#1 | Link |
Retired, but still around
A real CCE SpeedTest
The point of this exercise is to create meaningful comparisons of CCE encoding speeds. Many of us are tired of the nonsense posts and waste of bandwidth. Although this test is primitive and will reflect a speed much slower than you will actually get using proper source, it should allow an exact comparison of speed on various platforms. In other words, two machines of the exact same configuration should return identical results.
This assumes I have thought it out correctly and did not screw up ![]() Instructions (follow exactly): 1> Create directory on your HD as "CCESpeedTest01" 2> Copy and paste AVS file below into notepad. Save into the above directory as "CCESpeedTest01.avs" 3> Copy and paste the two ECL files into notepad one at a time. Save each as "CCESpeedTest01_CCE2.5.ecl" and "CCESpeedTest01_CCE267.ecl" 4> Edit the ecl files using the replace function of notepad. Search and replace "G:\" to the HD drive letter where you created the dir in step 1 above. 5> Run CCE and load the appropriate ECL file. Make NO changes. Press encode and note the speed after exactly 3 minutes of encoding. 6> Report that speed along with the information on your machine. Code:
#start of CCESpeedTest01.avs ColorBars (720,480) ShowSMPTE(24) converttoyuy2() #end Code:
; Cinema Craft Encoder SP -- Encoder Control List [item] title=CCESpeedTest01.avs vid_out=1 vaf_out=0 aud_out=0 vid_file0=G:\CCESpeedTest01\CCESpeedTest01_CCE2.5.mpv vid_file1= vaf_file= aud_file= file_focused=0 encode_mode=0 packet_size=4096 timecode=0x1000000 width=720 height=480 vmode=0 frame_rate_idx=4 cbr_brate=6000 opv_q_factor=32 opv_brate_min=300 opv_brate_max=8000 vbr_brate_avg=2257 vbr_brate_min=1194 vbr_brate_max=2565 vbr_bias=30 vbr_pass=3 quality_prec=17 use_filter=0 filter_val=6 seq_endcode=1 dvd=0 half_width=0 half_height=0 fast_mode=0 progressive=1 alternate_scan=0 non_linear=1 top_first=0 lum_level=1 intra_dc_prec=-1 aspect_ratio=2 gop_m=3 gop_nm=5 gop_hdr=15 seq_hdr=1 all_closed_gop=0 fix_gop_length=0 mpeg1=0 mpeg1_cps=0 samples_per_sec=48000 stereo=2 brate_idx=7 crc=1 [file] name=G:\CCESpeedTest01\CCESpeedTest01.avs type=0 frame_first=0 frame_last=107892 encode_first=0 encode_last=107892 Code:
; CCE SP Trial Version -- Encoder Control List [item] title=CCESpeedTest01.avs vid_out=1 vaf_out=0 aud_out=0 aud_mode=0 vid_file0=G:\CCESpeedTest01\CCESpeedTest01_CCE267.mpv vid_file1= vaf_file= aud_file= file_focused=0 video_type=2 width=720 height=480 timecode=0x1000000 tc_ref_frm=0 drop_frame=0 cbr_brate=6000 opv_q_factor=32 opv_brate_min=300 opv_brate_max=8000 vbr_brate_avg=2230 vbr_brate_min=300 vbr_brate_max=2530 vbr_bias=30 vbr_pass=3 create_new_vaf=0 pulldown_detect=0 letter_box=0 panscan=0 aspect_ratio=2 credits_tweak=0 credits_start=0x00000 credits_brate=1000 h_filter=0 h_filter_idx=8 use_filter=0 filter_val=4 dither=0 dither_max=8 quality_prec=25 intra_dc_prec=2 alternate_scan=0 non_linear=1 progressive=1 gop_m=3 gop_nm=5 gop_hdr=15 seq_hdr=1 seq_endcode=1 dvd=0 all_closed_gop=0 fix_gop_length=0 fix_vbv_delay=0 offset_line=0 half_width=0 half_height=0 uscc=0 lum_level=1 packet_size=2048 frame_rate_idx=4 qmat_idx=0 mpeg1=0 mpeg1_cps=1 brate_idx=7 stereo=2 samples_per_sec=48000 crc=1 [file] name=G:\CCESpeedTest01\CCESpeedTest01.avs type=0 frame_first=0 frame_last=107892 encode_first=0 encode_last=107892
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 4th December 2003 at 14:31. |
#2 | Link |
My tests:
CCE 2.5x 1.50 CCE 2.67 1.41 [Edited - Better speed after reboot] Biostar M7NCDP | XP1700 (AXDA1700DUT3C - JIUHB 0312VPMW) @2.1 Ghz (11*192) VCore 1.70 v - SiSoft PR 3064 (Est.)| GFrce 2 MX400 | 4 Maxtor 40g| Zlmn Flower w/ 120 fan @ 2000 rpm| Enermax 330 watt r82 tweak | (2) 256 meg PC3500 HYP_X (7-2-2-2 VDim 2.8 v| Enermax CS 307 Case
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 4th December 2003 at 18:15. |
#3 | Link |
I'm getting the following error:
D:\CCESpeedTest01\CCESpeedTest01_CCE2.5.ecl is not a ECL for Cinema Craft Encoder SP." I'm getting the same with CCESpeedTest01_CCE267.ecl file!!
