23rd April 2023, 15:41 | #1 | Link |
sRestore Vapoursynth vs Avisynth
Using the following VapourSynth script:
# Imports import vapoursynth as vs import os import ctypes # Loading Support Files Dllref = ctypes.windll.LoadLibrary("i:/Hybrid/64bit/vsfilters/Support/libfftw3f-3.dll") import sys # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'i:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/GrainFilter/RemoveGrain/RemoveGrainVS.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/GrainFilter/AddGrain/AddGrain.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DenoiseFilter/DFTTest/DFTTest.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DenoiseFilter/FFT3DFilter/fft3dfilter.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/Support/EEDI3m.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/vsznedi3.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/Support/libmvtools.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/Support/scenechange.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/MiscFilter/MiscFilters/MiscFilters.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DeinterlaceFilter/Bwdif/Bwdif.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/d2vSource/DGDecode.dll") # Import scripts import havsfunc # source: 'G:\Output\Naruto DVD Folge 4_3 min.m2v' # current color space: YUV420P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading G:\Output\Naruto DVD Folge 4_3 min.m2v using DGDecode clip = core.dgdecode.MPEG2Source("J:/tmp/m2v_b7151a7e116c7001abddb45453f1386c_853323747.d2v",info=3)# 25 fps, scanorder: top field first # Setting detected color matrix (470bg). clip = core.std.SetFrameProps(clip, _Matrix=5) # Setting color transfer info (470bg), when it is not set clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5) # Setting color primaries info (BT.601 PAL), when it is not set clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # tff # Deinterlacing using QTGMC clip = havsfunc.QTGMC(Input=clip, Preset="Fast", TFF=True) # new fps: 50 # Making sure content is preceived as frame based clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=0) # progressive # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=23.9760, omode=6) # set output frame rate to 23.976fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=24000, fpsden=1001) # Output clip.set_output() Code:
ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\DGDecode.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\RgTools.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\masktools2.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\mvtools2.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\nnedi3.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\TIVTC.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\Average.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\grunt-x64.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\MedianBlur2.dll") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\QTGMC.avsi") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\Zs_RF_Shared.avsi") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\Srestore.avsi") # loading source: G:\Output\Naruto DVD Folge 4_3 min.m2v # color sampling YV12@8, matrix: bt470, scantyp: top field first, luminance scale: limited MPEG2Source(d2v="J:\tmp\m2v_b7151a7e116c7001abddb45453f1386c_853323747.d2v",fieldop=0) # current resolution: 720x576 # deinterlacing AssumeTFF() QTGMC(Preset="Fast", ediThreads=2) # removing ghosting srestore(frate=23.976,omode=6) Preroll(Int(last.FrameRate())) # filtering # setting output fps to 23.976fps AssumeFPS(24000,1001) # output: color sampling YV12@8, matrix: bt470, scantyp: progressive, luminance scale: limited return last https://imgsli.com/MTcyOTU2 (see left side of the image) Any idea how to improve the blend removal in VapourSynth? Is there a newer sRestore port for VapourSynth out there? (can someone make one?) Cu Selur Ps.: Used the clip from https://forum.videohelp.com/threads/...e)-from-animes as source. (uploaded the source an the reencodes to GoogleDrive. Last edited by Selur; 23rd April 2023 at 16:08. |
24th April 2023, 14:56 | #2 | Link |
Similar poor results for vpy srestore here. The results are quite a bit worse on many frames compared to avs version
You reported the issue before - but on that sample it's very easy to see the problems, consider adding it as another example https://github.com/HomeOfVapourSynth...func/issues/78 On the avs version, a few of the slightly blended frames are from QTGMC . If you replace with something like bwdif ,they are clean |
24th April 2023, 16:13 | #5 | Link |
If I import an avs script using AVIsource with only bwdif, the vpy srestore works better too - about the same as the avs version. That sequence where girl is walking up is clean. But if I use vpy bwdif into srestore, it's blended.
