Old 26th August 2021, 23:13   #81  |  Link
lansing
How do I get a map of functions from a plugin in api4?
VSMap * FunctionsMap = VSAPI->getFunctions(Plugin);
Old 26th August 2021, 23:51   #82  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Use getNextPluginFunction(plugin, nullptr)
Then pass the returned pointer to the function until it returns null. That means you've enumerated all plugins.
Myrsloik is online now   Reply With Quote
Old 27th August 2021, 00:22   #83  |  Link
lansing
Like this? Do I need to free the function every loop before getting a new one?
VSPluginFunction * function = VSAPI->getNextPluginFunction(nullptr, Plugin);
while (function != nullptr) {
    # do stuff with function
Old 27th August 2021, 00:51   #84  |  Link
Myrsloik
Myrsloik's Avatar
Correct, you don't have to free anything.
Old 27th August 2021, 07:17   #85  |  Link
lansing
What does the argument string returned by "vsapi->getPluginFunctionArguments(function)" look like? I didn't see any example in the api
Old 27th August 2021, 20:27   #86  |  Link
lansing
How do I get the videoFormat name and uses it in one line like in api3?
myFunction(videoInfo->format.name);
Old 27th August 2021, 20:55   #87  |  Link
Myrsloik
Myrsloik's Avatar
One line?
char name[32]; vsapi->getVideoFormatName(&videoInfo.format, name); myFunction(name);
But more seriously, use a lambda or something if you need it many times in the same function.
Old 27th August 2021, 21:21   #88  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by _Al_ View Post
Using that latest API4 R 55 portable RC1 version with latest portable python 3.9 on windows 7, running VSPipe.exe I get:
The program can't start because api-ms-win-core-path-|1-1-0.dll is missing from computer. Try reinstalling the program to fix this problem.
What do i have outdated? Older R51 portable is working.
Do I need Visual Studio 2019 for portable setup?
Install the most recent vs2019 runtime manually.
Old 27th August 2021, 22:03   #89  |  Link
lansing
One line?
This is another use case in api3:
infoString.replace("%format%", videoInfo->format.name);
Old 28th August 2021, 05:05   #90  |  Link
Yomiko
core.add_cache is removed (although remains in the doc). May I know about a replacement for it?
Yomiko is online now   Reply With Quote
Old 28th August 2021, 10:26   #91  |  Link
Myrsloik
Myrsloik's Avatar
Cache insertion is now handled by the core so there's no direct replacement. If you want to change the automatic decision to add a lot of caching on your output simply use the SeVideoCache/SetAudioCache functions.
Old 28th August 2021, 11:47   #92  |  Link
Yomiko
Thanks. Also I see all the arguments are required in these functions. Is it as intended?
Old 28th August 2021, 12:02   #93  |  Link
Myrsloik
Myrsloik's Avatar
No, they should obviously be optional
Old 30th August 2021, 03:40   #94  |  Link
Yomiko
>>> import vapoursynth as vs
>>> core = vs.core
>>> clip = core.std.BlankClip(width=1921, height=1081, format=vs.RGB48)
>>> frame = clip.get_frame(2)
>>> frame[0] == frame[2]
True
>>> frame[0] == frame[1]
True
>>> frame = clip.get_frame(22)
>>> frame[0]
<memory at 0x0000021EE196B930>
>>> frame[1]
<memory at 0x0000021EE196B860>
>>> frame[2]
Is it as intended in R55-RC1?
Old 30th August 2021, 07:19   #95  |  Link
Myrsloik
Myrsloik's Avatar
>>> core = vs.core
True
True
>>> frame[0]
>>> frame[1]
>>> frame[2]
Yes, it's how you access plane data now
Old 2nd September 2021, 10:09   #96  |  Link
Myrsloik
Myrsloik's Avatar
RC2 posted. Changes:
  • Reworked vsscript api to restore api3 functionality
  • AVFS fixes (packed RGB in Avisynth scripts)
  • Uses new and faster libp2p for packing
  • Removed lots of Python functions that have been deprecated since at least R51
  • API4 headers actually included in installer
Things you can do to help:
  • Update the __all__ tag in vapoursynth.pyx with all relevant symbols
  • Create vsscript4.h.rst and vshelper4.h.rst (these are simple and work 99% like the api3 counterparts)
  • Review pythonreference.rst (mostly updated by me already but probably missing some functions)
  • Review all other documentation.
Old 2nd September 2021, 15:57   #97  |  Link
lansing
The VSVideoFormat argument of isSameVideoPresetFormat() is missing the "constant" declaration?
Old 2nd September 2021, 17:50   #98  |  Link
Myrsloik
Myrsloik's Avatar
Correct. Will be fixed.
Old 2nd September 2021, 20:45   #99  |  Link
poisondeathray
was the vs.set_option('alt_output', X) removed from RC2 ?
Old 2nd September 2021, 21:05   #100  |  Link
Myrsloik
Myrsloik's Avatar
Yes, now alt_output is an optional argument to set_output(). Makes more sense that way.
