Thread Tools Display Modes
Old 6th August 2012, 18:48   #41  |  Link
sneaker_ger
Try the complete path, not just the filename.
Old 6th August 2012, 18:58   #42  |  Link
wcwman18
Did not work
avs [error]: Unable to load C Plugin: C:\Program Files (x86)\AviSynth 2.5\plugin
s\ffms2.dll
(ufcfoxpost_x264.avs, line 1)
x264 [error]: could not open input file `post_x264.avs'
Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll")
Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll")
FFVideoSource("post.ts")
ConvertToYV12()
Yadif(0,1)
Lanczos4Resize(704,400,6,6,-6,-6)
wcwman18 is offline   Reply With Quote
Old 6th August 2012, 19:31   #43  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Either the path to the DLL is wrong or it's not actually a C plug-in (but a regular C++ plug-in). Or your are trying to load a 64-Bit plug-in from 32-Bit Avisynth (or vice versa).
Old 6th August 2012, 19:52   #44  |  Link
wcwman18
Since I am trying to use your software can you make sense of this?
Simple x264 Launcher (Build #346), built 2012-07-22
Job started at 2012-08-06, 14:49:13.
Source file: C:/Users/Owner/Desktop/AVSMeter1.21/AVSMeter1.21/post_x264.avs
Output file: C:/Users/Owner/Desktop/AVSMeter1.21/AVSMeter1.21/post_x264.mkv
--- SETTINGS ---
RC Mode: ABR
Preset:  Medium
Tuning:  Film
Profile: Auto
Custom:  (None)
--- CHECK VERSION ---
Creating process:
"C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/x264_8bit_x64.exe" --version
x264 0.125.2208 d9d2288
(libswscale 2.1.100)
(libavformat 54.17.100)
(ffmpegsource 2.17.2.1)
built by Komisar on Jul 19 2012, gcc: 4.7.1 (multilib.generic.Komisar)
configuration: --bit-depth=8 --chroma-format=all
x264 license: GPL version 2 or later
libswscale/libavformat/ffmpegsource license: GPL version 2 or later
Creating process:
"C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/avs2yuv_x86.exe"
Avs2YUV 0.24bm2
x264 revision: 2208 (core #125)
Avs2YUV version: 0.24.2
--- AVS INFO ---
Creating process:
"C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/avs2yuv_x86.exe" -frames 1 C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\post_x264.avs NUL
C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\post_x264.avs: 704x400, 60001/1001 fps, 189712 frames
Resolution: 704x400
Frame Rate: 60001/1001
No. Frames: 189712
--- ENCODING ---
Creating Avisynth process:
"C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/avs2yuv_x86.exe" C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\post_x264.avs -
Creating x264 process:
"C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/x264_8bit_x64.exe" --bitrate 1500 --preset medium --tune film --output C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\ufcfoxpost_x264.mkv --frames 189712 --demuxer y4m --stdin y4m -
y4m [info]: 704x400p 0:0 @ 60001/1001 fps (cfr)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT
x264 [info]: profile High, level 3.1
x264 [info]: frame I:1 Avg QP:27.09 size: 785
x264 [info]: mb I I16..4: 24.9% 75.1% 0.0%
x264 [info]: final ratefactor: 27.29
x264 [info]: 8x8 transform intra:75.1%
x264 [info]: coded y,uvDC,uvAC intra: 3.2% 6.1% 0.0%
x264 [info]: i16 v,h,dc,p: 53% 34% 7% 6%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 38% 33% 0% 0% 0% 0% 0% 0%
x264 [info]: i8c dc,h,v,p: 91% 5% 4% 0%
x264 [info]: kb/s:376.43
encoded 1 frames, 0.04 fps, 729.36 kb/s
WARNING: Avisynth process exited with error code: -1073741819
Final file size is 1,730 bytes.
--- DONE ---
Job finished at 2012-08-06, 14:49:48. Process took 0 minutes, 35 seconds.
Old 6th August 2012, 20:07   #45  |  Link
wcwman18
Am I getting closer?
LoadCPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll")
FFIndex(C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\ffmsindex.exe)
AudioDub(FFVideoSource(post.ts), FFAudioSource(post.ts))
ConvertToYV12()
Yadif(0,1)
Old 6th August 2012, 20:27   #46  |  Link
detmek
Can you try this way?
Remove your FFMS2 plugin and unpack this one into your Avisynth plugin folder, both files http://megui.org/auto/ffms2-r683.7z
Use this script:
Load_Stdcall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll")
a = FFAudioSource("post.ts")
v = FFVideoSource("post.ts")
AudioDub(v,a)
ConvertToYV12()
Yadif(0,1)
P.S. You may need Haali Media Splitter to properly open TS file.
detmek is offline   Reply With Quote
Old 6th August 2012, 20:54   #47  |  Link
wcwman18
Use this script:
Job started at 2012-08-06, 15:33:56.
