11th December 2002, 11:04 | #221 | Link |
Just wanted to say thanx...
Thanx for your time Gabest...WMPClassic is really great...
A3TeRnuS.213
"I refuse to join any club that would have me as a member!" Julius "Groucho" Marx (1890-1977) |
11th December 2002, 11:24 | #223 | Link |
Horizontally are the inputs and vertically the outputs. Whereever you place a check mark those two will be connected together. As a common usage you can check 1-rightfront and 2-leftfront to exchange the output on some badly configured stereo speakers.
gabest.org |
11th December 2002, 17:17 | #225 | Link |
The problem was that when the filter graph sent a notification event about the video frame size changing, I also set the default window zoom level. On my system it was only happenning with rm and dvd but it may arrive from any renderer at any time. And yes, this is supposed to be fixed in the new release
gabest.org |
11th December 2002, 17:46 | #226 | Link |
thanks. will test that out tonight.
one question about the audio channel matrix, if i set it to 1-rightfront and 1-leftfront, will the "left" channel be sent to both speakers? meaning i want to play only the left (or right) channel on both speakers... (for those dual language avi where the left channel is one language and the right channel is another language) |
11th December 2002, 18:56 | #227 | Link |
Yes, and you can mix more channels to one speaker too.
gabest.org |
12th December 2002, 07:51 | #229 | Link |
DVD Rebuilder!
@gabest,
Thank you for the channel matrix explaination, it's very cool feature! Btw, there is a way to save the speaker configuration for the "Intervideo Audio Filter" I did set it to 5.1 from the filter properties, but somehow it will always reset to 2 speaker (dolby) after I restart the MPC. Thank you. |
12th December 2002, 11:29 | #231 | Link | |
gabest.org |
13th December 2002, 05:55 | #232 | Link | |
DVD Rebuilder!
@gabest, Sure, I did change the Windows's speaker setting through the control panel to 5.1. But not reboot yet, still downloading... I'll try to reboot and check again. Thank you. Last edited by ookzDVD; 13th December 2002 at 08:56. |
13th December 2002, 19:08 | #233 | Link | |
But things have changed. Everybody has realized there are very strong negative feelings about what you describe, and we really want to improve. In that respect, the latest RealOne v.2 is much better than older RealPlayers, and on OS X, it's downright wonderful. On Windows though you still have to do the following, which isn't too bad, but still could have been better (and it will be soon): 1) Choose Custom Install 2) Uncheck all the boxes you don't like for stuff on the desktop and quicklaunch bar. Personally, I only leave one box for one shortcut on the desktop, but that's my preference, of course. 3) Check only the media types you want it to play. For you, probably the least possible. The box for "maintain media type preference", should be unchecked by default, but if it isn't, uncheck it 4) Start RealOne, go into Tools->Preferences->Automatic Updates, and uncheck everything there. As you can see, particularly items 2), 3) and 4) are things the Windows version still needs to improve upon. Now if you use MPC, you don't need to do anything more, but if you would like to use RealOne once in a while, go into Tools->Preferences->General and set On startup display to "Player only". That way, no browswer, and it starts much quicker. That's about it. If you don't like to View clip info while playing music, Select View->Album Info->Hide. Now, please don't hesitate to provide suggested improvements (or flames for that matter), and I can forward to our consumer team. Media Player Classic is a great player! I have it installed myself, and it plays the latest RealVideo like a champ, which by the way looks great at all bitrates
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
14th December 2002, 18:17 | #235 | Link |
Bug Report (cosmetic only)
Thanks for the properties menu.
I have a little bug report. It's maybe related with the change in the behaviour of the control bar in fullscreen. Before, if I let the mouse over the control bar, the bar remained in screen. Now, after the especified time, the bar dissapears. Procedure to reproduce the bug. - Open a movie an play it. - Go to fullscreen. - Right Click and select ffdshow (or maybe another filter). - Accept (you don't need to change anything in ffdshow). Before to accept let the bar disapears. - Now you have the bar with the status in the left (playing), the two speakers in the right, but no actual time/total time before. pandv |
14th December 2002, 21:52 | #236 | Link |
4-speaker
[HKEY_LOCAL_MACHINE\SOFTWARE\InterVideo\Common\AudioDec] "Audio"=dword:00000004 6-speaker [HKEY_LOCAL_MACHINE\SOFTWARE\InterVideo\Common\AudioDec] "Audio"=dword:00000005 S/PDIF [HKEY_LOCAL_MACHINE\SOFTWARE\InterVideo\Common\AudioDec] "Audio"=dword:00000006 The settings for iviaudio.ax should stick after modifying the registry. BTW, ffdshow and TomsMoComp are not that great. Sometines they tend to crash MPC and ZoomPlayer. CPU usage is quite high since ffdshow breaks DxVA of video decoders. VMR-9 + Radeon should be pretty good for deinterlacing but I have no idea why there is a really annoying diagonal line that kinda ruins the picture. Combing is very minor but the diagonal line problem affects both 24p and 30i sources. What the heck |
15th December 2002, 01:20 | #237 | Link | |
bbq@KL:
pandv: Fixed. Gforce_Ti: Could you connect graphedit to mpc and see what filters are there? karl_lillevold: It can play the latest realvideos, because it is using the sdk. Though it was a "real" pain to adjust all those header files for vc7, it is still a lot better than what quicktime has Also, I'm looking forward to seeing your dshow compatible filters you talked about in another thread here at doom9. Any idea about the release date? New version up: http://download.vobsub.edensrising.com/mpc98me6412.zip http://download.vobsub.edensrising.com/mpc2kxp6412.zip
gabest.org Last edited by gabest; 15th December 2002 at 01:41. |
15th December 2002, 02:38 | #238 | Link | |
With regards to directshow filters, I think I must have been unclear. That was about the input directshow reader for producer... soon to be supporting YV12 for those using AVISynth 2.5.
15th December 2002, 02:49 | #239 | Link | ||
gabest.org |
media player classic |