In both cases, the output node of bwdif is about the same . Props isn't screwing it up - you can set them the same In all cases, I go back a few seconds and test linearly , because you can get inconsistent results. Could it be some threading issue ? AVISource is 1 frame in/out, and slower, so it "forces" linear processing in a way - so when I use MPEG2Source in the avs script only (just source filter) , and import using AVISource into the vpy script. Use vpy bwdif and srestore - it works now . So that's my working theory - some threading issue and mixing up frames Is there a way to force linear/slow/threads=1 processing for source filter ? I used core.d2v.Source for vpy source loading |
24th April 2023, 16:16 | #6 | Link |
Yeah, so the whole GScriptClip-stuff in the AviSynth version makes it really difficult to read.
Additionally, the Vapoursynth version is based on sRestore 2.7e from 2009 and the current version probably changed quite a bit since then,.. |
24th April 2023, 17:14 | #9 | Link |
Doesn't work here,...
# Imports import vapoursynth as vs import os import sys # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'i:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DeinterlaceFilter/Bwdif/Bwdif.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/DGDecNV/DGDecodeNV.dll") # Import scripts import havsfunc # source: 'C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv' # current color space: YUV420P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv using DGSource clip = core.dgdecodenv.DGSource("J:/tmp/mkv_2d1ce5e0c17bb199c7f9dc6f4331d407_853323747.dgi",fieldop=0)# 25 fps, scanorder: top field first # Setting detected color matrix (470bg). clip = core.std.SetFrameProps(clip, _Matrix=5) # Setting color transfer info (470bg), when it is not set clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5) # Setting color primaries info (BT.601 PAL), when it is not set clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # tff # Deinterlace using Bwdif clip = core.bwdif.Bwdif(clip=clip, field=3) # new fps: 50 # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=23.9760, omode=6, speed=9, thresh=16, mode=2) # set output frame rate to 23.976fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=24000, fpsden=1001) # Output clip.set_output() same when I simplify it to: Code:
# Imports import vapoursynth as vs import os import sys # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'i:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DeinterlaceFilter/Bwdif/Bwdif.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/DGDecNV/DGDecodeNV.dll") # Import scripts import havsfunc # source: 'C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv' # current color space: YUV420P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv using DGSource clip = core.dgdecodenv.DGSource("J:/tmp/mkv_2d1ce5e0c17bb199c7f9dc6f4331d407_853323747.dgi")# 25 fps, scanorder: top field first # Deinterlace using Bwdif clip = core.bwdif.Bwdif(clip=clip, field=3) # new fps: 50 # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip) # set output frame rate to 23.976fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=24000, fpsden=1001) # Output clip.set_output() |
24th April 2023, 17:38 | #10 | Link |
Using:
# Imports import vapoursynth as vs import os import sys # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'i:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/NNEDI3CL.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DeinterlaceFilter/TIVTC/libtivtc.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/DGDecNV/DGDecodeNV.dll") # Import scripts import havsfunc import TFMBob # source: 'C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv' # current color space: YUV420P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv using DGSource clip = core.dgdecodenv.DGSource("J:/tmp/mkv_2d1ce5e0c17bb199c7f9dc6f4331d407_853323747.dgi",fieldop=0)# 25 fps, scanorder: top field first # Setting detected color matrix (470bg). clip = core.std.SetFrameProps(clip, _Matrix=5) # Setting color transfer info (470bg), when it is not set clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5) # Setting color primaries info (BT.601 PAL), when it is not set clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # tff clip = TFMBob.TFMBobN(clip=clip, cthresh=5, openCL=True) # see: https://github.com/Selur/VapoursynthScriptsInHybrid/blob/master/TFMBob.py # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=23.9760) # set output frame rate to 23.976fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=24000, fpsden=1001) # Output clip.set_output() Argh, scratch that,.. this causes some ugly artifacts in some scenes. Last edited by Selur; 24th April 2023 at 17:40. |
24th April 2023, 18:53 | #11 | Link |
DGSource,bwdif,srestore vpy works for me . Similar results to avs srestore
This is what I'm getting https://www.mediafire.com/file/rbsx5...e_vpy.mp4/file Last edited by poisondeathray; 24th April 2023 at 18:56. |
24th April 2023, 19:04 | #12 | Link |
