28th September 2008, 16:24 | #2541 | Link |
me
I did some test encodes with a few 5 minute or so clips. cq21 or cq22 tended to be much larger than 512 (in one case, cq22 was about the same size). In every case, quality was proportional to file size - bigger was better. I watched on PC, not on the Touch
29th September 2008, 20:14 | #2542 | Link |
DGavcdec
@Atak_Snajpera:
I have tried to load a .m2ts file in RipBot264. The file plays fine in mpc & powerdvd. After demuxing RipBot264 shows me a wrong duration & framecount (to less!!) of the movie. After lokking at the batch file ripbot264 has created in the \jobX\ dirextory, ill found out that the program "dgavcdec" (DGAVCINDEX) get the m2ts infos. I have installed the newer version (1.0.1) and loaded the file again. Now it works like a charm What i want to say: Please update dgavcdec in upcomming ripbot264 releases. cu pOpY PS: Is a new ripbot264 release planned? If yes, when? |
29th September 2008, 23:23 | #2543 | Link | |
Thank you for posting this! I have had the same problem and posted it on here twice, but no one had bothered to help. Once again THANK YOU!
29th September 2008, 23:55 | #2544 | Link | |
30th September 2008, 00:00 | #2545 | Link |
I dont care so should you
Nice! I am going to get my old script out and get ready for it...
Wondering? Does it have an updater yet or is that still in the making?
My Installer's || |
30th September 2008, 00:06 | #2546 | Link | |
30th September 2008, 00:09 | #2547 | Link |
Awe, lol its all good...
Love the site... If I put the money into it, You mind using rented space... These guys have excellent deals here in the US... http://www.3ix.org/
My Installer's || Last edited by Ajax_Undone; 30th September 2008 at 00:44. |
1st October 2008, 07:17 | #2551 | Link |
Sorry it took so long had a busy day... New installer in My signature...
My Installer's || |
1st October 2008, 15:19 | #2552 | Link | |
1st October 2008, 16:15 | #2553 | Link |
The new version is a blast! Dear Atak_Snajpera, just as an update. I've had problems with audio sync issues with some Disney Blurays with the older versions. The new .7 version works flawlessly with no sync issues at all! Might have been the updated DGAVCDec or something else you did, it doesn't matter since its flawless now.
Thanks for all your time and effort into this wonderfull tool! |
1st October 2008, 17:24 | #2554 | Link |
Thanks for the Update. I will test it in the next days.
@Atak_Snajpera: It is possible to change RipBot264 that it doesnt demux the streams first. It took a while to demux it and after that i can make my settings. It is possible to change this that the demuxing process starts if the job queue is started?? Thanks for this great tool cu pOpY |
1st October 2008, 19:51 | #2556 | Link |
Aging Video Hobbyist
The new version has inspired me to try RipBot264, but I have a question: What profile should be used to create a BD5 or BD9?
It looks to me like the two (provided) BD profiles differ by Trellis and Bitrate, but I thought that creation of the BR structure onto a DVD-5 or -9 required bitrates of 20Mbps or less??? |
1st October 2008, 20:58 | #2558 | Link | |||||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 1st October 2008 at 21:03. |
1st October 2008, 21:06 | #2559 | Link |
Here is the Code
D:\>"C:\Users\Administrator\Desktop\videotools\RipBot264v1.10.6\tools\bepipe\bepipe.exe" --script "import(^D:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Users\Administrator\Desktop\videotools\RipBot264v1.10.6\Tools\aften\aften.exe" -readtoeof 1 -b 640 - "D:\temp\RipBot264temp\audio.ac3" *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("D:\temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... Found Audio Stream Channels=6, BitsPerSample=16, SampleRate=48000Hz Writing Header... Writing Data... 0% Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz 5.1-channel output format: 48000 Hz 3/2 + LFE SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 0% | q: 455.7 | bw: 58.0 | bitrate: 640.0 kbps . . . . . . progress: 0% | q: 316.7 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.7 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate Done! : 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 0% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps progress: 100% | q: 316.6 | bw: 58.0 | bitrate: 640.0 kbps D:\>"C:\Users\Administrator\Desktop\videotools\RipBot264v1.10.6\tools\x264\x264.