13th November 2016, 22:32 | #1 | Link |
SOLVED :) Compiler Bug ??? (VS 2010)
SOLVED Problem disappears with mvtools2 v2.7.1.22.
Hi Guys, having a bit of a problem with below code (VS2010), there dont seem to be similar problem in VS98 or VS2003 ToolKit 3. Produces -1.IND000000000000 condition (but only on very first frame [EDIT: RT_AverageLuma will not access frame -1]). Code producing error is during conversion of __int64 value of 255 to double. Script Code:
FN="LowBitrateAnime.AVI" Avisource(FN) Function StartOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { c thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) I_fv=sup.MAnalyse(isb=false,delta=1,blksize=16,overlap=8) Return c.MSCDetection(I_fv,thSCD1=thSCD1,thSCD2=thSCD2) } SC=StartOfSceneClip SSS=""" n=current_frame f=SC.RT_AverageLuma(n=n,W=1,H=1) # Sample single pixel RT_Subtitle("%d] F=%f",n,f) # Shows '0] F=-1.#IND00' on first frame return last """ Scriptclip(SSS) Code fragment Code:
// Roughly What happens earlier in source // __int64 acc = 0; // unsigned int sum = 0; // sum = sum + 255 // unsigned int Pixels=1; // EDIT: Added // floating point error flags (eg 1.0/3.0 gives _EM_INEXACT) unsigned int e = (_clearfp()); if(e) { dprintf("RT_AverageLuma2: ***ERROR*** E=%X\n",e); } acc += sum; // acc = 255 double dacc = double(acc); // -1.#IND000000000000 ... SHOCK HORROR double result = dacc / Pixels; // e = (_clearfp() & ~_EM_INEXACT); e = (_clearfp()); if(e) { dprintf("RT_AverageLuma3: ***ERROR*** E=$%X dacc=%f($%I64X) Pixels=%d",e,dacc,acc,Pixels); } return result; } Code:
00000006 1.73375964 RT_AverageLuma3: ***ERROR*** E=$10 dacc=-1.#IND00($FF) Pixels=1 Disassembly Code:
// floating point error flags (eg 1.0/3.0 gives _EM_INEXACT) // unsigned int e = (_clearfp() & ~_EM_INEXACT); unsigned int e = (_clearfp()); 04DEBFBA call @ILT+1620(__clearfp) (4DE3659h) 04DEBFBF mov dword ptr [e],eax if(e) { 04DEBFC5 cmp dword ptr [e],0 04DEBFCC je $LN7+183h (4DEBFE2h) dprintf("RT_AverageLuma2: ***ERROR*** E=%X\n",e); 04DEBFCE mov eax,dword ptr [e] 04DEBFD4 push eax 04DEBFD5 push offset string "RT_AverageLuma2: ***ERROR*** E=%"... (4ECF1ACh) 04DEBFDA call dprintf (4DE31DBh) 04DEBFDF add esp,8 } acc += sum; 04DEBFE2 mov eax,dword ptr [sum] 04DEBFE5 xor ecx,ecx 04DEBFE7 add eax,dword ptr [acc] 04DEBFEA adc ecx,dword ptr [ebp-38h] 04DEBFED mov dword ptr [acc],eax 04DEBFF0 mov dword ptr [ebp-38h],ecx double dacc = double(acc); 04DEBFF3 fild qword ptr [acc] 04DEBFF6 fstp qword ptr [dacc] double result = dacc / Pixels; 04DEBFFC mov eax,dword ptr [Pixels] 04DEBFFF mov dword ptr [ebp-1A0h],eax 04DEC005 mov dword ptr [ebp-19Ch],0 04DEC00F fild qword ptr [ebp-1A0h] 04DEC015 fdivr qword ptr [dacc] 04DEC01B fstp qword ptr [result] // e = (_clearfp() & ~_EM_INEXACT); e = (_clearfp()); 04DEC021 call @ILT+1620(__clearfp) (4DE3659h) 04DEC026 mov dword ptr [e],eax if(e) { 04DEC02C cmp dword ptr [e],0 04DEC033 je $LN7+202h (4DEC061h) dprintf("RT_AverageLuma3: ***ERROR*** E=%X dacc=%f($%I64X) Pixels=%d",e,dacc,acc,Pixels); 04DEC035 mov eax,dword ptr [Pixels] 04DEC038 push eax 04DEC039 mov ecx,dword ptr [ebp-38h] 04DEC03C push ecx 04DEC03D mov edx,dword ptr [acc] 04DEC040 push edx 04DEC041 sub esp,8 04DEC044 fld qword ptr [dacc] 04DEC04A fstp qword ptr [esp] 04DEC04D mov eax,dword ptr [e] 04DEC053 push eax 04DEC054 push offset string "RT_AverageLuma3: ***ERROR*** E=%"... (4ECF164h) 04DEC059 call dprintf (4DE31DBh) 04DEC05E add esp,1Ch } return result; 04DEC061 fld qword ptr [result] } Perhaps MvTools2 (v2.5.11.20) problem in trying to access first frame-1 ie frame -1, and somehow propagated into my function ? Any clues anybody ?
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2016 at 02:31. |
13th November 2016, 22:44 | #2 | Link |
Did you compile with "/Od"? "_clearfp()" doesn't work properly if you don't disable compiler optimizations.
