Old 25th September 2023, 14:00   #721  |  Link
Atlantis
I can't read 720 posts! But it was so easy. You don't need to know anything to do Dolby Vision! Extracted the RPU and added it to an HDR version. Nothing goes wrong with DV!
Atlantis is offline   Reply With Quote
Old 25th September 2023, 17:15   #722  |  Link
von Suppé
von Suppé's Avatar
I'd say much can go wrong with Dolby Vision. I made quite a bunch of mistakes in the beginning. Goes with learning.
Old 25th September 2023, 17:33   #723  |  Link
Atlantis
I mean for us the simple users using the Dolby_Vision_Tool. It's so well written. It proposes all the correct settings by default.
Old 25th September 2023, 19:26   #724  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
I tend to agree with von Suppè, you can easily screw up DV if your RPU isn't synced with your file, e.g. when RPU is from a WEB-DL source and you add it to a Blu-ray, which causes weird flashes; or you can set the L5 wrong which (if your playback device cares for it) crops in too much.
GodzilaAvenger is offline   Reply With Quote
Old 25th September 2023, 19:26   #725  |  Link
Atlantis
I didn't use the DDVT_HYBRID.
Extracted the RPU from DV and added it to an HDR version.
Does DDVT_HYBRID do something more, or using DDVT_DEMUXER and DDVT_INJECTOR is enough?
(I obviously frame check to see that the versions match frame by frame)
Old 25th September 2023, 21:06   #726  |  Link
GodzilaAvenger
As far as I know hybrid is just demuxer and injector rolled into one, for convenience. Demuxes RPU from one file and injects into another.
Old 27th September 2023, 09:02   #727  |  Link
Fuso
Is there a way to implement also DoVi baker, for combining the FEL from P7 with the base HDR?
Fuso is offline   Reply With Quote
Old 27th September 2023, 15:27   #728  |  Link
von Suppé
von Suppé's Avatar
Would you care to explain what "DoVi baker" is? Never heard of the term.
Old 27th September 2023, 16:30   #729  |  Link
dkangel
Originally Posted by -QfG- View Post
Simply for dubbing. I'm from Germany and i must dub sometimes US movies. If i have a German BD with 24 FPS, but the Hybrid stream is 23,976 fps, i change the fps of the stream.
This function is not needed to adjust DV timestamps.
Thank you for your explanation. I understand it's better to change fps of the video without recoding than recoding audio.
dkangel is offline   Reply With Quote
Old 28th September 2023, 00:01   #730  |  Link
GodzilaAvenger
DoViBaker adds the EL information into the BL, essentially turning P7 into P8 without fully discarding the EL. At least that's what I think it does based on its GitHub repo.
Old 5th October 2023, 22:04   #731  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
v0.61 Online!
-v0.61
*Minor Bugfixes
*Some changes in scripts layout
*RENAMED Script Frameinfo.cmd to Fileinfo.cmd
Support for plotting DV / HDR10+ metadata graphs to png picture file.
If u use shell extensions start Options.cmd and reset Shell Extensions!
*Updated mkvtoolnix to v 79.0.0.0.
EDIT v0.61a Online, some bugfixes.
-QfG- is offline   Reply With Quote
Old 6th October 2023, 11:16   #732  |  Link
von Suppé
von Suppé's Avatar
Excellent addition, QfG.
A DoVi power user @ the MakeMKV forums has provided significant information on cases under what conditions certain RPU can or should not not be injected into BD video because of brightness expansion through FEL. Surely there are DoVi (Gung Ho) adventurers here that may appreciate it.
Hopefully you don't mind me putting up the link:
https://docs.google.com/spreadsheets...S74/edit#gid=0
Old 6th October 2023, 21:17   #733  |  Link
dkangel
Thanks for the update but i don't see the hybrid shorcut anymore...
Old 6th October 2023, 21:55   #734  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Hybrid Shortcut works only on background. Don't target a file an click the right button.
Old 6th October 2023, 22:04   #735  |  Link
dkangel
ok thank you
Old 6th October 2023, 22:29   #736  |  Link
dkangel
i have one more question
what would be the easy way to convert a profile 7 to profile 8 ?
Old 6th October 2023, 23:06   #737  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
V0.61.1 Online!
-v0.61.1
*Minor Bugfixes
*ADDED Video Bitrate Plotter in FILEINFO Script.
*ADDED MediaInfo File Writer in FILEINFO Script.
Use <DDVT_DEMUXER> Script if u will demux only the RPU in Profile 8 from Profile 7 Single Layer File
Use <DDVT_HYBRID> Script if you have a target movie. First place your target movie in the first HDR section and the DV P7 Movie in the secondary DV section.
Old 6th October 2023, 23:17   #738  |  Link
dkangel
in fact i would like to convert a profile 7 file to profile 8 to gain space, i don't need the FEL
i will try your solution
thank you
Old 7th October 2023, 08:58   #739  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
P8 is always a DV profile without EL (FEL/MEL) and have only the RPU (Dynamic Metadata).
Old 8th October 2023, 12:41   #740  |  Link
dkangel
yes i understand that.
it seems that a lot of player can't read FEL so profile 8 is enough for me
i have a shield