Strange, when I use:
# Imports import vapoursynth as vs import os import sys # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'i:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/DeinterlaceFilter/Bwdif/Bwdif.dll") core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/DGDecNV/DGDecodeNV.dll") # Import scripts import havsfunc # source: 'C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv' # current color space: YUV420P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading C:\Users\Selur\Desktop\Naruto DVD Folge 4_3 min.mkv using DGSource clip = core.dgdecodenv.DGSource("J:/tmp/mkv_2d1ce5e0c17bb199c7f9dc6f4331d407_853323747.dgi",fieldop=0)# 25 fps, scanorder: top field first # Setting detected color matrix (470bg). clip = core.std.SetFrameProps(clip, _Matrix=5) # Setting color transfer info (470bg), when it is not set clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5) # Setting color primaries info (BT.601 PAL), when it is not set clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # tff # Deinterlace using Bwdif clip = core.bwdif.Bwdif(clip=clip, field=3) # new fps: 50 # Making sure content is preceived as frame based clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=0) # progressive # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=23.9760) # adjusting output color from: YUV420P8 to YUV420P10 for NVEncModel clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, range_s="limited") # set output frame rate to 23.976fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=24000, fpsden=1001) # Output clip.set_output() No clue what I do differently than you. -> can you open my script (with adjusted paths) and check whether it looks fine for you? Maybe something in my script is causing the issue. Cu Selur |
24th April 2023, 19:13 | #13 | Link |
My script was in post #8 . I got similar problems earlier, and it was definitely from source filter d2vsource
I don't see anything in your script that would cause that problem Maybe version and dependency differences. I used an old vapoursynth version, old plugins, old scripts, old havsfunc. I'll check with a newer version and see if problem pops up . (vapoursynth /python dependencies are 10x worse than "avs .dll hell" ) EDIT- That was an R54 setup. Yes, I got blends on R61 setup, and R57 setup. Something maybe with dependencies/scripts/plugins differences between those. It's going to take some work to figure out what's causing it... Last edited by poisondeathray; 24th April 2023 at 19:19. |
24th April 2023, 20:06 | #15 | Link |
DGDecodeNV.dll was the same for my versions
Bwdif.dll was different, but using old version in R57 didn't make a difference Does not appear to be srestore version issue either; using older srestore (or copying over old havsfunc) in R57 still gets blends . Using newer srestore in older R54 still ok. Not sure why the difference, maybe some other dependency (or unlikely, core difference causing problem. Or maybe it is some API <4 vs. >=4 issue ?) |
25th April 2023, 13:52 | #16 | Link |
The culprit is that std.Cache filter becomes no-op in API4. Specifically, srestore requires the make_linear functionality from std.Cache in API3 to work as expected because it calculates some global statistics and those statistics get updated every frame inside FrameEval. Without make_linear, some calls inside FrameEval get skipped and the statistics calculated are incorrect. But it seems impossible to achieve the same result by using std.SetVideoCache in API4.
25th April 2023, 14:22 | #17 | Link | |
Thanks Do you have any suggestions how to address that in API4 ? Maybe have 2 types of Cache ? Perhaps Myrsloik can look at it ? BTW - Nice to see you back here |
25th April 2023, 22:10 | #19 | Link | |
Professional Code Monkey
As a really stupid plan b create a dummy passthrough filter (like the filter skeleton example), use Unordered as the mode and call setLinearFilter(). Replace the Cache() with this filter instead. Maybe it'll whack things into order enough.
26th April 2023, 14:45 | #20 | Link |
I think this is what really make a difference for srestore because it can no longer get statistics from the skipped frames.
from functools import partial import vapoursynth as vs def print_num(n, clip): print(f"frame number: {n}") return clip clip = vs.core.std.BlankClip(length=20) clip = clip.std.FrameEval(partial(print_num, clip=clip)) #clip = clip.std.Cache(make_linear=True) clip = clip.std.SelectEvery(2, 0) clip.set_output() Without Cache(make_linear=True), it outputs: Code:
frame number: 0 frame number: 2 frame number: 4 frame number: 6 frame number: 8 frame number: 10 frame number: 12 frame number: 14 frame number: 16 frame number: 18 Code:
frame number: 0 frame number: 1 frame number: 2 frame number: 3 frame number: 4 frame number: 5 frame number: 6 frame number: 7 frame number: 8 frame number: 9 frame number: 10 frame number: 11 frame number: 12 frame number: 13 frame number: 14 frame number: 15 frame number: 16 frame number: 17 frame number: 18 |