Groucho's Avisynth Stuff |
13th November 2016, 22:49 | #3 | Link |
Debug dll compiled with /Od (as above).
EDIT: Exact same results in release with Maximise Speed /O2. EDIT: Also occurs if script line mod Code:
f=SC.RT_AverageLuma # Use current_frame and full frame sample Code:
f=SC.AverageLuma EDIT: Swapping Code:
SC=StartOfSceneClip Code:
SC=Last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th November 2016 at 23:12. |
13th November 2016, 23:56 | #4 | Link |
Its beginning to taste a lot like a problem in MvTool2 v2.5.11.20.
This has a problem at both ends of the clip, Error on SOS (Start of Scene) at frame 0, and at EOS (End Of Scene) on last frame (if you in VDMod jump directly to last frame, And also if you jump to last but one, then step forward to last frame. Strangely not if you jump to last but two and step forward to last frame). Code:
FN="LowBitrateAnime.AVI" Avisource(FN) Function EndOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) I_bv=sup.MAnalyse(isb=true, delta=1,blksize=16,overlap=8) Return c.MSCDetection(I_bv,thSCD1=thSCD1,thSCD2=thSCD2) } Function StartOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) I_fv=sup.MAnalyse(isb=false,delta=1,blksize=16,overlap=8) Return c.MSCDetection(I_fv,thSCD1=thSCD1,thSCD2=thSCD2) } EOS = EndOfSceneClip SOS = StartOfSceneClip SSS=""" e = EOS.RT_AverageLuma(n=current_frame,W=1,H=1) s = SOS.RT_AverageLuma(n=current_frame,W=1,H=1) RT_Subtitle("%d] EOS=%f SOS=%f",current_frame,e,s) return last """ Scriptclip(SSS) on convert to double. EDIT: Problem persists in earlier MvTool2 v2.5.11.2.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2016 at 00:11. |
14th November 2016, 00:18 | #5 | Link |
SOLVED EDIT: MSCDetection from mvtools2 v2.5.11.2 and v2.5.11.20 must cause some kind of Floating point error that is propagated to the next filter using Floating point. Only above 3 versions of mvTools2 tested. EDIT: Wheres the Edit Tags thing gone ? (Wanted to add eg MvTools, MSCDetection, and Floating point error). EDIT: Found it, on last post, not first. EDIT: Also broken in v2.5.11.22. EDIT: V2.6.0.5 unaffected by above problem.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2016 at 03:05. |
14th November 2016, 23:14 | #6 | Link |
Here is small source that demos the problem even using VS6 (Aka VS 98)
#ifdef UNICODE #undef UNICODE // Avoid default wide character stuff #endif #ifdef _UNICODE #undef _UNICODE // Avoid default wide character stuff #endif #ifdef MBCS #undef MBCS #endif #ifdef _MBCS #undef _MBCS #endif #define _CRT_SECURE_NO_WARNINGS #include <windows.h> #include <stdio.h> #include <float.h> #include "avisynth.h" int dprintf(char* fmt, ...) { char printString[2048]="FloatTest: "; // MUST NUL TERM THIS [at some point before vsprintf(p, fmt, argp)] char *p=printString; while(*p++); --p; // @ nul term va_list argp; va_start(argp, fmt); vsprintf(p, fmt, argp); va_end(argp); while(*p++); --p; // @ nul term if(printString == p || p[-1] != '\n') { p[0]='\n'; p[1]='\0'; } // append n/l if not there already OutputDebugString(printString); return int(p-printString); // strlen printString } AVSValue __cdecl FloatTest(AVSValue args, void* user_data, IScriptEnvironment* env) { PClip child = args[0].AsClip(); const bool test = args[1].AsBool(false); // Should we test video frame 0 ? const int n = 0; // test frame 0 only PVideoFrame src; __int64 acc=255; int Pixels=1; double dacc = (double)acc; double result = dacc / Pixels; int e; if(e = _clearfp()) { dprintf("FloatTest1: ***ERROR*** E=$%X dacc=%f($%I64X) Pixels=%d",e,dacc,acc,Pixels); } if(test)src = child->GetFrame(n,env); // Force decoding. MUST assign to PVideoFrame dacc = (double)acc; // Error Here when test==true result = dacc / Pixels; if(e = _clearfp()) { dprintf("FloatTest2: ***ERROR*** E=$%X dacc=%f($%I64X) Pixels=%d",e,dacc,acc,Pixels); } return result; } extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit2(IScriptEnvironment* env) { env->AddFunction("FloatTest","c[test]b", FloatTest, 0); return "`FloatTest' FloatTest plugin"; } Code:
FN="LowBitrateAnime.AVI" Avisource(FN) Function StartOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) I_fv=sup.MAnalyse(isb=false,delta=1,blksize=16,overlap=8) Return c.MSCDetection(I_fv,thSCD1=thSCD1,thSCD2=thSCD2) } SOS = StartOfSceneClip TEST=True SSS=""" s = SOS.FloatTest(Test=TEST) RT_Subtitle("%d] SOS=%f",current_frame,s) return last """ Scriptclip(SSS) EDIT: Made test a bit better, CPP updated. Here debug output Code:
00000003 0.80795121 FloatTest: FloatTest2: ***ERROR*** E=$10 dacc=-1.#IND00($FF) Pixels=1
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2016 at 23:35. |
floating point error, mscdetection, mvtools |
