17th May 2009, 18:42 | #1 | Link |
x264 VBV -- Progressive download and Streaming
Hi everyone,
I've been a longtime user of megui and x264, and I have to admit that the work that everyone has put into it is quite amazing! From the programmers to the support staff on all levels, thanks! But, I have a question that I've only been able to get partial answers to, and nothing totally conclusive. On the issue of VBV and progressive http streaming, and real "rtsp:" streaming. I'm basically trying to figure out how to set the VBV settings to restrict the maximum bitrate of my .mp4 files. In the case of JWPlayer, i can set, for instance, a 3 second buffer. Should I set the vbv-bufsize to match that 3 seconds worth of buffer? I understand that VBV is generally used for specific hardware requirements, but what about in the cases of progressive and rstp streaming? Thanks, -Adam |
17th May 2009, 20:25 | #4 | Link | |
x264 developer
With streaming, you can't do this, since the client can't buffer arbitrarily far ahead. But wait, you ask. What if there's a spike at the beginning? Well then the user has to buffer for another second or two . Neither Youtube nor Facebook use VBV in their progressive download. The reason for this is twofold: 1. The impact of CBR on quality is tremendous. 2. You could modify an encoder to model the interaction described here (effectively an infinite-size VBV that starts empty), but that takes effort.
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 17th May 2009 at 20:30. |
18th May 2009, 01:32 | #5 | Link | |
You can also think of VBR as a CBR with some really easy parts and without padding bits. There's no reason not to set a VBV as well as ABR/PBR, where the VBV is PBR * buffer duration. When doing progressive download to devices with hardware decoders, you need to respect the VBV as well. This is fine for streaming as well if you don't want to spend the bandwidth budget making the easy bits higher than a certain quality. Thus, you could make sure it's streamable with 1000 Kbps of bandwidth, but the utilized bandiwidth could be lower much of the time. |
18th May 2009, 16:56 | #8 | Link |
thanks everyone. What is the VBV_maxrate limited by? Frame, gop, or seconds?
I use this program to examine the bitrate of my resulting .mp4's http://www.winhoros.de/docs/bitrate-viewer/ Even if I set a VBV_maxrate it seems that the maxrate is being respected only in regards to the GOP, and it seems to be about 200k higher than the maxrate. So for instance, if I set a maxrate of 1500k and a buffer of 4500k, when I use the bitrate viewer, it will show a rate of 1700k maximum bitrate when I put it on GOP mode. If I select frame or seconds mode, i still see huge spikes on the I frames. Thanks for all the input, right now my website is running on purely progressive download, and I have to make a decision very soon to switch to a more advanced progressive solution like this one: http://h264.code-shop.com/trac Or go for a full-on wowza RTSP solution. Regards, -Adam PS- I'm currently using MEGUI as a front-end to my encoding, and using automated 2-pass mode, using the VBV settings that are exposed in the GUI. I check the resulting command lines and they SEEM ok, but could MEGUI be giving me problems in my VBV experiments? |
18th May 2009, 17:01 | #9 | Link | ||
x264 developer
20th October 2009, 18:50 | #11 | Link | |
Hi Dark, I was hoping for a little more info on what you said here:
So would it be a good idea to set the buffer size *2, *10, or somewhere in the middle. Also, what is the harm in setting this too high. Thanks Last edited by Riki; 20th October 2009 at 18:50. Reason: spelling |
23rd October 2009, 19:51 | #15 | Link |
Anyway, in general I'm fan of having the peak bitrate at least 1.5x the average, with a buffer duration at least as big as the GOP length (so the VBR model can allocate bits for at least one full GOP).
With our modern byte-range access progressive download mechanisms, using a GOP and buffer duration around 4-6 seconds seems pretty optimal in practice. Much higher and random access can get slow, and much less and compression efficiency can be badly impacted. |
28th October 2009, 16:27 | #16 | Link | |
Video Encoder (Settings) -> cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=150 / keyint_min=30 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1316 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1579 / vbv_bufsize=6581 / ip_ratio=1.40 / aq=1:1.00 / cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=150 / keyint_min=30 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1316 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1579 / vbv_bufsize=6581 / ip_ratio=1.40 / aq=1:1.00 Date of Original Encoding -> UTC 2009-10-17 00:09:26 |
28th October 2009, 17:20 | #18 | Link | |
Are the VBV values based on anything other than the target bitrate? I'm wondering what the logic is behind ~120% for maxrate and ~420% as reasonable values for capping bitrate spikes, or am I extrapolating too much from one video? |
bitrate, download, rstp, streaming, vbv |
