13th December 2009, 10:50 | #6301 | Link |
Is there a way to increase the "visibility" of the interface, i.e. the font of the GUI is too small.
Edited: managed to do a few tests. no more comments because I have removed it for good. Last edited by medp7060; 13th December 2009 at 11:15. |
13th December 2009, 17:44 | #6302 | Link |
Atak,
Great program. Thanks for all your support. 1 question... 1. When converting a mkv file to AVCHD with DTS audio (bitrate: 1536 Kbps, sample rate: 48 Khz, 5.1), I generally change the audio option to 5.1 Aften, 640kbps, AC3 instead of leaving the xxx stream-copyxxx as the default audio. Is there any benefit to more stable play back on my stand alone blu-ray player (sony bdp-s550)? I feel like the playback is sometimes buggy. Sometimes, I will get only audio but no video for a minute, then it pops up OR the tv just says no signal. Sometimes, reloading the DVDR+DL disc makes it work. I'm trying to figure out if this "bugginess is a result of my encoding options, or if it a problem with my bluray player, or my reciever. My Pioneer reciever can play all audio including DTS so I am not sure why I keep changing the audio? I guess I'm doing it because I think the AC3 is "more stable"? Does this make any sense? Would love to hear your opinion. If it helps, I usually 2-pass, lock the size to 8150MB, choosing AVCHD as my output, and burning to a DVDR+DL. Thanks in advance, Philippe My specs (with all HDMI cables going into the Reciever): Sony Blu-ray player BDP-S550 Pioneer Reciever VSX-819H TV is LG 37" HDTV My computer is running Windows 7 Ultimate 64bit, Intel Quad-core Q9550 @ 2.83Ghz, 4GB ram, DVD burner is HP DVD writer 1070r, media is Verbatim DVD+R DL (8x speed), burning with IMGburn. |
13th December 2009, 19:57 | #6303 | Link |
@pdek
Try to burn your DVD at 4X instead of maximum. Use DVD+RW if you don't want to waste your discs. Let me know if this helps or not.
13th December 2009, 21:46 | #6305 | Link | |
13th December 2009, 22:04 | #6306 | Link |
Sorry, here you go...
job1_EncodeVideoPass1.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job2\job2.avs" --pass 1 --bitrate 8192 --stats "E:\temp\RipBot264temp\job2\job2.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" job2_EncodeVideoPass2.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job2\job2.avs" --pass 2 --bitrate 8192 --stats "E:\temp\RipBot264temp\job2\job2.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" job2_MuxFiles.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\mkvtoolnix\mkvmerge.exe" -o "E:\iceage3.mkv" --title "iceage3" --default-duration 0:24000/1001fps -d 0 -A -S "E:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "E:\temp\RipBot264temp\job2\audio.1.dts" MKVExtract.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.6\Tools\mkvtoolnix\mkvextract.exe" tracks "E:\iceage3demux\00386+00364.track_4113.mkv" 2:"E:\temp\RipBot264temp\job2\audio.1.dts" "E:\Apps\Rip BD To MKV\RipBot264v1.14.6\Tools\mkvtoolnix\mkvextract.exe" chapters "E:\iceage3demux\00386+00364.track_4113.mkv" -s > "E:\temp\RipBot264temp\job2\chapters.txt" |
13th December 2009, 22:06 | #6307 | Link |
I need job2.avs not log!
13th December 2009, 22:37 | #6308 | Link |
Great program, thanks a lot for creating. I've successfully encoded some of my 1080p mkv files with ac3 audio to 720p to save space and the 720p look great. A few questions:
1. Can I keep HD audio from mkv container if I leave at copy stream? 2. I have a recording from media center that I've converted to mpeg. When I play the video and audio are in sync. When I try to use ripbot to reduce the size the audio becomes out of sync with the video. I've also used mkvmerge to seperate the video and audio and both are the same length. Using Ripbot on the two separate files also results in out of sync audio. Any ideas? I'm using the high 4.0 HD.Bluray.consoles profile. Thanks again. |
13th December 2009, 23:18 | #6309 | Link | |
14th December 2009, 01:54 | #6310 | Link | |
http://www.mediafire.com/?1zlieyymmyn |
14th December 2009, 05:12 | #6311 | Link |
here is the job2.avs file..
#MT #VideoSource video=DirectShowSource("E:\iceage3demux\00386+00364.track_4113.mkv",audio=false).ConvertToYV12() #Deinterlace #Decimate #Crop video=Crop(video,0,22,-0,-22) #Resize video=Spline36Resize(video,1920,1038).Sharpen(0.2).AddBorders(0,21,0,21) #Colors #Denoise #Subtitles #AudioSource LoadPlugin("E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicDTSSource("E:\temp\RipBot264temp\job2\audio.1.dts") audio=ResampleAudio(audio,48000) #DownMix Import("E:\Apps\Rip BD To MKV\RipBot264v1.14.6\Tools\AviSynth plugins\Scripts\DownMixAudio.avs") audio=DownMix2Stereo(audio) #Delay audio=DelayAudio(audio,0) #Tempo #Normalize #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(0,135303) #ColorSpace |
14th December 2009, 07:54 | #6312 | Link | |
Installation of MP 11 solved the problem for me.
Bye QUEENFAN |
14th December 2009, 13:34 | #6313 | Link |
192kbps audio setting request for 2 channel Audio encoding!
Hi Atak,
I am using your marvellous program for ripping video for my Sony X Series (NWZ-X1060) Walkman. But 2 channel audio setting is upto 128kbps. I wish to use, higher 192kbps audio setting too. Can you please add this setting under the "Audio Profile" preferences? (Being: 2.0 CT, AAC-LC, 192 kbps [abr]) Or, can you give me the way, how to apply this setting? Thank You... |
14th December 2009, 15:44 | #6315 | Link | |
@APorter819
temporary solution to your problem 1) change extension of your file to .m2v (for example sample.m2v) 2) open .m2v file in ripbot 3) enable inverse telecine function 4) set audio delay to -750ms After this i have perfect audio synchronization. I don't know if this works with your whole file. Let's hope that audio delay is constant. Quote:
@magmo did you have the same problem in older versions of ripbot?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th December 2009 at 15:49. |
14th December 2009, 16:07 | #6316 | Link |
Hmm,
The hint, seemed to me like an effect type Atak! For 2 channel audio 128kbps is a really low bit rate by means of audio quality. The cinema sound is much lower in quality than a studio recording. I didn't only requested it for only choosing 192Kbps use. I may use higher 256kbps and 320kbps setting when necessary, if possible of course! English/USA or other country specific films generally recording in real time with microphoses "outside" not in dubbing rooms. Therefore hearing the speech is really a matter sometimes. Increasing the bitrate might be helpful in many cases. This setting is not only necessary for me here. It might be useful to others... |
14th December 2009, 16:12 | #6317 | Link | |
14th December 2009, 16:15 | #6318 | Link | ||
http://wiki.hydrogenaudio.org/index.php?title=AAC Quote:
14th December 2009, 16:43 | #6319 | Link |
Gee,
I have invented a new device by mistake. microphose singular, microphoses plural Of course the right typing I meant was "microphones" Yeah they may contain a lot of microbs on the hoses. Not completely wrong in fact |
14th December 2009, 17:51 | #6320 | Link | |
