11th January 2021, 09:14 | #121 | Link |
Big Bit Savings Now !
Win7U64SP1 with (hopefully) latest .net 4.8.03761, systemwide latest VC++ Redist 2019 (14.28.29325.2)
Trying VSRepoGUI.exe for the first time. No matter if 32bit or 64 bit, starting VSRepoGUI.exe from within Vapoursynth portable R52 with internally provided python3.8.7150 and VC++ runtime 2019 (14.28.29334.0) gives Code:
Problemsignatur: Problemereignisname: CLR20r3 Problemsignatur 01: VSRepoGUI.exe Problemsignatur 02: 1.0.0.0 Problemsignatur 03: b514b7a2 Problemsignatur 04: VSRepoGUI Problemsignatur 05: 1.0.0.0 Problemsignatur 06: b514b7a2 Problemsignatur 07: 118 Problemsignatur 08: 6a Problemsignatur 09: N3CTRYE2KN3C34SGL4ZQYRBFTE4M13NB Betriebsystemversion: 6.1.7601.2.1.0.256.1 Gebietsschema-ID: 1031 Zusatzinformation 1: 0a9e Zusatzinformation 2: 0a9e372d3b4ad19135b953a78882e789 Zusatzinformation 3: 0a9e Zusatzinformation 4: 0a9e372d3b4ad19135b953a78882e789 then after confirming the abovementioned crash report window pops up. Continuing.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 11th January 2021 at 09:32. |
11th January 2021, 10:09 | #122 | Link |
I will check later in my VM. How does your vsrepogui.json look like?
Avsrepogui.exe is in the same folder as the python.exe? EDIT Can you run "python vsrepo.py update" in console without problems?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 11th January 2021 at 10:23. |
11th January 2021, 10:22 | #123 | Link |
Many thanks for looking into it ! Yes, vsrepogui is in the same folder as python.exe.
Just downloaded your Fatpack, it throws the same error, BTW. Fatpack vsrepogui.json: Code:
{ "Bin":"vsrepo.py", "win32": { "Binaries":"vapoursynth32\\plugins", "Scripts":"..\\Scripts" }, "win64": { "Binaries":"vapoursynth64\\plugins", "Scripts":"..\\Scripts" } } (ATM I have no thorough understanding what "binaries" would address: the location of plugins or the VapourSynth.dll and where this is an example of relative vs. absolute paths... Code:
{ "Bin":"C:\\_PROG\\! Video Tools\\! VapourSynth32-Portable-R52\\vsrepo.py", "win32": { "Binaries":"abc d\\p32", "Scripts":"..\\scripts" }, "win64": { "Binaries":"C:\_PROG_64\! Video Tools 64\! VapourSynth64-Portable-R52\\vsrepo\\abc d\\p64", "Scripts":"C:\_PROG_64\! Video Tools 64\! VapourSynth64-Portable-R52\\vsrepo\\abc d\\scripts" } }
11th January 2021, 11:50 | #124 | Link |
Binaries = plugin path in this context (it overrides the vsrepo parameters: you can check with "vsrepo.py paths)
the \ char needs to be escaped. A valid version should look like this. Code:
{ "Bin":"C:\\_PROG\\! Video Tools\\! VapourSynth32-Portable-R52\\vsrepo.py", "win32":{ "Binaries":"abc d\\p32", "Scripts":"..\\scripts" }, "win64":{ "Binaries":"C:\\_PROG_64\\! Video Tools 64\\! VapourSynth64-Portable-R52\\vsrepo\\abc d\\p64", "Scripts":"C:\\_PROG_64\\! Video Tools 64\\! VapourSynth64-Portable-R52\\vsrepo\\abc d\\scripts" } } I think I need a bat file which changes the directory first to avoid this problem. "Clr20r3" error on google suggest that it could be a problem with the .net installation. Btw. what is U in Win7U64SP1? Ultimate?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 11th January 2021 at 11:57. |
2nd February 2021, 11:11 | #126 | Link |
See if the new version fixes it for you https://github.com/theChaosCoder/VSR...ses/tag/v0.9.6
2nd February 2021, 17:56 | #128 | Link |
I see the problem now.
vsrepo can't detect vapoursynth Code:
.\python.exe .\vsrepo.py update Could not detect vapoursynth => But it should work in portable mode (not tested yet) EDIT portable mode works. Tested with python3.9 embed version. vsrepogui.json Code:
{ "Bin":"vsrepo.py", "win32": { "Binaries":"plugins32", "Scripts":"Scripts", }, "win64": { "Binaries":"plugins64", "Scripts":"Scripts", } }
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 2nd February 2021 at 18:02. |
22nd March 2021, 10:38 | #130 | Link |
You can find a vs version here https://github.com/Selur/Vapoursynth...41Fun.py#L2885
Scipts are imported like this: import G41Fun as gf and then can be used like this: clip = gg.DetailSharpen(clip) You need to place G41Fun.py inside your python site-packages folder Code:
C:\Users\<USER>\AppData\Roaming\Python\Python38\site-packages
23rd March 2021, 00:32 | #131 | Link | |
18th July 2022, 17:46 | #133 | Link |
It is most likely a vsrepo.py problem. Try running vsrepo.py in CMD first and see if it works. I had the same problem, not sure how I fixed it. I think I reinstalled python and/or R59.
15th December 2022, 22:36 | #134 | Link |
Many thanks, ChaosKing !
Finally got it to work nicely. It is end of 2022 and I can return to learning VapourSynth on a Win10Pro64 system. Here comes the correct vsrepogui.json for my 2 portable installations. Code:
{ "Bin":"C:\\_PROG\\! Video Tools\\! VapourSynth32-Portable-R61\\vsrepo.py", "win32":{ "Binaries":"C:\\_PROG\\! Video Tools\\! VapourSynth32-Portable-R61\\vapoursynth32\\plugins", "Scripts":"C:\\_PROG\\! Video Tools\\! VapourSynth32-Portable-R61\\vapoursynth32\\scripts" }, "win64":{ "Binaries":"C:\\_PROG_64\\! Video Tools 64\\! VapourSynth64-Portable-R61\\vapoursynth64\\plugins", "Scripts":"C:\\_PROG_64\\! Video Tools 64\\! VapourSynth64-Portable-R61\\vapoursynth64\\scripts" } } Having the VSRepoGUI "Search (x) Win64" ticked searches the local 64bit installation and downloads the 64bit plugins and scripts into the 64bit installation. Having the VSRepoGUI "Search ( ) Win64" unticked searches the local 32bit installation and downloads the 32bit plugins and scripts into the 32bit installation. P.S. Eek... 102 64bit plugins fell into the 32-bit installation, only 2 were correct 32bit. On reload the situation improved: almost 100 correct. Ok, later..
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 15th December 2022 at 22:48. |
16th December 2022, 12:01 | #135 | Link | |
I could replace the checkbox with a dropdown [Auto, Win64, Win32 ] to avoid confusion 🤔
20th February 2023, 00:25 | #136 | Link |
Installing havsfunc and muvsfunc did not install several dependencies. Havsfunc was installed without vsutil installing. Several muvsfunc plugins also did not install including: AWarpSharp2, Bilateral, CAS, CTMF, descale, TCanny, and likely many others. All are listed separately in Vsrepogui. VSrepogui was placed in the the pedeps bin directory with listpedeps.exe. Diagnose Problems did not recognize the missing dependencies.