AMD Athlon 64 3200+,Asus K8N,2x256Mb Kingston CL2.5(Winbond) PC3200 DDR,ASUS ÁX800 XT Platinum Edition ,17" LCD Sony SDM-HS74P/B ,Plextor DVD+R PX-716A ,Pioneer DVD-121,80Gb WD Caviar WB800JB , 120Gb WD Caviar WB1200JD SATA ,Creative Inspire 5500 Digital 5.1,Thermaltake Tsunami Case,Antec TruePower 430W,Zalman 7000B-Cu,Arctic Cooling ATI Silencer 4 Last edited by KeyserSoze; 4th December 2003 at 03:03. |
#4 | Link |
Sure thought they should load OK, crap. Well just set either of them up for One Pass VBR Q32 Min 300 Max 8000 and no VAF creation. Set Zigzag and Progressive on. No internal filters engaged of any kind. Make sure DVD compliant is not on. That should work, but without loading the ECL's we can't consider it apples to apples.
What exact version/s of CCE are you trying to use? Has anybody else got them to work ok?
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 4th December 2003 at 04:32. |
#5 | Link |
Hi DDogg,
I really appreciate your work ![]() ![]() ; Cinema Craft Encoder SP -- Encoder Control List My result is: CCE 2.5x 0.391 I´ll post my configuration later because I´m at work and I have to check what hardware I really use here, hehe. ***EDITED Asus CUSL2-M, PIII 866, 512 MB SDRAM, Ati Rage XL AGP,1x IBM 60 GB, 1x IBM 75 GB, Toshiba SD-M1502 ***EDITED Last edited by coona; 4th December 2003 at 09:11. |
#6 | Link |
jarvis1781, did you use the ECL above? That speed surprised me.
How to Optimize Bitrate for CCE multipass |
#7 | Link |
2.67.00.10---->1.42
2.50.01.00---->1.514 XP2400+ at 2000Mhz(12x166,harmless o/c ![]() CCE 2.67 is ofcourse optimised for P4 CPUs, and CCE 2.5 for Athlons . (no background apps this time)
AMD Athlon 64 3200+,Asus K8N,2x256Mb Kingston CL2.5(Winbond) PC3200 DDR,ASUS ÁX800 XT Platinum Edition ,17" LCD Sony SDM-HS74P/B ,Plextor DVD+R PX-716A ,Pioneer DVD-121,80Gb WD Caviar WB800JB , 120Gb WD Caviar WB1200JD SATA ,Creative Inspire 5500 Digital 5.1,Thermaltake Tsunami Case,Antec TruePower 430W,Zalman 7000B-Cu,Arctic Cooling ATI Silencer 4 Last edited by KeyserSoze; 4th December 2003 at 15:33. |
#8 | Link |
KeyserSoze, were you able/how did you get the ecls to load? Note your speed and mine are nearly exact, so we can see the benchmark works and returns similar results on like machines.
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 4th December 2003 at 18:20. |
#9 | Link | |
#10 | Link | |
Those didn't work in CCE2.5 but worked in 2.67(EclCCE). Now everything is ok on both scripts. I just followed coona's advice ![]()
AMD Athlon 64 3200+,Asus K8N,2x256Mb Kingston CL2.5(Winbond) PC3200 DDR,ASUS ÁX800 XT Platinum Edition ,17" LCD Sony SDM-HS74P/B ,Plextor DVD+R PX-716A ,Pioneer DVD-121,80Gb WD Caviar WB800JB , 120Gb WD Caviar WB1200JD SATA ,Creative Inspire 5500 Digital 5.1,Thermaltake Tsunami Case,Antec TruePower 430W,Zalman 7000B-Cu,Arctic Cooling ATI Silencer 4 Last edited by KeyserSoze; 5th December 2003 at 18:40. |
#11 | Link |
OK, thanks. As you noticed I edited out those extra lines in the ECLs above. Now everybody should be able to just copy and paste them into notepad and save them. The only edit needed is to change "g:\" to the drive they use.
The benchmark seems to work well now. Let's see some more testing results, people! ![]()
#13 | Link |
chipvideo, the data we are interested in was what speed you obtained. Once we get enough of that data we can then develop a factor to convert the result to one that more closely indicates real world encoding. Keep in mind that this method removes avisynth and mpeg2decX from the equation, as well as resolution/aspect ratio.
In your case, this shows CCEs processor usage alone. It may be that jarvis1781's single processor machine will actually encode faster than yours. If so, that is useful data to know (although not something you may particularly appreciate ![]()
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 5th December 2003 at 18:33. |
#14 | Link |
Well I doubt that he can encode 70% faster than my machine. He would have to encode a dvd with bicubic resize at around RT5.3 on Titanic.
I know that your machine isnt the same speed as mine for encoding. I have my procs OC'd to 2400mhz each. LIke I said this test shows CCE using only 58% processor while using the real method shows a CCE using 72%. That is all I am saying. Based on this test one would assume that a dual processor system is a waste and doesnt perform any better than a single one when in fact a dual system enocdes much faster. |
#15 | Link | |
That's interesting, but as before we don't have your speed on this test so as to put it into perspective.
