#21 | Link |
Member of a Library
How much does this build differ from Casimir666's Homecinema build? I.e. how many of the patches are different, is there any modified behaviour... ?
I read the changelogs, but don't understand much ![]() *** edit *** I guess, what I wanted to ask, is which build could be considered more 'up to date'. GL Last edited by GrofLuigi; 9th August 2007 at 14:36. |
#22 | Link |
My build just has some updated libs and a few small patches to fix some bugs. Homecinema has new functionality, mainly related to the renderers. If you have fullscreen tearing problems or want to use the EVR render, use Homecinema. Otherwise use mine.
MPC-HC 2.6.3 |
#24 | Link |
Each DirectX SDK contains a new d3dx9_xx.dll file. I could update to the latest SDK (august 2007), but that would mean that everyone would need to update to the latest version of DirectX. What should I do?
Btw, next build will have two new shaders. A levels converter (16-235 to 0-255) and a nightvision effect. If anyone has written some cool shaders, post them here, and I can add them.
MPC-HC 2.6.3 |
#25 | Link |
Software Developer
![]() Join Date: Jun 2005
Maybe put the required d3dx9_xx.dll for every build into the RAR file !?
#26 | Link |
Updating to latest DirectX SDK is ok I think. As finding new software is easier than finding ancient one. For ppl who don't want to update their DirectX (for whatever reason) you can just upload the needed d3dx9_??.dll to any file upload service like your MPC.
#28 | Link |
Manually putting the ddx9_??.dll file into the archive for distribution is actually wrong...! lol, it would work for the given Windows version, but not for other versrions of Windows. For example, if you are running xp x64, or vista 32, or vista 64, it might actually stop the program from running properly. Might I also add that doesn't it violate the Microsoft licence agreement to distribute single files instead of the redistributable?... It would be far better to have a link to the Microsoft Directx page for the web installer. Afterall, the web installer is actually quite small. The first time you might require 6mb of download etc. but then every 2 months when it comes out the download is quite tiny... it makes better sense and you don't run in to OS compatibility problems or licensing problems
#29 | Link | ||
ffdshow/AviSynth wrangler
now playing: [artist] - [track] ([album]) |
#31 | Link | |
But for whatever reason (I have to repeat what I said in my previous post) d3dx9_22.dll is not in the latest DX update despite what MS said. As for license issue, please enlighten me any part that specific so. I know some games that bundles DX file in them (e.g. s.t.a.l.k.e.r with d3dx31.dll somewhere in the bin folder). |
#33 | Link | |
sidekick
casimir's build fails also...
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
#34 | Link |
Member of a Library
Well what do you know, I always keep my DX updated and I thought this doesn't affect me. But I just checked and indeed there is no 22 dll, just 24 and higher.
![]() I haven't stumbled into any problems since I don't use pixel shaders, but I think this issue should be addressed (compile against other dll)? GL |
#35 | Link |
I will use the latest DirectX SDK for next build. I'll also upload the required DLL.
MPC-HC 2.6.3 |
#36 | Link |
but ffdshow also fails in my practice, maybe my ffdshow is outdated, well, i'll take another try, thx kurt
and i prefer the internal mped2 decoder, it has a convenient color space fix preset, while i'm not quite sure how to set ffdshow's "picture properties" filter to do a proper color space fix, and ffdshow's dvd decoding checkbox is still labeled "not working yet" while it's actually, working. waiting for the upcoming build for the pixel shader color space convertor ![]() hope my previous post didn't look like blame, i really like this refresh build, thx clsid! maybe you should contact gabest for the official sf svn access? or a new project like mpc-hc? |
#37 | Link |
New build is up.
I am not doing any real development here, so I don't see a need for a new project. I don't have any plans for further changes, so this is the last build for now. Of course, if any worthwhile new patches appear, a fresh build shall be made.
MPC-HC 2.6.3 |
#39 | Link |
The shaders is the only functionality that need the dll. The number depends on which version of the DirectX SDK is used during compilation.
MPC-HC 2.6.3 |
| Tags |
| media player classic, mpc, vsfilter |
| Thread Tools | |
| Display Modes | |
