4th August 2009, 20:56 | #61 | Link |
@Chengbin: What DS (as I understood) is saying is that CRF most probably hasn't shifted by a constant value but it has entirely changed and this change cannot easily be described on basis of one encoding sample. You simply need to find a new CRF that meets your demands, but I think you always have to if you don't want to waste bitrate or lack quality in the end.
4th August 2009, 22:20 | #62 | Link |
its sad that this is my first post, but x264_mbtree keeps crashing with one input file ... The crash occurs around frame 2-20 ... Already tried to reduce lookahead to 0. commandline: Code:
C:\Dokumente und Einstellungen\Fire>"D:\$Test\temp\x264_mbtree11.exe" --lookahea d 0 --pass 1 --mbtree --ref 2 --bitrate 500 --qcomp 0.95 --bframes 3 --b-adapt 2 --mixed-refs --no-fast-pskip --weightb --direct auto --subme 10 --trellis 2 --p artitions all --8x8dct --me umh --merange 32 --nr 50 --stats "D:\$Test\temp\test 2.avs.mbtree.stats" --threads 1 --thread-input -o "D:\$Test\temp\test2.avs.mbtre e.mkv" "D:\$Test\temp\test2.avs" avis [info]: 1280x720 @ 23.98 fps (1750 frames) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile Main, level 3.1 [0.2%] 4/1750 frames, 43.01 fps, 0.00 kb/s, eta 0:00:40 Code:
C:\Dokumente und Einstellungen\Fire>"D:\$Test\temp\x264_mbtree11.exe" -o D:\$Tes t\temp\test2.avs.mkv D:\$Test\temp\test2.avs avis [info]: 1280x720 @ 23.98 fps (1750 frames) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 3.1 [0.1%] 2/1750 frames, 32.26 fps, 0.00 kb/s, eta 0:00:54 Code:
D:\$Test\temp>gdb.exe D:\$Test\temp\x264_mbtree11_debug.exe GNU gdb (GDB) 6.8.50.20090804 Copyright (C) 2009 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i386-pc-mingw32". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. This binary was built by Equation Solution <http://www.Equation.com>... (gdb) run -o a.mkv test2.avs Starting program: D:\$Test\temp\x264_mbtree11_debug.exe -o a.mkv test2.avs [New Thread 4472.0x12e4] warning: Can not parse XML library list; XML support was disabled at compile tim e [New Thread 4472.0x1248] [New Thread 4472.0x1208] [New Thread 4472.0x264] [New Thread 4472.0x858] [New Thread 4472.0xf90] warning: HEAP[x264_mbtree11_debug.exe]: warning: Invalid Address specified to RtlFreeHeap( 00240000, 00FAF174 ) Program received signal SIGTRAP, Trace/breakpoint trap. 0x7c91120f in ?? () (gdb) bt #0 0x7c91120f in ?? () #1 0x7c97c201 in ?? () #2 0x0022ebe8 in ?? () #3 0x7c97c63e in ?? () #4 0x00faf16c in ?? () #5 0x00240000 in ?? () #6 0x00faf174 in ?? () #7 0x0022ec5c in ?? () #8 0x7c97d826 in ?? () #9 0x00240000 in ?? () #10 0x00faf16c in ?? () #11 0x7c97d9dc in ?? () #12 0x00240000 in ?? () #13 0x00faf174 in ?? () #14 0x40000060 in ?? () #15 0x00000040 in ?? () #16 0x00f37e48 in ?? () #17 0x003e0000 in ?? () #18 0x003e0000 in ?? () #19 0x007d0037 in ?? () #20 0x0101ecec in ?? () #21 0x0022ebd8 in ?? () #22 0x0022ebdc in ?? () #23 0x0022ed10 in ?? () #24 0x00014320 in ?? () #25 0x00faf16c in ?? () #26 0x00240000 in ?? () #27 0x7c97d994 in ?? () #28 