Old 3rd September 2021, 05:41   #101  |  Link
poisondeathray
Originally Posted by Myrsloik View Post
Yes, now alt_output is an optional argument to set_output(). Makes more sense that way.
It "works" , but same problems as last version ie. wrong fourcc for UYVY, avfs crashes
Originally Posted by poisondeathray View Post
But with Core R55, ffmpeg still reports Y42B, yuv422p for the yuv422 alt2 script .
Also, avfs now crashes when file is accessed, even a plain BlankClip script (without alt_output options) . It "mounts", but as soon as you touch or access the fake avi, it crashes no helpful error message
Calling old avfs with same plain BlankClip script does not crash
Old 4th September 2021, 12:12   #102  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
RC3 posted. Fixes the reported deadlock and avfs crashes on vpy script access (really tested this time).
Myrsloik is online now   Reply With Quote
Old 4th September 2021, 18:47   #103  |  Link
poisondeathray
avfs and alt_output issues fixed, thanks
Question about vspipe and alt_output - Does the alt_output fourcc emulation only work with avfs ? ffmpeg reports different fourcc with vspipe input using y4m headers (-c y4m), using same script that worked with avfs.
eg.
vspipe -c y4m yuv422_alt2.vpy - | ffmpeg -f yuv4mpegpipe -i - -an -f null NUL
reports Y42B, yuv422p instead of the expected UYVY, uyvy422
But,
avfs yuv422_alt2.vpy
reports the expected UYVY (and it works ok in programs like Premiere, gets YUV treatment, passthough)
(I don't think it matters that much, the alt_output /fourcc probably only be used for avfs - it's just a curiosity question)
Old 4th September 2021, 18:59   #104  |  Link
Myrsloik
Myrsloik's Avatar
eg.
But,
You're probably a bit format confused. Y4M is a super basic "container" that only allows planar yuv. Nothing else. It doesn't have the concept of fourcc or packed formats. That's why alt_output does nothing outside of avfs and vfw.
BUT for some reason FFmpeg decides to print out Y42B since that fourcc is effectively the same storage format as Y4M with the supplied headers. Pure coincidence.
Old 4th September 2021, 19:10   #105  |  Link
poisondeathray
So vspipe rawvideo would not act any differently either ?
Old 4th September 2021, 19:11   #106  |  Link
Myrsloik
Myrsloik's Avatar
Correct, there's no reason to. Everything that supports pipe input can accept pure planar nowadays.
Old 4th September 2021, 19:13   #107  |  Link
poisondeathray
Thanks
Old 6th September 2021, 01:04   #108  |  Link
Yomiko
It seems the VideoOutputTuple confuses existing python scripts that read vpy using runpy. For a video clip, in script.vpy
clip.set_output(2)
In python that handles both old and new api
runpy.run_path(script.vpy, dict(), '__vapoursynth__')
try:
    clip = vs.get_output(2)[0]
except TypeError:
vspreview may be modified to treat it as a tuple. Meanwhile in vseditor I don't see anything different from before.
May I know whether there will be further changes for this, like, backward compatibility for python or more breaking changes for vsscript?
Yomiko is offline   Reply With Quote
Old 6th September 2021, 09:08   #109  |  Link
Myrsloik
Myrsloik's Avatar
clip.set_output(2)
try:
except TypeError:
I think I'm done with all breaking changes now unless someone discovers something really broken.
I thought about adding an AudioOutputTuple but couldn't think of any additional information that'd be useful.
Old 7th September 2021, 05:32   #110  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Was the support for this old non-recommended style now removed? There are several utility scripts and tools like muvsfunc, mvsfunc and Zopti which use that and need some fixing.
import vapoursynth as vs
core = vs.core
Old 7th September 2021, 08:52   #111  |  Link
Myrsloik
Myrsloik's Avatar
core = vs.core
Uh no? core=vs.core should work
I only removed vs.get_core()
Old 7th September 2021, 09:12   #112  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Ah, I prolly looked too quickly and confused the two. The latter one is most likely still in use in a lot of older scripts but fortunately trivial to fix.
Old 8th September 2021, 04:59   #113  |  Link
lansing
I ran into problem calling freeScript() in vsedit2. It kept crashing the program. Then I make a simple test with one button calling createScript() and one button calling freeScript():
VSScript * testVSScriptEnv;
void testCreateScript()
    if(testVSScriptEnv == nullptr)
        testVSScriptEnv = VSScriptAPI->createScript(nullptr);
void testFreeScript()
    if (testVSScriptEnv) {
        VSScriptAPI->freeScript(testVSScriptEnv);
If I go createScript -> freeScript -> createScript -> freeScript, the program will crash.
Old 8th September 2021, 12:35   #114  |  Link
Myrsloik
Myrsloik's Avatar
Can't reproduce
Old 8th September 2021, 12:41   #115  |  Link
lansing
Can't reproduce
I forgot the "testVSScriptEnv =" line in the above post, can you test again?
Old 8th September 2021, 12:45   #116  |  Link
Myrsloik
Myrsloik's Avatar
Obviously I adjusted it for those things. Still worked.
Old 9th September 2021, 00:35   #117  |  Link
lansing
I found my problem. I was trying to reuse the temporary node reference. I passed it into a function, and then freed the node inside the function. And then when I free the environment, it will crash.
VSNode * pProcessingNode = m_cpVSAPI->addNodeRef(pOutputNode);
pProcessingNode = resizePlugin(pProcessingNode);
pProcessingNode = otherPlugin(pProcessingNode);
VSNode * resizePlugin (VSNode * a_pVideoNode) {
    m_cpVSAPI->mapSetNode(pArgumentMap, "clip", a_pVideoNode, maReplace);
    VSMap * pResultMap = m_cpVSAPI->invoke(pResizePlugin, "Point", pArgumentMap);
    VSNode * pResultNode = m_cpVSAPI->mapGetNode(pResultMap, "clip", 0, nullptr);
    m_cpVSAPI->freeNode(a_pVideoNode);
    return pResultNode;
What is the correct way to do this?
Old 9th September 2021, 09:51   #118  |  Link
Myrsloik
Myrsloik's Avatar
    VSMap *pArgumentMap = m_cpVSAPI->createMap();
    m_cpVSAPI->mapConsumeNode(pArgumentMap, "clip", a_pVideoNode, maReplace);
    m_cpVSAPI->freeMap(pArgumentMap);
    // use mapGetError(pResultMap) here if you need to check for errors
    m_cpVSAPI->freeMap(pResultMap);
    return pResultNode;
At the end you have pProcessingNode and pOutputNode that needs to be freed.
Old 9th September 2021, 15:49   #119  |  Link
lansing
Thanks I got it working.
Old 10th September 2021, 00:29   #120  |  Link
_Al_
All working here so far, this is nice.
Also attempt to drag audio along with video, here in vapoursynth attaching audio to video frames using props.
But the code below does not work because ModifyFrame does not work with anode. vnode only. ModifyFrame (or FrameEval) is planned in future or is it a bad idea?
oh I see, n is not the same for vnode as is for anode, this could not work, only if bunch of anode frames (perhaps list) is attached to vnode and then reconstructed again, no idea how anisynth does it,
also deleting previous code to not confuse anyone
_Al_ is online now   Reply With Quote
