008, 12:51   #15  |  Link
DD51
CPU Q6600
MB Asus P5K Deluxe P35
9x373
3357MHZ
5-5-5-12 @447Mhz 5:6
Windows XP SP2 x32
encoded 1442 frames, 68.98 fps, 3904.67 kb/s
encoded 1442 frames, 68.77 fps, 3904.67 kb/s
encoded 1442 frames, 69.29 fps, 3904.67 kb/s
encoded 1442 frames, 69.86 fps, 3904.67 kb/s
encoded 1442 frames, 18.93 fps, 3952.97 kb/s
encoded 1442 frames, 18.97 fps, 3952.97 kb/s
encoded 1442 frames, 18.96 fps, 3952.97 kb/s
encoded 1442 frames, 18.95 fps, 3952.97 kb/s
DD51 is offline   Reply With Quote
Old 4th April 2008, 13:14   #16  |  Link
graysky
graysky's Avatar
Cool, can you give me the memory timings and final memory speed?
Old 4th April 2008, 14:16   #17  |  Link
deekey777
Dual DDR400, 200 MHz, 2.5-3-3-7 CR1
Old 4th April 2008, 17:47   #18  |  Link
graysky
graysky's Avatar
Thanks man, will update the table shortly.
@DD51 and southstorm - thanks for the data also
Old 7th April 2008, 12:56   #19  |  Link
breez
encoded 1442 frames, 32.48 fps, 3905.08 kb/s
encoded 1442 frames, 32.74 fps, 3905.08 kb/s
encoded 1442 frames, 32.56 fps, 3905.08 kb/s
encoded 1442 frames, 32.51 fps, 3905.08 kb/s
encoded 1442 frames, 8.23 fps, 3942.92 kb/s
encoded 1442 frames, 8.30 fps, 3942.92 kb/s
encoded 1442 frames, 8.18 fps, 3942.92 kb/s
E4300, 9x333, P35, 4GB DDR2 @ 800MHz 18-5-5-5, Vista x64
breez is offline   Reply With Quote
Old 10th April 2008, 07:48   #20  |  Link
Manao
encoded 1442 frames, 58.67 fps, 3904.94 kb/s
encoded 1442 frames, 58.56 fps, 3904.94 kb/s
encoded 1442 frames, 58.71 fps, 3904.94 kb/s
encoded 1442 frames, 28.74 fps, 3974.08 kb/s
encoded 1442 frames, 28.73 fps, 3974.08 kb/s
encoded 1442 frames, 28.70 fps, 3974.08 kb/s
2 x Xeon E5420 @ 2.5 Ghz, 4GB DDR2 @ 333 MHz 5-5-5-15, Windows 2003 Server
Manao is offline   Reply With Quote