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 5th December 2003 at 20:16. |
#16 | Link |
My speed was 1.51 using your test. If cce didnt utilize the both processors then I would get a max of 50% on cce. I get 58% with cce using your test and 72% when using the dvd2dvd method.
His single processor is not beating my dual encodes by 70% encoding a dvd material. You must be crazy to think that your system is as fast as mine as well. But it isn't. I think a better way to figure this out would be for a few of us to use the dvd2dvd method and use the same settings. Bicubic resize and use ntsc source. Maybe we could make a list of some movies that people have and then see if we can get some results. I have Titanic, Saving Private Ryan and that other hanks movie on the Island. Those are good movies as they are long ones and would show that true power of the system. I mean I get 3.3RT with Titanic. I highly doubt your processor running at much lower than mine is goign to do as well. I know this is a early stage test and I am glad your willing to take the time, but we need to get more realife results. |
#17 | Link |
I feel compelled to comment, as I've spent a fair amount of time thinking about multiprocessor (MP) systems.
This test isn't just testing CCE encoding speed, it's also testing the speed of AviSynth. On a single processor system, the script might be using something like 86% of processor cycles, leaving the other 14% for CCE. On a dual processor system, all of one processor (100%) can be dedicated to the script. All of the left over processor could be dedicated to CCE, but the script is only capable of delivering data so fast, so CCE only ends up using 16%. The apparent result is a 15% increase in CCE encoding speed, but the test is somewhat biased by a slow script. With a more efficient script, the ratios are completely different, and tend more and more in MP's favor. Just a point of clarification, CCE is MP enabled. The reason you don't see 100% processor usage is that AviSynth is not MP enabled. A more fair test of CCE sans frame server might be to use the script to create a Huffy (or raw) avi file, then encode from that. That would really show off the advantages of MP systems. Unfortunately that is misrepresentative of what you're really trying to test (frame server+encoder performance) in the other direction. BTW: why is that script so slow? I wouldn't think ColorBars or ShowSMPTE would slow the script down so much. Last edited by Kedirekin; 5th December 2003 at 22:26. |
#18 | Link | ||
![]() This is only the first stage of that process. Typically I normally have a bit of method in my madness. Over the years I've found that the only way to accomplish something on this board is to cause a challenge scenario. It is just the way people are. Its neither good nor bad, it just is. ![]() Perhaps you and/or Kedirekin can make a major contribution so we can actually have an intelligent method of reportage instead of the silliness of "WoW, bubba, I got 9 x realtime!!!! er, 'course that was 160x120 resolution, but who cares cause 9x makes me feel like I have a big Johnson ![]() I think you are completely correct about this particular test as it not only concerns multi processors, but the general full process itself. I would wholeheartedly concur with a more proper method as you suggested that uses real source. When I have suggested something similar (repeatedly over the years) the response has been underwhelming. As said, this is the first stage, and it does supply a legitimate method of comparing [single ![]() Now we just need to work together and come up with the next iterations. However, that method must be transparent to NTSC and Pal, else it is a waste of time. Nobody wants a dual benchmark, IMO. This gets us into a easily downloadable common source and the required bandwidth which has always been one of the hangups. So, you want to help or just bitch at me? ![]() So now Quote:
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 5th December 2003 at 23:25. |
#19 | Link |
Actually I think your proposed test is perfectly valid for SP systems. I wasn't trying to denigrate it. It may not represent real-world performance, but as an apples-to-apples test is should be accurate. As you said, the relative performance differences should track into real-world circumstances.
It's probably valid for MP systems as well, but only for comparing to other MP systems. Unfortunately things break down when trying to compare SP and MP systems, and it isn't really the fault of the test; the breakdown is present in real-world situations as well. For example, your MP setup could encode one project 40% faster than a comparable SP system, and the next project might only be 10% faster. Taking that into account, I don't think it is possible to create a test that will ever allow apples-to-apples comparisons between SP and MP systems. It's kind-of sad really - if everything were MP enabled, the MP system would always be 85-95% faster than the comparable SP system. BTW: chipvideo, if you want to see how much added oomph your MP system gives you, try setting your CCE processor affinity to only use one processor. Last edited by Kedirekin; 5th December 2003 at 23:45. |
#20 | Link |
When we get more data, that is, when we can get a few more people to get motivated, run the test and report the results, we can then pick a few folks to also run an encode on a common DVD source. [Hey, it only takes five minutes!]
That data should establish the proportion of this artificial benchmark to a real world encoding job. Ultimately I think (hope) we can end up with a multiplier to apply against the benchmark number that will yield a close approximation to real world speed using the common encoding method of mpeg2dec3/avisynth. Hopefully that would also use, as part of the factor, the amount of pixels to be encoded so we can take into account aspect ratio/res. I'm still fuzzy on that. Most folks know I am a math dropout. There is something else tickling the back of my brain but I can't get a handle on it yet ![]()
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 6th December 2003 at 01:21. |