0x7c959e1c in ?? () #29 0x00010000 in ?? () #30 0x0022ebfc in ?? () #31 0x7c937764 in ?? () #32 0x0022ed34 in ?? () #33 0x7c91e900 in ?? () #34 0x7c97d9b8 in ?? () #35 0x00000001 in ?? () #36 0x0022ed44 in ?? () #37 0x7c959e1c in ?? () #38 0x00240000 in ?? () #39 0x50000061 in ?? () #40 0x00faf174 in ?? () #41 0x00240000 in ?? () #42 0x00faf174 in ?? () #43 0x40000060 in ?? () #44 0x40000060 in ?? () #45 0x7c92003d in ?? () #46 0x00efa744 in ?? () #47 0x00efa740 in ?? () #48 0x00240000 in ?? () #49 0x0022ed60 in ?? () #50 0x7c91e900 in ?? () #51 0x7c937768 in ?? () #52 0xffffffff in ?? () #53 0x7c937764 in ?? () #54 0x7c007553 in ?? () #55 0x003e0000 in ?? () #56 0x0022ebf0 in ?? () #57 0x7c92003d in ?? () #58 0x0022ed84 in ?? () #59 0x7c91e900 in ?? () #60 0x7c937768 in ?? () #61 0xffffffff in ?? () #62 0x7c937764 in ?? () #63 0x7c937553 in ?? () #64 0x00240000 in ?? () #65 0x40000060 in ?? () #66 0x7c92003d in ?? () #67 0x00e98f4c in ?? () #68 0x0022edd8 in ?? () #69 0x00e95038 in ?? () #70 0x0022ec40 in ?? () #71 0x003e0000 in ?? () #72 0x003e0000 in ?? () #73 0x7c91e900 in ?? () #74 0x7c920040 in ?? () #75 0xffffffff in ?? () #76 0x7c92003d in ?? () #77 0x7c001432 in ?? () #78 0x7c001463 in ?? () #79 0x0022ec4c in ?? () #80 0x00240000 in ?? () #81 0x0022ede0 in ?? () #82 0x7c91e900 in ?? () #83 0x7c937768 in ?? () #84 0xffffffff in ?? () #85 0x7c937764 in ?? () #86 0x7c007553 in ?? () #87 0x003e0000 in ?? () #88 0x0022ec70 in ?? () #89 0x7c92003d in ?? () #90 0x0022ee04 in ?? () #91 0x7c91e900 in ?? () #92 0x7c937768 in ?? () #93 0xffffffff in ?? () #94 0x0022ee14 in ?? () #95 0x7c937553 in ?? () #96 0x00240000 in ?? () #97 0x40000060 in ?? () #98 0x00faf174 in ?? () #99 0x0022eea8 in ?? () #100 0x00f37e90 in ?? () #101 0x00f08ca8 in ?? () #102 0x0022ed44 in ?? () #103 0x0022f218 in ?? () #104 0x0022f218 in ?? () #105 0x0022ed54 in ?? () #106 0x000113d8 in ?? () #107 0x0022f218 in ?? () #108 0x0022ecd8 in ?? () #109 0x77be2070 in ?? () #110 0x0022f218 in ?? () #111 0x7c91e900 in ?? () #112 0x7c920040 in ?? () #113 0xffffffff in ?? () #114 0x7c92003d in ?? () #115 0x774cd01c in ?? () #116 0x00240000 in ?? () #117 0x00000000 in ?? () Code:
DirectShowSource("X:\test.mp4",audio=false) LoadPlugin("D:\***\UnDot.dll") UnDot() ConvertToYV12() SelectRangeEvery(5000,250) If you need more information/i should try something then tell me ^^ |
4th August 2009, 22:32 | #64 | Link |
thx for the quick response ... could you also tell me how i get my avs input to a raw yuv file? thx
found avs2yuv.exe .. tried like this: avs2yuv.exe test2.avs -raw -o test2.yuv put also crashes ... maybe its avisynth ... Code:
AppName: avs2yuv.exe AppVer: 0.0.0.0 ModName: avisynth.dll ModVer: 2.5.7.0 Offset: 000168f0 Last edited by Firethe1; 4th August 2009 at 23:08. |
4th August 2009, 23:42 | #66 | Link |
Novice x264 User
Tests on some anime I have are looking good so far!
Even at lower bitrates, an aq and psy-rd value of 1.0 doesn't create as much horrible artifacts as before. Testing with --tune animation now.