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 8767 --stats "D:\temp\RipBot264temp\job1\job1.stats" --level 4.0 --sar 1:1 --aud --nal-hrd --vbv-bufsize 30000 --vbv-maxrate 30000 --filter 0,0 --bframes 3 --b-pyramid --direct auto --subme 2 --analyse none --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --output "D:\temp\RipBot264temp\video.264" avis [info]: 1920x1080 @ 23.98 fps (162079 frames) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (30000) > level limit (20000) x264 [warning]: VBV buffer (30000) > level limit (25000) x264 [info]: using cpu capabilities: MMX2 SSE2Slow encoded frames: 163/162079 (0.1%), 11.91 fps, eta 3:46:36 x264 [info]: slice I:2428 Avg QP:12.11 size:125404 x264 [info]: slice P:89268 Avg QP:14.29 size: 59201 x264 [info]: slice B:70383 Avg QP:16.24 size: 23386 x264 [info]: consecutive B-frames: 26.2% 44.1% 3.5% 26.3% x264 [info]: mb I I16..4: 65.3% 0.0% 34.7% x264 [info]: mb P I16..4: 42.2% 0.0% 0.0% P16..4: 25.8% 0.0% 0.0% 0.0% 0.0% skip:32.0% x264 [info]: mb B I16..4: 10.0% 0.0% 0.0% B16..8: 23.0% 0.0% 0.0% direct:17.2% skip:49.7% L0:37.6% L1:46.1% BI:16.4% x264 [info]: final ratefactor: 17.07 x264 [info]: direct mvs spatial:98.0% temporal:2.0% x264 [info]: kb/s:8562.4 encoded 162079 frames, 7.74 fps, 8567.13 kb/s D:\>"C:\Users\Administrator\Desktop\videotools\RipBot264v1.10.6\tools\x264\x264.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8767 --stats "D:\temp\RipBot264temp\job1\job1.stats" --level 4.0 --sar 1:1 --aud --nal-hrd --vbv-bufsize 30000 --vbv-maxrate 30000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-pyramid --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse all --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "D:\temp\RipBot264temp\video.264" avis [info]: 1920x1080 @ 23.98 fps (162079 frames) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (30000) > level limit (20000) x264 [warning]: VBV buffer (30000) > level limit (25000) x264 [info]: using cpu capabilities: MMX2 SSE2Slow encoded frames: 163/162079 (0.1%), 9.36 fps, eta 4:48:10 x264 [info]: slice I:2428 Avg QP:13.92 size: 81712 x264 [info]: slice P:89268 Avg QP:16.64 size: 63964 x264 [info]: slice B:70383 Avg QP:18.69 size: 21134 x264 [info]: consecutive B-frames: 26.2% 44.1% 3.5% 26.3% x264 [info]: mb I I16..4: 37.8% 54.7% 7.5% x264 [info]: mb P I16..4: 5.6% 14.8% 0.9% P16..4: 31.1% 9.0% 5.5% 0.0% 0.0% skip:33.1% x264 [info]: mb B I16..4: 0.7% 1.2% 0.0% B16..8: 25.4% 0.5% 0.8% direct: 4.2% skip:67.1% L0:45.0% L1:37.6% BI:17.4% x264 [info]: 8x8 transform intra:67.3% inter:79.6% x264 [info]: direct mvs spatial:86.7% temporal:13.3% x264 [info]: ref P L0 59.1% 24.5% 16.3% x264 [info]: ref B L0 74.3% 25.7% x264 [info]: ref B L1 96.6% 3.4% x264 [info]: kb/s:8752.4 encoded 162079 frames, 2.38 fps, 8756.94 kb/s D:\>"C:\Users\Administrator\Desktop\videotools\RipBot264v1.10.6\tools\tsmuxer\tsmuxer.exe" "D:\temp\RipBot264temp\job1\tsmuxer.meta" "D:\Ripbot\DoomEU.bluray" SmartLabs tsMuxeR. Version 1.8.4(b) http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1920:1080p Frame rate: 23.976 0.0% complete Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6 B-pyramid level 1 detected. Shift DTS to 2 frames 0.0% complete H264 bitstream changed: insert SPS/PPS units 0.0% complete 0.1% complete 0.1% complete 0.1% complete . . . . 94.1% complete 94.2% complete 94.2% complete 94.3% complete 94.3% complete 94.3% complete 94.4% complete 94.5% complete 94.5% complete 94.5% complete 94.6% complete 94.7% complete 94.7% complete 94.8% complete 94.8% complete 94.9% complete 94.9% complete 95.0% complete 95.1% complete 95.2% complete 95.3% complete 95.3% complete 95.3% complete 95.4% complete 95.4% complete 95.5% complete 95.6% complete 95.6% complete 95.6% complete 95.7% complete 95.7% complete 95.8% complete 95.8% complete 95.9% complete 96.0% complete 96.0% complete 96.1% complete 96.2% complete 96.2% complete 96.3% complete 96.4% complete 96.4% complete 96.4% complete 96.5% complete 96.5% complete 96.6% complete 96.6% complete 96.7% complete 96.7% complete 96.8% complete 96.8% complete 96.9% complete 96.9% complete 96.9% complete 97.0% complete 97.1% complete 97.2% complete 97.3% complete 97.3% complete 97.4% complete 97.4% complete 97.4% complete 97.4% complete 97.5% complete 97.5% complete 97.6% complete 97.6% complete 97.6% complete 97.7% complete 97.7% complete 97.8% complete 97.8% complete 97.9% complete 97.9% complete 97.9% complete 98.0% complete 98.0% complete 98.1% complete 98.1% complete 98.2% complete 98.2% complete 98.3% complete 98.3% complete 98.4% complete 98.4% complete 98.5% complete 98.5% complete 98.6% complete 98.6% complete 98.6% complete 98.6% complete 98.6% complete 98.6% complete 98.7% complete 98.7% complete 98.7% complete 98.7% complete 98.7% complete 98.8% complete 98.9% complete 98.9% complete 98.9% complete 98.9% complete 99.0% complete 99.0% complete 99.0% complete 99.1% complete 99.1% complete 99.1% complete 99.2% complete 99.2% complete 99.3% complete 99.3% complete 99.3% complete 99.4% complete 99.4% complete 99.4% complete 99.4% complete 99.5% complete 99.5% complete 99.5% complete 99.6% complete 99.6% complete 99.6% complete 99.6% complete 99.7% complete 99.7% complete 99.7% complete 99.8% complete 99.8% complete 99.8% complete 99.8% complete 99.9% complete 100.0% complete Processed 162079 video frames 100.0% complete Creation of Blu-ray playlist Creation of Blu-ray stream info and seek index Mux successful complete. Muxing time: 13 min 19 sec |
1st October 2008, 21:24 | #2560 | Link |
Try again with 1.10.7
