Thread Tools Display Modes
Old 30th December 2024, 07:38   #381  |  Link
taurusus
It happens in different ways, some are disabled in classes, sometimes in text documents, maybe in MovieObject.bdmv or bdjo files need to watch the entire disc, it's easier to replace the video itself with something else.
taurusus is offline   Reply With Quote
Old 30th December 2024, 22:19   #382  |  Link
palestina
Originally Posted by terrorindeed View Post
Any idea how to disable fbi warning before mainfeature playback or onresume ?
You can do this with BDedit.
Modify the times in the "PLAYLIST" tab of the MPLS that calls the warning.
palestina is offline   Reply With Quote
Old 31st December 2024, 14:18   #383  |  Link
terrorindeed
Im fairly new to bdedit, Im in PLAYLIST, have the mpls responsible,the only area i see time, IN time and OUT Time, allows me to double click, then im in clipinf, not sure how to proceed after that. im using bdedit 0.58b11
terrorindeed is offline   Reply With Quote
Old 31st December 2024, 17:00   #384  |  Link
Lowpro
Each of the fields for a given PlayItem are editable. Right click and select "Edit Mode" or use the keyboard shortcut, Ctrl+E. Once in "Edit Mode" update the "OUT time" so that it mirrors the "IN time". This will set the length of the PlayItem to 00:00:00.000 effectively skipping over it. If the playlist contains additional PlayItems you plan to retain just delete (Shift+Del) the PlayItem in question instead if you like, then saving your changes via the "Save" button in the lower left corner.
Old 2nd January 2025, 18:34   #385  |  Link
terrorindeed
Thanks Lowpro!. Your method didn't quite work, but I was able to get around the issue. I first changed the playitem OUT time to match the total length of a 0.250 second blank black mt2s file. Then Saved the change. I then removed the 00709 m2ts, and replaced it with my 0.250 second m2ts, renamed to 00709 and began playback. No more warning video !
Old 2nd January 2025, 20:31   #386  |  Link
Lowpro
Yep, replacing the video works too. And again, you can adjust the IN time and OUT time to play whatever portion of the given video that you'd like effectively accomplishing the same thing.
Old 12th January 2025, 00:59   #387  |  Link
ernnnn
Hi!
I´m dealing with an UHD disc with just the BACKUP, CLIPINF, META, PLAYLIST and STREAM folders inside the BDMV folder. The only one containing something similar to the menu, is the META folder, containing a folder called DL with three files inside, two jpgs with the menu background in different shapes, and a xml file. I assume I have to edit that xml file, but I don't know where to start, as I usually deal with Java menus containing pngs. It's a Netflix disc, FYI.
Thanks for any info regarding how to deal with this kind of menu.
ernnnn is offline   Reply With Quote
Old 12th January 2025, 01:45   #388  |  Link
Lowpro
Originally Posted by ernnnn View Post
Hi!
The META folder is not related to the menus. It's where metadata is stored. When inserting the disc in a game console for example, the name of the disc and thumbnail shown are acquired from the META folder. Menus which are not java based are located in the STREAM folder. They're stored within M2TS files and can be viewed/edited using BDedit.
Old 12th January 2025, 11:43   #389  |  Link
ernnnn
First of all, thank you very much for your help.
According to your message, the menu is divided into two different M2TS, with different screen sizes. Is there any tutorial where I could find out how to deal with them? I don't know where to start on BDedit, as although I use it, not that deeply.
EDIT: I have found the buttons on BDedit. Is it possible to edit the text directly on BDedit or do I have to do it with photoshop or Scenarist?
Thanks in advance!
Old 12th January 2025, 18:16   #390  |  Link
Lowpro
Thanks in advance!
It's a bit more complicated than that. The objects (images) used by the given IG (menu) are accessed from the "Objects" tab of the IG. From the "Objects" tab one or more objects can be exported using the "Save object image" option and imported using the "Load object image" option, the existing object and/or palette being replaced on import if the "Replace the selected object" and/or "Replace the selected palette" options are checked.
