Old 28th July 2007, 16:58   #61  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
New test compile that should fix the issues with huge mkv files and mpeg2 in mkv:
deleted
Note that it requires the dlls from the normal package and that it now uses the AVISYNTH_C interface. ONLY FOR TESTING.
Last edited by Myrsloik; 29th July 2007 at 21:47. Reason: remove the outdated link
Myrsloik is offline   Reply With Quote
Old 28th July 2007, 18:33   #62  |  Link
video_magic
Hurrah for Myrsloik!!!! Very useful and time-saving
Thankyou!, I am grateful for any help
video_magic is offline   Reply With Quote
Old 29th July 2007, 17:39   #63  |  Link
ajp
http://ivtc.org/new/beta/FFmpegSource.dll
Nice! However, I get a message saying "ffmpegsource.dll is not an Avisynth 2.5 plugin"?
ajp is offline   Reply With Quote
Old 29th July 2007, 17:49   #64  |  Link
Myrsloik
Myrsloik's Avatar
That could be because it isn't one. As I wrote in the post, quoted by you for additional effect, it uses the the c interface. Load it with load_stdcall_plugin or loadcplugin.
Old 29th July 2007, 17:57   #65  |  Link
buzzqw
HDConvertToX author
would be possible to build with standard interface ? with loadplugin ? is more handy
thanks
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 29th July 2007, 18:18   #66  |  Link
ajp
Sorry 'bout that, I had no idea there was such a thing...
Now I get 'access violation' though, maybe I'm doing something wrong...
Old 29th July 2007, 21:53   #67  |  Link
Myrsloik
Myrsloik's Avatar
Another updated version has been released that fixes lots of trivial typos in the code that have shown up through the versions and adds aac and ac3 decoding support to the included libavcodec.
The website is also hosted at a real webspace provider now so the download speeds should be much better.
Old 29th July 2007, 22:26   #68  |  Link
ajp
The ffmpegsource.dll is still dated 07/18/2007 and says 'audio codec not found' when fed a source with ac3? Still v1.4? Other than that, can't wait to try the new one...
Old 29th July 2007, 22:54   #69  |  Link
Myrsloik
Myrsloik's Avatar
No, it's the right one and it works here. Check the version number listed in the documentation if you think you've somehow gotten an older version.
Old 29th July 2007, 22:59   #70  |  Link
ajp
Hmmm, that's weird.. now it's the correct version. Maybe I had it cached or something... thanks!
Old 30th July 2007, 07:21   #71  |  Link
ajp
Can't get audio (ac3) to work in .mkv files, I just get silence. I also get a lot of messages when encoding that it's ignoring certain matroska headers. VOB seems to work and .avi with ac3 as well. Also, the audio cache gets pretty huge, is that normal?
Old 30th July 2007, 12:08   #72  |  Link
Myrsloik
Myrsloik's Avatar
New version uploaded that should fix ac3 and some other audio formats in matroska.
It's normal that the audio cache is huge since the whole file is stored as raw pcm in it. It's also why audio isn't opened by default.
Old 30th July 2007, 12:20   #73  |  Link
ajp
Wow, that was quick! I'm beginning to feel like a pain in the rear... Makes sense about the audio, better than demuxing it myself anyway... cheers!
Old 30th July 2007, 12:26   #74  |  Link
ajp
Now I get "System exception - Stack overflow" with .mkv...
Old 30th July 2007, 12:41   #75  |  Link
Myrsloik
Myrsloik's Avatar
Exactly what does the mkv contain? Could you cut a piece of it and upload to ftp://upload:upload@mellbin.org ?
Old 30th July 2007, 12:48   #76  |  Link
ajp
It contains just an AVC/H264 video stream and the AC3 stream...
Uploading a sample shortly...
Old 30th July 2007, 13:02   #77  |  Link
Myrsloik
Myrsloik's Avatar
It works here. Did you try deleting all old cache files?
Old 30th July 2007, 13:09   #78  |  Link
ajp
Yes, deleted all old cache files. I'll reboot my machine shortly too just in case...
What commandline did you use in your .avs?
Old 30th July 2007, 13:21   #79  |  Link
ajp
Doh! It was only when playing the .avs in WMP11, MPC works fine...
Another problem (surprise).. now my wmcmd.vbs won't recognize the audio format, I guess that's because it's 6ch PCM and not 6ch WAV?
Edit: Ah, enabling ffdshow raw audio took care of the wmcmd.vbs problem...
Old 30th July 2007, 18:17   #80  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I don't have a problem with the audio cache, if random access methods are going to cause problems. But would it be possible to either pass each block through zlib first, or designate the file as compressed? (ie, by passing FILE_ATTRIBUTE_COMPRESSED to CreateFile.) Doesn't help much, but since disk i/o will be the big blocker there, it'll help some.
