#21 | Link |
Software Developer
![]() Join Date: Jun 2005
I don't know how your script looks, but a simple FFMS2 script would look like:
V = FFVideoSource("C:\Some Path\input.foo")
A = FFAudioSource("C:\Some Path\input.foo")
AudioDub(V,A)
I would recommend to use DGDecodeNV for accessing TS files, but you'll have to buy it (and it needs an NVidia card). DGAVCIndex is a dead project and has various problems that won't ever get fixed... BTW: You know that you can hit "Edit" instead of writing several posts in sequence !?
#22 | Link | |
LoadPlugin("C:\Users\Owner\Desktop\pack\DG\DGAVCDecode.dll")
Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll")
AVCSource("post.dga")
ConvertToYV12()
Yadif(0,1)
Lanczos4Resize(704,400,6,6,-6,-6)
#23 | Link |
Software Developer
Throw out the AVCSource() and instead insert the code that I just posted. Of course you would give FFVideoSource() the original video file, not the DGA file.
Also throw out the LoadPlugin(). Or, if FFMS2.dll is not located directly in your Avisynth plug-in's folder, change the LoadPlugin() to load FFMS2.dll instead of DGAVCDecode.dll.
#24 | Link | |
Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll") FFVideoSource("post.ts") ConvertToYV12() Yadif(0,1) Lanczos4Resize(704,400,6,6,-6,-6) |
#25 | Link |
Software Developer
If you don't need to load FFMS2.DLL explicitely (because it is in your Avisynth "plugins" folder) and if the file "post.ts" is located in the same folder as your AVS file, then yes.
#27 | Link |
Software Developer
So obviously you do NOT have the required plug-in DLL in your Avisynth "plugins" folder
![]() Put the DLL in place or load it explcitely via LoadPlugin() from wherever it is located...
#28 | Link | |
s\yadif.dll (post_x264.avs, line 2) x264 [error]: could not open input file `post_x264.avs' Line 2 : Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll") Last edited by wcwman18; 6th August 2012 at 16:21. |
#30 | Link | |
Is ffms2-x64.dll the proper plugin? Last edited by wcwman18; 6th August 2012 at 16:37. |
#32 | Link | |
(C:\Users\Owner\Desktop\AVSMeter1.21\AVSMeter1.21\post_x264.avs, line 1) LoadPlugin("C:\Program Files(x86)\AviSynth 2.5\plugins\ffms2.dll") Load_STDCall_Plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll") FFVideoSource("post.ts") ConvertToYV12() Yadif(0,1) Lanczos4Resize(704,400,6,6,-6,-6) PROCESS EXITED WITH ERROR CODE: 1 |
#34 | Link | |
LoadCPlugin(C:\Program Files(x86)\AviSynth 2.5\plugins\ffms2.dll)/Load_STDCall_Plugin(C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll) FFVideoSource("post.ts") ConvertToYV12() Yadif(0,1) Lanczos4Resize(704,400,6,6,-6,-6) I get an error could not open line 1 column 14 Last edited by wcwman18; 6th August 2012 at 18:06. |
#35 | Link |
The slash ( "/" ) was meant as "either or", not an actual slash.
http://avisynth.org/mediawiki/Plugins |
#36 | Link | |
Load_STDCall_Plugin(ffms2.dll) Load_STDCall_Plugin(yadif.dll) FFVideoSource("post.ts") ConvertToYV12() Yadif(0,1) Lanczos4Resize(704,400,6,6,-6,-6) Last edited by wcwman18; 6th August 2012 at 18:25. |
#40 | Link | |
(post_x264.avs, line 1) x264 [error]: could not open input file 'post_x264.avs' Load_STDCall_Plugin("ffms2.dll") Load_STDCall_Plugin(yadif.dll) FFVideoSource("post.ts") ConvertToYV12() Yadif(0,1) Lanczos4Resize(704,400,6,6,-6,-6) |
| Thread Tools | |
| Display Modes | |
