Old 3rd June 2018, 23:05   #41  |  Link
Richard1485
Posts: n/a
I've tinkered with VapourSynth a bit. It's just that I'd end up going back to AviSynth for various reasons (audio work, use of DGIndexNV, familiarity, etc), most of which I've no doubt whatsoever are surmountable. I guess I just don't like going back and forth between tools if I can avoid it. Hell, I'd order my shopping by writing an AviSynth script if it were possible.☺ Anyway, I'll try to stop hijacking threads.
Old 4th June 2018, 19:46   #42  |  Link
Selur
Selur's Avatar
as a side note to that: DGIndexNV works fine with Vapoursynth, using it for month,...
Old 5th June 2018, 11:01   #43  |  Link
Richard1485
Posts: n/a
A month? I thought that there was some issue getting it to work with VapourSynth. Thanks for letting me know: I'll check it out.
Old 30th August 2018, 03:11   #44  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
timecube r2 pre-release version: link
Key changes:
  • Developer API for Cube processing
  • Fixed processing of limited range
  • Option to use different output format than source
  • AVX-512 mode for up to 33% speedup
  • Minor optimization in other modes (2-3%)
Stephen R. Savage is offline   Reply With Quote
Old 25th August 2019, 19:47   #45  |  Link
groucho86
If someone could figure out the necessary configure/make files to compile timecube on Mac/Linux it would be much appreciated.
groucho86 is offline   Reply With Quote
Old 26th August 2019, 00:57   #46  |  Link
Are_
Timecube already has a makefile in its repo. What problem is it giving to you?
Are_ is offline   Reply With Quote
Old 26th August 2019, 03:04   #47  |  Link
groucho86
Once I cd into the root folder of timecube-r2a and run make, I get the following error:
c++    -c -o vscube/vscube.o vscube/vscube.cpp
vscube/vscube.cpp:6:10: fatal error: 'timecube.h' file not found
#include "timecube.h"
1 error generated.
make: *** [vscube/vscube.o] Error 1
I'm used to running an ./autogen.sh and ./configure before running make. I tried repurposing those from other plugin sources but was unsuccessful.
Old 26th August 2019, 16:00   #48  |  Link
Are_
timecube repo has a submodule, you need to fetch it with:
git clone --recursive https://github.com/sekrit-twc/timecube.git
Old 26th August 2019, 17:21   #49  |  Link
groucho86
That worked, thank you _Are!
Old 16th December 2019, 02:26   #50  |  Link
ASVTut
ASVTut's Avatar
I hope this isn't too off-topic, but why does the Timecube Readme have the "You are Educated Evil" thing? Is it an in-joke about LUTs? At first, I thought the repo was hacked.
ASVTut is offline   Reply With Quote
Old 27th March 2023, 23:20   #51  |  Link
Couleur
Couleur's Avatar
is there proper documentation for it anywhere?
Couleur is offline   Reply With Quote
