Old 22nd September 2022, 08:51   #481  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
@banaguitar
Actually, the masks from your last post are OK, I didn't noticed that I ran them on WIP script...
Delogo result is not perfect but you can't do better on this video, maybe I would add more Gaussian blur to it with dPP=5.
Logo:
Delogo [ InpaintDelogo( mask="D:\mask.bmp", Loc="40,26,146,60", Analyze=1, Mode="Deblend", dPP=5) ]:
VoodooFX is offline   Reply With Quote
Old 23rd September 2022, 05:52   #482  |  Link
doctorkhv
@doctorkhv
My advice: Don't waste your time, anything you add there can be removed.
Not a single logo can be erased with high quality even by specialized programs for removing objects (DaVinci Resolve and NUKE Studio)
The brain is arranged in such a way that it is easier for it not to notice a static object (logo) than a spot that changes in color and shape in place of a remote logo.
doctorkhv is offline   Reply With Quote
Old 23rd September 2022, 19:11   #483  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by doctorkhv View Post
Not a single logo can be erased with high quality even by specialized programs for removing objects (DaVinci Resolve and NUKE Studio).
Fake news, you need to join VideoNonsense forums.
Top - your logo [Trim(5921,-260).Crop(3420,2000,-20,-60)], bottom - after InpaintDelogo:
Btw, good to know that those "even" programs are not good.
Is this some kind of propaganda or it's self-hypnosis?
My brain definitely is choosing the bottom video.
Last edited by VoodooFX; 23rd September 2022 at 20:01. Reason: added link to the post with video link
Old 23rd September 2022, 19:20   #484  |  Link
johnmeyer
VoodooFX: Great work. Not even worth replying to someone who doesn't know which end is up.
Old 23rd September 2022, 19:42   #485  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Nonsense should be addressed, especially on Doom9 forums.
For reference: I'm still waiting for lordTroll's MS Paint skills there, the last news that the guy started to see ghosts on his TV, most likely it's a case for Ghostbusters.
Old 24th September 2022, 00:40   #486  |  Link
doctorkhv
VoodooFX: Great work!
I remembered the film "Un homme et une femme" 1966 in which I could not remove the stains that can be considered logos)
Can anyone try to remove the stains? Humanity and I will be grateful)
Link to my google drive (2 minutes 21 seconds) https://drive.google.com/file/d/1mmN...ew?usp=sharing
Thanks a lot!
Old 24th September 2022, 03:05   #487  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
1) Save frame with the spots to image.
2) Open that image with some editor and mask/mark the spots then save it to lossless image.
3) Apply that mask to the selected frames with InpaintDelogo( mask="D:\spots.png", Loc="0,0,0,0", Inflate=0 )
Notes:
With current version you would need to paint the background in black.
If you don't want to bother with the background then get v3 InpaintDelogo.
Use full white to mask/mark the spots.
"Inflate" expands mask, its default is 1 px, so I disabled it here.
You can use fastest preset with "Turbo=3".
Original frame 800:
Mask with the spots to remove:
Result:
Old 24th September 2022, 13:26   #488  |  Link
Voodoo indeed.
doctorkhv, see here [Postimages instructions]:- https://forum.doom9.org/showthread.p...ge#post1959414
Old 26th September 2022, 00:15   #489  |  Link
doctorkhv
Thank you so much StainlessS
Thank you so much VoodooFX
I never saw a video without spots.
I am unable to apply the InpaintDelogo-temp.avs script. , used XviD4PSP 5
PHP Code:
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
LoadPlugin("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\FFMS2.dll")
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\FFMS2.avsi")
LoadPlugin("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\SplineResize.dll")
FFmpegSource2("D:\Un.homme.et.une.femme.1966.mkv"rffmode=0threads=1cachefile="D:\Temp\Un.homme.et.une.femme.1966.mkv.ffindex")
ConvertToYV12()
###[FILTERING]###
XviD4PSPPluginsPath "C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\"
Import(XviD4PSPPluginsPath + "
InpaintDelogo-temp.avs")
InpaintFunc(last,mask="
D:\spots.png", Loc="0,0,0,0", Inflate=0)
Old 26th September 2022, 01:09   #490  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Are you sure?
Old 26th September 2022, 23:45   #491  |  Link
doctorkhv
Yes, this is probably because XviD4PSP 5 only supports AviSynth + v3.5.1
I want to see how well the spots are removed in the 2 minute episode "Un homme et une femme" 1966 https://drive.google.com/file/d/1mmN...ew?usp=sharing
Old 27th September 2022, 00:37   #492  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Yes
How do you know that you are sure?
Old 27th September 2022, 01:41   #493  |  Link
doctorkhv
1.
2.
You didn't show me the video fragment with the stains already removed
Old 27th September 2022, 01:59   #494  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
1. Finally you've posted something tangible... How you expect to see "video without spots" or "apply" if you couln't even import InpaintDelogo?
Probably InpaintDelogo is not there, check if your path, filename and extension is correct.
2. I posted a fragment as image "Result".
Old 27th September 2022, 02:23   #495  |  Link
doctorkhv
1. It's very easy to remove spots from one image and show the result, but I asked you about the episode VIDEO
If you want to upload a sample there's lots of places.
https://workupload.com/
https://www.udrop.com/
https://ufile.io/
https://fileupload.win/
2. What AviSynth GUI are you using and what does the script look like for this case?
Old 27th September 2022, 02:53   #496  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
1) Do it by yourself.
2) GUI is not important, it was posted already.
Old 28th September 2022, 00:29   #497  |  Link
Zetti
I have a sample that i hope you will look at and help me with the settings and give me some tips how you have got them and what i can do on future projects.
Because I'm scratching on my head after trying to adjust for hours
Samlpe
https://file.io/HHeLlMlHF5EJ
Script
InpaintDelogo(Loc="58, 564, -98, -24", Show=4, DynLocUp=4, DynMask=4, DynTune=215, DynMask4H=200, KillBlobs=-7, Extract=1, ImgDir="D:\Test\Pics", ImgInflate=1, CorrTh=0.9)
Zetti is offline   Reply With Quote
Old 28th September 2022, 01:21   #498  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by Zetti View Post
File is deleted. Maybe upload to Wetransfer.
Old 28th September 2022, 10:10   #499  |  Link
Zetti
https://we.tl/t-NhbuVVmQGw
Old 28th September 2022, 14:37   #500  |  Link
kedautinh12
Video is interlaced, so first deinterlace it to lossless file.
Logo is transparent = use Deblend mode.
Trim to exclude parts where there is no logo or logo is animated.
Run the script posted below with Automask=1 to create "bmp" basemask, then run with 0 to create deblending masks and delogo.
Animated parts you can delogo with Inpaint mode.
LWLibAvVideoSource("D:\EONIAN_deinterlaced.mkv")
Trim(61,10907)
InpaintDelogo( mask="D:\mask2.bmp", Automask=0, aMix=1, Loc="1252,878,-90,-64", Mode="Deblend")
Similarly you can remove logo at the left side too.
Logo:
https://i.imgur.com/eTxsNe4.jpeg
Delogo:
https://i.imgur.com/HZNQF8f.jpeg
I tried with leftside but can't creat mask perfect like rightside
Trim(159,10954)
InpaintDelogo( mask="C:\mask3.bmp", Automask=1, aMix=1, Loc="98,874,-980,-64", Mode="Deblend")
sample:
https://drive.google.com/file/d/1-kk...ew?usp=sharing
delogo, hardsubs, ocr, remove, watermark
