#121 | Link |
Archimedes, nice work in summary. Have one suggestion (besides mvtools implementing
): using key 'TAB' and 'SHIFT-TAB' to switch between values when editing parameters.Thank you, T. Last edited by Terka; 12th April 2011 at 12:55. |
#133 | Link |
Did a quick test with 212 images from a digital camera (original resolution). No problems here (latest alpha release of AviSynth) with dfttest.
What is the task manager telling you while processing? Do you have enough memory? |
#134 | Link |
Fritz use up to 100MB of memory, going down to 30MB and up again for each Image, I have 4GB of ram so it doesn't seems to be the problem. I just tried avisynth set build and it processed up to 31 image before throwing this error :
![]() My script is simple greyscale and dfttest, using sigma 256 since it's a comic scans, maybe that's the problem? |
#136 | Link |
I'm having a problem on Win7 x64 where none of the tabs have labels and most of the windows are blank. In the preview window, I have to hit "Refresh" before the images will show up. Anything special for running on 64 bit?
#138 | Link |
Fritz Photo run all AviSynth scripts in thread. If there is a crash, you normally will receive the same crash (the same error message) when starting the script outside of the program (e. g. in Virtual Dub).
Don’t’ know exactly, what the problem is here. I will provide you with another exe file for further testing. Last edited by Archimedes; 29th November 2011 at 23:49. |
#139 | Link | |
![]() Regarding the preview window, this is the normal behavior, you allways have to hit the refresh button, before seeing pictures. |
#140 | Link | |
I did try it in a Win XP 32bit virtual machine and all is good. |
| Thread Tools | |
| Display Modes | |