"I'll take a potato chip... and eat it!" Last edited by Yoshiyuki Blade; 4th August 2009 at 23:49. |
5th August 2009, 00:16 | #67 | Link | |
If one encoding says with the same CRF value an encoding dropped 35% in bitrate than the unpatched, that means the same CRF value gives lower bitrate encodes. Of course with different sources the percentage will differ, but I seriously doubt it will vary much, let alone 35%. How about as a suggestion, when CRF changes, can you tell us what is the new "CRF 18"? |
5th August 2009, 00:30 | #68 | Link |
x264aholic
Why don't you do some testing? Go pick out a bunch of clips, test them with and without mbtree.
Find what the average change in crf is, then you'll know. I know you think that it might not vary much, but the only way you can really prove that is by testing more than one source. Otherwise, I could pull out a source and say "Hey, I think this changes the crf upwards by 5" which could be completely wrong. I'd do testing myself, but I don't have the time for it at the moment (Going away on vacation soon). If anyone is willing to do the testing, you or otherwise, it would be useful for everyone.
You can't call your encoding speed slow until you start measuring in seconds per frame. |
5th August 2009, 00:30 | #69 | Link | ||
5th August 2009, 00:58 | #70 | Link | |
If I did testing (which I did for AutoVAQ with all kinds of sources), by the time I finished with AutoVAQ testing (which is a few weeks ago), my data is obsolete because of mbtree. Who knows when another change could happen. Maybe an update to mbtree will change CRF again. I think you can understand why I'm asking. Just to keep the thread on topic, are there any compression improvements with this patch? Or is it visuals only? Last edited by Chengbin; 5th August 2009 at 01:02. |
5th August 2009, 01:53 | #71 | Link |
Insane Encoder
plz learn to read...
if metrics increase it means that's a compression improvement. metrics almost always go down when it's visually (aq PSNR goes down, psyrd / trellis both go down...) And the change at the crf value may happend until the commit of this patch, this is a TEST patch, and everything that is true today may be wrong tomorow. It's not for real encoding, but to see what it does, where it fails, where it does great and improve this path before he got commited
Only two things are infinite, the universe and human stupidity, and I’m not sure about the former. |
5th August 2009, 05:16 | #72 | Link |
x264aholic
Yes, mbtree should improve quality, visually and metrically speaking.
It might not be as easy to judge in crf mode given the wide fluctuations we've seen, but it should be optimal when it comes out of testing.
5th August 2009, 07:09 | #75 | Link | |
x264 developer
Fast and above (medium, slow, etc) have it on. |
5th August 2009, 07:21 | #77 | Link | |
x264 developer
Currently I don't think MB-tree with pyramid is a good idea as long as we allow referenced B-frames to end up in the reference list. |
5th August 2009, 07:45 | #78 | Link | ||
Commandline used: Quote:
