View Poll Results: What version do you prefer?
[+] v0.1 1 4.17%
[+] v0.9 0 0%
[+] v1.0 3 12.50%
[+] v1.9 1 4.17%
[+] v2b1 2 8.33%
[+] v2.0 8 33.33%
[+] v2.1 0 0%
[+] v2.2 8 33.33%
[+] v3.0 1 4.17%
Voters: 24. You may not vote on this poll
Old 22nd February 2012, 20:38   #1  |  Link
fred_gaou
fred_gaou's Avatar
Potplayer [+] skins
Hi Potplayer users,
Note: See this post that explains why potplayer related topic are gone from doom9. Direct link toward skins package is here but the history post is gone...for now.
Install: Just copy the dsf files you want to test or use in the skins folder under potplayer installation directory. Don't forget to install provided fonts on your system (just google how to install fonts on Windows if you're a very noob)
I'm happy to announce that my skins will always be available to download here.
There are English and French version and foreign users can now easily translate this skin.
v3.0
Playing file through detached playlist
Advanced mode
Audio skin
[url=http://www.flickr.com/photos/21745091@N08/8242628314/]
Advanced mode
Control box is translatable
english
french
More screenshots of my PotPlayer version can be seen here
As my [+] skin has evolved since the first release of my PotPlayer in French in 2011/07/25, I would appreciate that users give me a feedback by participating to the above poll
Note: Tooltip on button may display as xxx | yyy. It means the button has 2 commands : left and right mouse click separated by |.
Translators: Just edit the PotplayerPattern.ini file and post it here.
Last edited by fred_gaou; 3rd December 2012 at 21:31. Reason: Skin update 2012.12.03
fred_gaou is offline
Old 22nd February 2012, 23:27   #2  |  Link
fairchild
Very slick and nice looking skin. If I ever decide to give PotPlayer another whirl, I'll be sure to give it a shot. The only reason I'm not using PotPlayer atm, is because I can't seem to find a way to get Lav Splitter to work with Blu-rays, it always loads it's own splitter even if I add Lav Splitter as preferred filter.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline
Old 23rd February 2012, 02:48   #3  |  Link
ranpha
Why not?
ranpha is offline
Old 23rd February 2012, 03:35   #4  |  Link
fairchild
Originally Posted by ranpha View Post
Why not?
Hmmm. What do you have to do aside from adding Lav Splitter to registered preferred filter? When I do the open Disc/DVD method, it always loads the BDMV I believe it is called splitter.
Old 23rd February 2012, 10:05   #5  |  Link
HoP
HoP's Avatar
please,make an skin with this parts
it should be smaller
[ sorry for my bad english...i can read it very well but cant write it very well :D]
HoP is offline
Old 23rd February 2012, 15:48   #6  |  Link
fred_gaou
fred_gaou's Avatar
[+] Skin 2.0 English & French correction
Please, download again the [+] Skin 2.0. The timebar in audio skin didn't display properly.
Old 23rd February 2012, 15:52   #7  |  Link
fred_gaou
fred_gaou's Avatar
Sorry man, you'll have to choose between the available versions or do it by yourself
cheers
Old 23rd February 2012, 16:03   #8  |  Link
HoP
HoP's Avatar
cheers
ok.thanks anyway
in ver 1.0...a little problem
HoP is offline
Old 23rd February 2012, 18:00   #9  |  Link
fred_gaou
fred_gaou's Avatar
I think the major problem is users can't read useful informations even when they are written in red at the top of the download page. There won't be no problem at all with EN [+] v1.0 if you learn to read !
Old 23rd February 2012, 18:42   #10  |  Link
HoP
HoP's Avatar
1 - first of all i shoud say it was EN [+] v0.1 no EN [+] v1.0...it was my fault...i'm sorry
2 - written in red at the top of the download page:"Note: Install the fonts provided in package to use skin v.1* and above or they will display weird"
now you look at this pic:
you can see???i installed the font before using the skin.
3 - why you are angry??you created an skin and a topic,you not created the world.
4 - goodluck
HoP is offline
Old 23rd February 2012, 19:01   #11  |  Link
fairchild
I just tried your skin and 1.0 works the best for me and has the most features I use. (particularly the extra A-B buttons) The only thing I've noticed so far, any files that have AAC audio, don't work or you didn't add a skin for that format. Not sure.
Old 23rd February 2012, 19:06   #12  |  Link
fred_gaou
fred_gaou's Avatar
Ok, easy guy! I'm not angry, it's all fine. Nobody wants to hurt you. So the problem is not you can't read...but you are dyslexic (you wrote 1.0 instead of 0.1). It's just a joke.
I'll post a fix update in a few minute. [Done]
You killed me
Old 23rd February 2012, 19:09   #13  |  Link
fred_gaou
fred_gaou's Avatar
AAC audio works fine here, I just tried an MKV with that. The problem may come from splitters/filters. I use the integrated one and it works.
Do you have this same problem with other skins?
Old 23rd February 2012, 19:20   #14  |  Link
fairchild
Just checked and you are correct. Simply changing Lav Splitter to the stock one it now displays properly AAC.
Old 23rd February 2012, 19:27   #15  |  Link
HoP
HoP's Avatar
You killed me
i'm sorry man.i didnt want make you sad.very sorry
many thanks for fix update
goodluck and be happy
HoP is offline
Old 23rd February 2012, 20:30   #16  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Note: Install the fonts provided in package and use font smoothing [General > Dialog] to use skin v.1* and above or they will display weird.
Just out of curiosity,
would it be "too difficult" (or "not recommended") to use the custom fonts without installing them?
FWIW, I have a *Not-So-Old* screensaver which creates a .FOT file when its default font is in the same directory ( "./" )
Midzuki is offline
Old 23rd February 2012, 21:02   #17  |  Link
fred_gaou
fred_gaou's Avatar
If there is a possibility now or in a future to use custom font without install them I'll take it. But AFAIK, the potplayer skin architecture doesn't have this feature. But I may be wrong.
Old 23rd February 2012, 21:36   #18  |  Link
pdanpdan
Can you please add the timeline and the play control buttons to the playlist as well, so that one can controll playback from a second monitor with the playlist, with movie window fullscreen on another monitor?
pdanpdan is offline
Old 24th February 2012, 16:03   #19  |  Link
fred_gaou
fred_gaou's Avatar
Skins update 9
download an update for v2.0 and try the new dark skin.
Old 24th February 2012, 16:20   #20  |  Link
fairchild
Thanks for the update. I started using potplayer again and i'm using your v2.0 dark skin. I remember that setting hotkeys for A B repeat is simple enough and i don't need it in the actual skin.
english, french, potplayer, skin
