Thread Tools Display Modes
Old 11th March 2020, 12:24   #1  |  Link
color
color's Avatar
Drop/Remove Frames
I am going crazy here, math is not my strongest side, so If someone can help me. I got a movie that dublicates (wrong frames) the hole movie (25 fps). So I need to drop frames/remove this frames. I don't know how to figure out the first frame that needs to be deleted, but when looking a bit in the movie, I get that this frames between 2518-2550 this must be removed:
2518
2520
2523
2525
2543
2545
2548
2550
Automatic Colorization
Last edited by color; 11th March 2020 at 13:03. Reason: my keyboard did press the "v"-keyboard, it does this sometimes. Don't know why.
color is offline   Reply With Quote
Old 11th March 2020, 13:18   #2  |  Link
DJATOM
DJATOM's Avatar
Probably not so optimal solution, but assuming pattern doesn't changes the whole movie (python code below)
int(2518/25) = 100
100*25 = 2500
frames="""2518
2520
2523
2525
2543
2545
2548
2550"""
frames=frames.split('\n')
frames2=[int(i)-2500 for i in frames]
"""frames2 will have initial section, which is"""
[18, 20, 23, 25, 43, 45, 48, 50]
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
Notebook: Ryzen 7945HX, 64 GB RAM, RTX 4060, 17'' @ 240Hz @ 1440p
DJATOM is offline   Reply With Quote
Old 11th March 2020, 13:27   #3  |  Link
color
color's Avatar
Its the same pattern in the full movie. I do however use avisynth.
Old 11th March 2020, 14:37   #4  |  Link
DJATOM
DJATOM's Avatar
No problem with that. Python3 is handy interpreter for small calculations (and more).
Me on GitHub
Old 11th March 2020, 17:52   #5  |  Link
Sharc
Have you tried the avisynth filters 'Dup' or 'DeDup' or 'ExactDedup'?
If the pattern is regular you could probably also use Selectevery(…).
Old 11th March 2020, 20:09   #6  |  Link
manono
Have you tried the avisynth filters 'Dup' or 'DeDup'?
Or TDecimate.
There might not be enough information supplied yet to be sure, but it seems there are 4 duplicate frames in every 25. If so, the TDecimate syntax goes:
TDecimate(Mode=0,Cycle=25.CycleR=4)
Again, as Sharc says, this relies on the pattern being regular. And the result is 21fps, an odd framerate unless, maybe, it's a silent film.
remove frames
Thread Tools