--- SETTINGS ---
RC Mode: ABR
Preset: Medium
Tuning: Film
Profile: Auto
Custom: (None)
Creating process:
Creating process:
Avs2YUV 0.24bm2
--- AVS INFO ---
Creating process:
error: Evaluate: Unrecognized exception!
(C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\post_x264.avs, line 2)
PROCESS EXITED WITH ERROR CODE: 1
With a CMD Prompt
avs [error]: Evaluate: System exception - Access Violation
(post_x264.avs, line 2)
Just installed avisynth 2.5.8 same issue
Old 6th August 2012, 21:56   #48  |  Link
LoRd_MuldeR
Software Developer
Looks like Avisynth (or more likely one of the plug-ins involved) has crashed.
Do you use the "stable" Avisynth 2.5? If not, I would suggest trying with that one first:
http://sourceforge.net/projects/avis...Synth%202.5.8/
Furthermore you should clean up your Avisynth plug-ins directory. I encountered strange crashes with "buggy" plug-in DLL's, even when that plug-in wasn't even used in the script.
Also you may want to kick out Yadif for now (you can re-add it later). Last but not least you may want to try the last official FFMS2 release from here.
Old 6th August 2012, 23:11   #49  |  Link
wcwman18
Thank you. That did the trick. Sadly that even with the presets I still only get 16-18fps while encoding video
Old 6th August 2012, 23:45   #50  |  Link
LoRd_MuldeR
Software Developer
Using the Preset system does not speed-up things per se!
The x264 presets simply provide a very convenient and foolproof way to tweak the "speed -vs- quality" trade-off. If your goal is to squish out more speed, you have to switch from your current preset to a faster one.
If switching, e.g., from "slower" to "faster" preset doesn't give a significant speed-up, you are very likely bottlenecked by slow input. As mentioned earlier, you can benchmark your AVS script with AVSMeter...
(You certainly won't be able to encode any faster than what AVSMeter reports for your input script, even with the "ultrafast" preset)
Old 7th August 2012, 00:17   #51  |  Link
wcwman18
Is their any ways to fix bottle necking? 16-18fps takes forever.
Here is my current set up if you have any ideas for me to try.
I use a HD PVR and it records 1920 x 1080 at 13.5mbps. It records to a .ts file that I then edit in videoredo. Then I encode that edited file with x264. Any other details that might help?
Old 7th August 2012, 01:26   #52  |  Link
Groucho2004
Several options (not mutually exclusive):
- Get a faster CPU/MB
- Use DGDecodeNV to offload decoding and de-interlacing
- Use a faster de-interlacer
Old 7th August 2012, 01:33   #53  |  Link
wcwman18
I don't have a nvidia card. How might I use a faster deinterlacer?
Old 7th August 2012, 01:51   #54  |  Link
Groucho2004
I thought yadif is pretty fast so I don't really know what to recommend that is faster and doesn't suck. Search the forum.
Whenever I need to de-interlace I use QTGMC which is in a completely different league in terms of quality. But it's also quite slow. It does have fast modes but I don't know how those compare to yadif.
Old 7th August 2012, 02:37   #55  |  Link
wcwman18
Here is my current PC if anyone can look at the specs and recommend anything. Maybe Avisynth MT?
http://h20000.www2.hp.com/bizsupport...odTypeId=12454
Old 7th August 2012, 02:51   #56  |  Link
AnonCrow
Crazy idea: Don't deinterlace, remove those lines from the avisynth script, add the necessary option to your x264 commandline to encode as interlaced, then see what kind of speeds and CPU usage you get. Deinterlace during playback if necessary.
Or get a ~30-70 € Nvidia card (about the same speed or slightly faster than your current Radeon that it would replace)
AnonCrow is offline   Reply With Quote
Old 7th August 2012, 03:18   #57  |  Link
wcwman18
Can't deinterlace during playback. I stream this files in my flash media player.
Old 7th August 2012, 07:59   #58  |  Link
Groucho2004
QTGMC and Avisynth MT are probably worth a try, considering that you have 6 CPU cores to play with.
Old 7th August 2012, 14:44   #59  |  Link
LoRd_MuldeR
Software Developer
Yadif probably is the fastest (software) deinterlacer you want to use.
Even faster would be a simple "Bob()" or a "SeparateFields().SelectEven()" followed by a resize, but result won't be nice.
I second the suggestion to get a cheap NVidia card plus DGDecodeNV and use hardware deinterlacing...
Old 7th August 2012, 15:42   #60  |  Link
wcwman18
Is their a faster way since my files capture in h264 that I can make AAC 192 audio and mp4 x264 without the long encode?
Thread Tools
