11th August 2009, 23:12 | #9081 | Link |
rev 1216:
http://aleksoid.tosei.ru/Dist/MPCHC_1216_x86.7z http://aleksoid.tosei.ru/Dist/MPCHC_1216_x64.7z standalone filters: http://aleksoid.tosei.ru/Dist/Filter...rs_1216_x86.7z http://aleksoid.tosei.ru/Dist/Filter...rs_1216_x64.7z
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
12th August 2009, 09:20 | #9083 | Link |
12th August 2009, 15:00 | #9086 | Link | |
Where as with DirectX and VMR9 non-exclusive mode there is no mechanism in the OS itself (nor in DirectX) that would allow the application to rely on for the v-sync (i.e. application itself is responsible for the v-sync matching). / tourettes, MediaPortal developer |
12th August 2009, 15:10 | #9088 | Link | |
MPC-HC Project Manager
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
12th August 2009, 18:22 | #9089 | Link |
Does ar-jar's new code have a setting that turns off all of MPC-HC's application-level syncing and allows the default graphics card syncing to occur ?
If not, that would be helpful for a) situations where that produces the best results, and b) testing of MPC-HC's sync code - i.e. you would have a scientific "control" to compare with.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
12th August 2009, 18:25 | #9090 | Link |
Disable all 3 sync options (only 1 can be active at the time)
So uncheck present close to vsync and you'll mpc is free to do whatever. You will never get a better result though, vsync doesn't know anything about the actually video refreshrate. Various glitches will occur ever X timeunits of playtime. (the present close to vsync code minimised these glitches by slightly adjusting present timing)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 12th August 2009 at 18:31. |
12th August 2009, 20:13 | #9092 | Link | |
12th August 2009, 23:33 | #9093 | Link |
rev. 1223:
http://aleksoid.tosei.ru/Dist/MPCHC_1223_x86.7z http://aleksoid.tosei.ru/Dist/MPCHC_1223_x64.7z changelog: Fix : crash in DXVA, enable 14 ref frames for XP Fix : DTS bugs
13th August 2009, 00:32 | #9094 | Link | |
the hedgehog
the MediaInfo.dll support is a nice addition. others using Nvidia+XP should test the newly introduced 14 ReFrames limitation and post the results.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
13th August 2009, 03:08 | #9096 | Link |
Made self ,use MeGui
13th August 2009, 03:26 | #9097 | Link |
the hedgehog
yes, that would be best, instead of everyone using the same samples
you can download some of the samples i've been using (12 to 15 Reframes, no B-Pyramid): http://rapidshare.com/files/26677394...-001_12ReF.mkv http://rapidshare.com/files/26677467...-001_13Ref.mkv http://rapidshare.com/files/26677562...-001_14ReF.mkv http://rapidshare.com/files/26677638...-001_15ReF.mkv a 16 ReFrames video here
13th August 2009, 04:04 | #9098 | Link |
720p, 14 ReFrames sample - http://aleksoid.tosei.ru/Sample/test.mkv, short
13th August 2009, 05:39 | #9099 | Link |
Audiophile
can't seem to get DXVA to get working on that sample. CoreAVC(CUDA) works fine though.
edit: false reading. i forgot to update MPC. both 14ref samples work just fine. btw, what's the ref limit on nvidia cards? the 16ref sample doesn't work with CoreAVC(CUDA) or DXVA. edit2: 15ref works with CUDA. Last edited by Mangix; 13th August 2009 at 06:11. |
13th August 2009, 06:06 | #9100 | Link | |