Once importing (Load object image) the updated object you'd update the M2TS file in question using the "Mux" option. Once mux'ing out the associated CLPI file may need updated as well. (Make sure the "Ask to correct packet size in ClipInfo" option is checked from the OPTIONS tab.) BDedit will update the CLPI file for you if needed. It doesn't happen when mux'ing out however. Once mux'ing out go to the "BDMV" tab and "Read" the Blu-ray fresh, then going to the "CLIPINF" tab selecting the CLPI file in question. If the CLPI file needs updated BDedit will display a prompt offering to update the CLPI for you.
That being said, there's one huge catch to all of this. Menus for HDMV based Blu-ray's have limitations regarding the images used as compared to BD-J. The images for HDMV based Blu-ray's are limited to 256-color 8-bit indexed PNG's. Also, every object (image) used for a given menu page must be using the same color palette. As such, there are two methods which can be used to replace an object within an IG.
You can export (Save object image) the object in question and its palette (Save palette), then applying the exported palette to the updated version of the image prior to import back to the IG. The other method would be to export all objects that use the same color palette, update the object in question, then process all exported objects using PNG Quantizer importing the resulting images back to the IG, PNG Quantizer having created a 256-color 8-bit indexed copy of all the images, the same color palette being applied to each image.
And this may not work out, but you can try it. Export the objects (images) in question and update them, then import the objects back to the IG replacing the existing objects, but not the color palette. This will add a new color palette to the IG which can then be deleted (Shift+Del). Mux out at that point, then reading the Blu-ray fresh returning to the IG. Once back at the IG select the updated objects from the "Objects" tab to see if they're being displayed correctly using the original color palette. If so, you're good to go. If not, one of the methods described previously would need to be used.
Old 19th January 2025, 02:03   #391  |  Link
terrorindeed
Im running into an issue with a menu conversion. I have mapped out the words, but I am looking to center all 4 of the words properly. In the xml file, I can specify their coordinates like x,y. But that has no bearing on where they show up in the menu, just what is made visible. Anyone know what I am looking for in the .class file? I have set all parameters correctly, so that all words are now visible, several were 3 times the size of the original. But I would like those new words to be better centered.
Old 19th January 2025, 05:45   #392  |  Link
taurusus
terrorindeed
Hi, to find the desired class in the jar file, you need luyten-0.5.4. You insert the button name from the xml file into the search. So you can find a class where the button sizes are duplicated from xml, but there may be another class where the button coordinates are specified in the menu, you can find it by the menu name "Main Menu", "Settings", "Setup", "Audiolist", it happens in different ways.
Old 19th January 2025, 07:11   #393  |  Link
terrorindeed
Originally Posted by taurusus View Post
terrorindeed
Hey thanks for the reply. I believe I have found them. Ive taken screenshots and now loaded them into GIMP to confirm they are the mapped coordinates for the buttons. I've modified the .class already to allow for larger texts in the menu, ie bipush to sipush, so hopefully this allows me to move around the buttons. Thanks!
Old 21st January 2025, 20:54   #394  |  Link
terrorindeed
Now a new issue.
If I remove the original japanese audio track, replacing it with a french audio track, the Scenes no longer match up. From the menu, if I select Scene 2, Scene 3 loads etc. If I select Scene 15 or higher (up to 26), nothing happens.
Old 21st January 2025, 21:15   #395  |  Link
taurusus
In which program did you change the road?
Old 21st January 2025, 21:20   #396  |  Link
terrorindeed
tsmuxer to extract the french dolby 5.1
txmuxer to remove japanese audio, and add french,
tsxmuer bluray folder
Old 21st January 2025, 21:59   #397  |  Link
taurusus
Have you opened a playlist or m2ts in tsMuxeR?
Old 21st January 2025, 23:47   #398  |  Link
ocean
Hi taurusus, It could also be playlist Mark:
ocean is offline   Reply With Quote
Old 22nd January 2025, 02:49   #399  |  Link
terrorindeed
I have scenes 1-14 working as they should. But now scenes 15-26 are not selectable.
As far as I can tell, I have set hexeditor correctly for the original playlist.
Not sure where the error is coming from.
Old 22nd January 2025, 02:51   #400  |  Link
terrorindeed
I'm working with a 3D BluRay, so I have 2 playlists in question.
Should both Playlist Mark points be identical?
I will take a look shortly and post back.
Thread Tools
