Thread Tools Display Modes
Old 24th January 2025, 23:54   #1  |  Link
jay123210599
Vapoursynth: Remove Frames to Sync Videos
I have 5 videos I want to make a comparison with, but they're out of sync. How do I remove the right amount of frames from each video until they're in sync?
jay123210599 is offline   Reply With Quote
Old 25th January 2025, 10:05   #2  |  Link
Selur
Selur's Avatar
Easy solution: Use an NLE tool and not Vapoursynth/Vapoursynth. (NLEs are meant to deal with multiple audio & video tracks and their alignment)
With Vapoursynth: Figure out which frames you want to remove, then remove the frames by splitting (using trim) and re-combine your sources.
Since you already have 300+ post you should have a basic understanding of using Vapoursynth and using trim to archive what you want should be easy (and a lot of manual work).
Something like https://github.com/k-aito/vapoursynt...atching-frames might help with figuring out which frames you want to remove.
Doing this for a small clip might be feasible, for larger projects probably not, that is what NLEs are for.
Hybrid here in the forum, homepage, its own forum
Old 25th January 2025, 18:25   #3  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Over in AviSynthland ;-)
https://forum.doom9.org/showthread.p...89#post2013689
Old 26th January 2025, 00:11   #4  |  Link
jay123210599
What are some NLE tools? Do some for Vapoursynth exist?
Old 26th January 2025, 07:18   #5  |  Link
Selur
Selur's Avatar
https://letmegooglethat.com/?q=What+...e+NLE+tools%3F
I know of no NLE which uses Vapourynth some might be able to open Vapoursynth scripts as source using AVFS (AV FileSystem), but in general intermediate files would be needed when aiming to combine an NLE with Vapoursynth.
Cu Selur
frame accurate, remove frames, vapoursynth, video comparison
Thread Tools
