View Poll Results: What version do you prefer?
[+] v0.1 1 4.17%
[+] v0.9 0 0%
[+] v1.0 3 12.50%
[+] v1.9 1 4.17%
[+] v2b1 2 8.33%
[+] v2.0 8 33.33%
[+] v2.1 0 0%
[+] v2.2 8 33.33%
[+] v3.0 1 4.17%
Voters: 24. You may not vote on this poll
Old 24th February 2012, 16:28   #21  |  Link
fred_gaou
fred_gaou's Avatar
Originally Posted by fairchild View Post
Thanks for the update. I started using potplayer again and i'm using your v2.0 dark skin. I remember that setting hotkeys for A B repeat is simple enough and i don't need it in the actual skin.
You're welcome. For A B repeat, you can use the control box. This tool may be useful.
fred_gaou is offline
Old 24th February 2012, 18:21   #22  |  Link
Ishino
Very beautiful the dark skin *o*
Ishino is offline
Old 25th February 2012, 09:45   #23  |  Link
fred_gaou
fred_gaou's Avatar
Originally Posted by pdanpdan View Post
Can you please add the timeline and the play control buttons to the playlist as well, so that one can controll playback from a second monitor with the playlist, with movie window fullscreen on another monitor?
I can't promise but I'll see what I can do about it.
Old 26th February 2012, 21:36   #24  |  Link
mltno
great skin, using latest dark 2.0, but my playlist does not look like yours, originally the logo did not switch either so i had to force it but i see no option for playlist?
Uploaded with ImageShack.us
mltno is offline
Old 5th March 2012, 14:21   #25  |  Link
fred_gaou
fred_gaou's Avatar
can you please add the timeline and the play control buttons to the playlist as well, so that one can controll playback from a second monitor with the playlist, with movie window fullscreen on another monitor?
done !
Old 5th March 2012, 14:32   #26  |  Link
fred_gaou
fred_gaou's Avatar
Custom Potplayers Icons are only available for x86 version. Dowload PotPlayer 1.5.32007 x86 stable - complete french release 2012.02.23.zip then extract PotPlayer.zip and copy PotIcons.dll to your x86 Potplayer installation directory.
And for the + tab instead of *new album, it's due to french localization choice, not to the skin.
I hope I answer your issue.
Old 5th March 2012, 14:42   #27  |  Link
pdanpdan
thank you, I'll check it this evening
It's great - I changed only few things:
- the Close button on the playlist closes the player instead of the playlist
- on right click on stop button - rewind
- on right click on audio track select - subtitle track select
pdanpdan is offline
Old 23rd March 2012, 08:28   #28  |  Link
Defcon
Thank you very much for this great skin! I've just discovered it and didn't know a skin could be so powerful/customizable, things like transparency, control via playlist, the different modes etc is all so nice to use. You must have put in a lot of work on this, it should be the default skin.
Defcon is offline
Old 23rd March 2012, 08:39   #29  |  Link
fred_gaou
fred_gaou's Avatar
Thanks a lot. I'm glad you enjoy it.
Old 27th March 2012, 13:37   #30  |  Link
buzzly
My best skin is 1.0, soft & I like font used for movie timing
buzzly is offline
Old 27th March 2012, 14:41   #31  |  Link
fred_gaou
fred_gaou's Avatar
skin update v2.2
Old 27th March 2012, 22:15   #32  |  Link
fred_gaou
fred_gaou's Avatar
Skin update 2012.03.27
Please download v2.2 again (if you download it before this post), I made some changes:
Skin update 2012.03.27: minor changes
v2.2 (2012/03/27)
+ buttons are more integrated with skin background (see screenshots below)
+ change: subtitle button
+ change: button animation on click improvement
+ fix: hover on playlist button could be frozen in some cases
Old 11th May 2012, 00:18   #33  |  Link
fred_gaou
fred_gaou's Avatar
skin update v2.2.1 is available
Skin update 2012.05.11: minor changes
v2.2.1 (2012/05/11) only for those who experimented problem in audio skin
+ fix: time display in audio skin was limited to 59 min, now limit is 9:59:59 (useful for podcasts)
+ add tooltip for file infos in skin audio (bit rate, codec, etc). kbps text has been removed because it took too much space and broke display in some cases (aac with variable bit rate)
+ visual audio synchronization is available in control box to Sub./Synch./right click
Old 4th October 2012, 12:42   #34  |  Link
ZoNi
ZoNi's Avatar
Originally Posted by fred_gaou View Post
I'm happy to announce that my skins will always be available to download here.
Always?
ZoNi is offline
Old 4th October 2012, 16:44   #35  |  Link
fred_gaou
fred_gaou's Avatar
Not my fault. See this post that explains why potplayer related topic are gone from doom9.
See first post to new links toward skins package.
Old 5th October 2012, 10:20   #36  |  Link
ZoNi
ZoNi's Avatar
Not my fault.
Yes, I know
Thank you for fresh upload.
ZoNi is offline
Old 10th October 2012, 05:06   #37  |  Link
bsw11
The zip you provide seems to have duplicated files and 7Z hangs trying to unzip. I was able to select individual files so I got it to work. Great SKINS!!
My only question is can you provide details on where to save the skins - ie can I put them in their en folder under skins?
And where do I put the fonts for them to work?
Thanks again!
BSW
bsw11 is offline
Old 11th October 2012, 19:33   #38  |  Link
ZoNi
ZoNi's Avatar
I wish this buttons and colors in video skin
ZoNi is offline
Old 29th November 2012, 07:58   #39  |  Link
fred_gaou
fred_gaou's Avatar
Update
New skin major update. See first post.
Give feedback you leechers !
Old 29th November 2012, 08:00   #40  |  Link
fred_gaou
fred_gaou's Avatar
Not me, sorry
You may try to make a fork of the skin and post your own version.
english, french, potplayer, skin
