22nd December 2012, 23:44 | #101 | Link |
This is a BE problem, MPC-HC has its own frame names, GUIDs and everything, MPC-BE just never changed those after forking, so the installer doesn't know any better.
In this case, its the application mutex which is created somewhere.
23rd December 2012, 10:38 | #102 | Link |
Armada, would it be possible to do the new UI with the transparent overlay, similar to what youtube uses, just one form for player bar controls? Then remove the code for old player bars and such. Old MFC forms are bit of a grey area to me so dunno what it can do without skinning.
http://www.youtube.com/watch?v=TEHWDA_6e3M
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 24th December 2012 at 09:03. |
24th December 2012, 09:00 | #103 | Link |
Also about WPF, the UI would need to be redone but WPF can use the old C++ MFC code when placing it to DLL, then gradially move it to WPF when doing bugfixes and when adding new features. I mean if the MFC skinning needs a lot of work, maybe the WPF could be worth considering.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 |
26th December 2012, 16:54 | #104 | Link |
http://forum.doom9.org/showpost.php?...ostcount=13565
Win7 x64 MPC-HC.1.6.6.6391 x86, default setting 1). DI job failed. 2). DXVA mode does not work on NVIDIA cards 3). On AMD/Intel GPUs, there is a green&pink horizontal stripe at the top of the file. |
28th December 2012, 09:53 | #105 | Link |
Broadband Junkie
Ticket #2423 wasn't resolved by the commits last week, so it's in need of someone with necessary permissions to re-open it.
28th December 2012, 17:15 | #107 | Link | |
MPC-HC Helper xD
29th December 2012, 13:37 | #108 | Link |
Uninstall the lastest mpc-hc, an empty MPC-HC folder exists.
http://i.imgur.com/eouO0.png http://i.imgur.com/ILUW2.png http://i.imgur.com/9XdRr.png Download here:http://xhmikosr.1f0.de/mpc-hc/MPC-HC.1.6.6.6419.x86.exe Last edited by wanezhiling; 29th December 2012 at 13:44. |
29th December 2012, 22:33 | #109 | Link |
@Armada
I've figured out what's happening with that crash I reported earlier – where 1.6.5 crashes and 1.6.4 doesn't. If “auto-load audio files” is checked AND I do hasve additional audio files present, 1.6.5 crashes. Uncheck “auto-load audio files” or removing the audio files, the video will play. Why will it play the extra features and not the main movie? Ripped & encoded same time, same software & same settings. What's the difference? Remove the extra audio (which the extra features didn't have in the first place) and it works. Put the audio back & uncheck the auto-load box, it still works. Any recent changes to that code? Of course, neither option is acceptable in my case. Update: A single additional audio file appears to be okay. |
30th December 2012, 11:07 | #111 | Link |
Would anyone know if there's a known bug regarding MP4 audio delay or something which would cause MPC-HC to ignore the audio delay in MP4s?
I've googled and not found anything but it's ignoring MP4 audio delays on two different PCs here. MPC-HC 1.6.5.6366 and XP SP2. I've tried the internal splitter and Haali, the internal audio decoder and ffdshow.... nothing makes a difference. I've no problem with it obeying MKV audio delays (I checked to confirm) and if it was ignoring AVI audio delays I'd probably have noticed by now. MPC-BE ignores the MP4 audio delay also. VLC doesn't, so I assume the MP4 files I'm checking aren't the problem. MediaInfo displays the correct delay only MPC-HC won't use it. Thanks. |
30th December 2012, 12:53 | #112 | Link | |
I have tried the built-in h264 decoder, mkv splitter, lav splitter, lav video filters (dxva2 native). Are you sure that the file has a h264 video stream which is dxva complient?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
30th December 2012, 18:08 | #113 | Link |
Test with these versions:
http://xhmikosr.1f0.de/mpc-hc/old/1.6.4/
MPC-HC 2.2.1 |
30th December 2012, 19:53 | #114 | Link |
I've tried versions 1.6.4.5823 and 1.6.1.4235, and as per my post #111, neither of them seem to pay any attention to the audio delay in MP4s. MKVs and AVIs are fine, but even though MediaInfo shows the MP4 audio delay, MPC-HC seems to ignore it.
30th December 2012, 20:18 | #115 | Link |
Yes file is dxva compliant, 1024x576 23.976 encoded with x264 --preset faster. MPC video decoder says 'H.264 E. bitstream decoder, no FGT' when it's working.
Build 6187 is the last one that works with both decoders, 6202 doesn't. What video card in your laptop? Last edited by turbojet; 30th December 2012 at 20:21. |
30th December 2012, 23:52 | #116 | Link |
You need to enable the internal subtitle renderer in combination with a compatible video renderer. Or block DirectVobSub (= VSFilter) in the external filters list. DirectVobSub is not compatible with DXVA.
It worked with older versions despite your incorrect settings because there used to be a bug that prevented DirectVobSub from loading automatically.
MPC-HC 2.2.1 |
31st December 2012, 07:17 | #117 | Link |
Thanks for the reply, vsfilter isn't installed but you were on the right track. ffdshow video decoder needs to be blocked, is this really intended? There's still many useful things ffdshow can do that nothing else can, mainly avisynth. Disabling all subtitle options in ffdshow didn't help.
31st December 2012, 08:07 | #118 | Link | |
@turbojet
http://forum.doom9.org/showthread.ph...34#post1607334 Quote:
31st December 2012, 19:08 | #120 | Link |
What are pro's and con's on 32 bit and 64 bit versions?
Could not find any info at http://mpc-hc.sourceforge.net/ and the FAQ is blank. I just like using MPC because it can play back everything without installing codecs. |
dxva, media player classic, mpc, mpc-hc |