avis [info]: 1280x720 @ 25.00 fps (35001 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cach e64 x264 [info]: profile High, level 4.1 x264 [info]: slice I:2212 Avg QP:19.00 size: 73712 PSNR Mean Y:46.71 U:50.33 V:50.92 Avg:47.62 Global:46.51 x264 [info]: slice P:12247 Avg QP:21.08 size: 32098 PSNR Mean Y:43.76 U:47.87 V:48.92 Avg:44.78 Global:43.59 x264 [info]: slice B:20542 Avg QP:22.86 size: 10825 PSNR Mean Y:43.02 U:47.50 V:48.58 Avg:44.09 Global:43.19 x264 [info]: consecutive B-frames: 4.1% 18.0% 57.1% 20.8% x264 [info]: mb I I16..4: 8.2% 84.8% 7.0% x264 [info]: mb P I16..4: 1.8% 14.8% 0.6% P16..4: 44.0% 20.5% 13.5% 0.2% 0 .2% skip: 4.5% x264 [info]: mb B I16..4: 0.5% 1.9% 0.1% B16..8: 42.1% 1.6% 2.4% direct: 9.2% skip:42.3% L0:35.6% L1:48.1% BI:16.3% x264 [info]: 8x8 transform intra:84.6% inter:74.8% x264 [info]: direct mvs spatial:76.3% temporal:23.7% x264 [info]: coded y,uvDC,uvAC intra:80.9% 80.7% 46.4% inter:30.4% 32.1% 3.9% x264 [info]: ref P L0 78.9% 11.5% 5.4% 2.2% 1.3% 0.7% x264 [info]: ref B L0 85.2% 8.9% 3.6% 1.5% 0.9% x264 [info]: SSIM Mean Y:0.9784036 x264 [info]: PSNR Mean Y:43.516 U:47.805 V:48.844 Avg:44.553 Global:43.481 kb/s: 4448.60 encoded 35001 frames, 4.39 fps, 4448.63 kb/s Encode with --mbtree Code:
avis [info]: 1280x720 @ 25.00 fps (35001 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cach e64 x264 [info]: profile High, level 4.1 x264 [info]: slice I:2211 Avg QP:18.28 size: 89332 PSNR Mean Y:47.28 U:50.78 V:51.30 Avg:48.17 Global:47.36 x264 [info]: slice P:12255 Avg QP:21.25 size: 32438 PSNR Mean Y:43.83 U:47.96 V:48.98 Avg:44.85 Global:43.92 x264 [info]: slice B:20535 Avg QP:24.79 size: 8944 PSNR Mean Y:43.01 U:47.53 V:48.62 Avg:44.07 Global:43.39 x264 [info]: consecutive B-frames: 4.2% 17.4% 59.0% 19.5% x264 [info]: mb I I16..4: 10.8% 79.8% 9.4% x264 [info]: mb P I16..4: 1.9% 15.0% 0.6% P16..4: 43.2% 19.4% 13.4% 0.2% 0 .3% skip: 6.0% x264 [info]: mb B I16..4: 0.4% 1.8% 0.1% B16..8: 40.3% 1.4% 1.8% direct: 6.0% skip:48.2% L0:37.7% L1:47.7% BI:14.6% x264 [info]: 8x8 transform intra:82.3% inter:74.7% x264 [info]: direct mvs spatial:72.8% temporal:27.2% x264 [info]: coded y,uvDC,uvAC intra:80.6% 80.1% 48.2% inter:26.1% 26.6% 3.5% x264 [info]: ref P L0 78.7% 11.7% 5.5% 2.2% 1.3% 0.7% x264 [info]: ref B L0 86.5% 8.1% 3.3% 1.3% 0.8% x264 [info]: SSIM Mean Y:0.9790297 x264 [info]: PSNR Mean Y:43.564 U:47.884 V:48.917 Avg:44.603 Global:43.742 kb/s: 4449.59 encoded 35001 frames, 4.41 fps, 4449.62 kb/s But other than that, all went as if nothing changed. My STD ran these files as usual (no change noticed), and visual quality was about the same (with a slight plus on the --mbtree side). Will run another encode with some different parameters while i'm at work (with/without VAQ). I'll post about those when i get back from work. Last edited by G_M_C; 5th August 2009 at 10:05. |
5th August 2009, 08:29 | #79 | Link | |
MPC-HC Project Manager
This might raise b-frame and b-pyramid compatibility with standalone devices! (or break them)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
5th August 2009, 10:47 | #80 | Link |
x264_x86_r1195_juGGaKNot
GCC 4.4.0, modified, fprofiled, patched Code:
Source: GIT Applied patches : x264_win_zone_parse_fix_05.diff x264_hrd_pulldown.15_interlace.diff x264_Macroblock_Tree_Ratecontrol_013.diff x264_juGGaKNot_preset_01.diff ( This just adds a preset, juggaknot, download it to see the settings ) It is fprofiled on a uncompressed 300 frames source with very high motion Please check Doom9.org patches thread, Doom9.org Macroblock tree Ratecontrol thread and GIT shortlog for more info. Compiled by juGGaKNot with GCC 4.4.0 on Windows XP SP-2 32-bit. Platform: X86 System: MINGW asm: yes avis input: yes mp4 output: yes pthread: yes debug: no gprof: no PIC: no shared: no visualize: no Last edited by juGGaKNot; 5th August 2009 at 13:38. |
development, testing, x264 |
