#603 | Link |
Broadcast Encoder
Eheheheh you're at Amazon so you literally have everything implemented already. If there's something you don't fall short of is bandwidth in cloud servers scattered across the globe :P
#604 | Link |
Artem S. Tashkinov
An interview with Dr. Dmitriy Vatolin is the Head of the Moscow State University Graphics and Media Lab about video codecs.
#608 | Link | |
Artem S. Tashkinov
Recently I tried to recompress an SD source (interlaced MPEG2 at 10Mbps) using x264, x265 and libaom and x264 came out on top by a wide margin. Both x265 and AV1 simply destroyed the source and even x264 @3Mbps struggled. I didn't venture to go below 3000. H.266 might excel at 4K/8K but for SD/HD x264 is still the king which is really weird considering all the new intra/inter algos in new codecs. |
#609 | Link | |
So to make x265 handling SD resolution well, I use small CTU Code:
--ctu 16 --max-tu-size 16 --qg-size 16 Code:
--ctu 16 --max-tu-size 8 --qg-size 8 raise --qcom from 0.6 to 0.8, 0.9 to improve high motion scene. turn off smooth filter: Code:
--no-sao, --no-strong-intra-smoothing with AV1 encoder, particular aomenc, I can only reduce superblock to 64x64, and AV1 has too many filters which make result too blurry. As I test all AV1 encoders are so terrible at high motion scene. All new codecs love high resolution with big block, by now the block increases to 128x128. Last edited by Dann0245; 8th January 2022 at 11:36. |
#610 | Link |
Pig on the wing
--strong-intra-smoothing is not a smoothing filter. It actually should improve the retention of details.
#611 | Link | |
https://multicorewareinc.com/news/join-us-at-ces-2022/ Because of that, so I think they will talk about their products, also something about x266 I don't know that. I usually disable when encode grain or high bitrate. |
#612 | Link | |
Previously iwod Last edited by ksec; 11th January 2022 at 05:44. |
#613 | Link |
Pig on the wing
The world is moving towards digital media from the old physical media. That's why the development concentrates mainly on creating a watchable low bitrate stream from the source instead of replicating it accurately.
#614 | Link |
Artem S. Tashkinov
No idea what to make of it: https://www.techpowerup.com/290799/a...pool-licensors
18 months after finalizing the codec they are excited about ... licensing. Not adoption, not products, not software ... That sounds almost [don't want to get a ban here]. |
#615 | Link | |
![]() Join Date: Jan 2006
There's no doubt that VVC is technically the best video codec standard available today, by a substantial margin. Licensing problems are the main reasons why it wouldn't be successful. |
#616 | Link |
No doubt MPEG-LA will also have one again, so thats at least two again.
Unless the technical standardization also enforces patent sanity for a future codec, there will never be one single point for this again, its just too much money.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 11th January 2022 at 23:43. |
#618 | Link |
Qualcomm were the main company that prevented a single patent pool on h265, i highly doubt they will join access advance until companies like google pressure qualcomm. Google owns android which is critically important for qualcomm's products. Google could easily force qualcomm to agree with their power over android if they wanted to.
#619 | Link | |
#620 | Link | |
In terms of Smartphone, it is Qualcomm which has the power. You want 4G / 5G along with other Modem technology? You need to deal with Qualcomm no matter what. And I would be surprised if that patent agreement doesn't include video compression, since Qualcomm lumped everything from CPU, power management to other things all in one package anyway. AV1 and VVC will likely live side by side in the future. Since the industry doesn't seems to agree on anything.
Previously iwod |
