Old 7th July 2014, 10:25   #2161  |  Link
Mercury_22
I'm using LAV latest git and latest MPC-BE (MPC-BE v1.4.3 -dev build 5074) and it happens with ALL my BD
And it's NOT a LAV problem cause MPC-HC (with the same external LAV) doesn't have this problem
Here is the same BD opened via index.bdmv with MPC-HC and the same (external) LAV filters
But since nobody else has this problem must be my system
P.S. I've also tested with MPC-BE's default settings too
EDIT Just tested on two virtual machines one with windows 7 x64 and one with windows 8.1 x64 and the same thing it's happening ! so one questions comes to mind did you use alexins's mpc-be builds or your own builds ?
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 7th July 2014, 11:52   #2162  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Here from latest SVN version + latest LAV version:
here latest SVN build - http://aleksoid.voserver.net/MPC-BE/mpc-be.exe.5078.7z
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 7th July 2014, 13:53   #2163  |  Link
Mercury_22
The same problem with your build too
This is on a clean VM windows 7 x64 with your build, latest official lav and default settings
EDIT: Why on your player's "seek bar" it's saying 00001.mpls instead of Blu-ray ......?
Old 7th July 2014, 19:05   #2164  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5081 Dev.:
MPC-BE 1.4.3.5081 Dev (sourceforge.net)
MPC-BE 1.4.3.5081 Dev (dev.mpc-next.ru)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 8th July 2014, 01:00   #2165  |  Link
Aleksoid1978
I see only one BD - but you say that it's happened with any BD that you have. Check other.
Give me a link(to PM) where i can download you BD "COSMOS_S1_D1"
P.S. I know whats wrong at you - you disable internal MPEGSplitter in setting. I fix it )))
Old 8th July 2014, 10:27   #2166  |  Link
Mercury_22
Yes I have MPEGSplitter disabled in setting and I've told you I was using LAV Splitter
I've sent you a PM
EDIT:
Here is "proof" from another BD
EDIT:
The problem it's solved in your latest build
THANK YOU !
Old 8th July 2014, 21:10   #2167  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5091 Dev.:
MPC-BE 1.4.3.5091 Dev (sourceforge.net)
MPC-BE 1.4.3.5091 Dev (dev.mpc-next.ru)
Old 9th July 2014, 11:57   #2168  |  Link
subz3ro
Would it be possible to add a feature, where one could make a list of FPS rates (something like already existing list of FPS rates for full-screen playback), while for each rate a custom sound delay can be set? This would be very useful when one is using ReClock, because it will compensate this variable length of lip-synchro gap which is dependent on actual FPS of the media file being played.
subz3ro is offline   Reply With Quote
Old 10th July 2014, 12:38   #2169  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5098 Dev.:
MPC-BE 1.4.3.5098 Dev (sourceforge.net)
MPC-BE 1.4.3.5098 Dev (dev.mpc-next.ru)
Old 10th July 2014, 22:12   #2170  |  Link
xiringu
I've just tried 1.4.3.5098.x86 and is not loading audio on my movies (tried a couple randomly, MKV and MP4).
1.4.3.5056 is OK. It seems something is broken.
By the way, is it possible to add these 2 things?
1) Add a clock with system time at the bottom.
2) Add brightness, contrast and saturation sliders at the bottom next to the volume, to avoid going through the menus to change that. I know there's keyboard shortcuts, but I think it is very useful to be able to change those values with the mouse without opening the menus, etc.
thanks
xiringu is offline   Reply With Quote
Old 11th July 2014, 07:34   #2171  |  Link
ryrynz
ryrynz's Avatar
Probably unlikely they'll do that, FWIW you can call the time to the OSD with the I key.
No problems here. Internal filters all okay.
You should screenshot your filter chain and upload it for starters (recommend using an actual image sharing site)
Old 12th July 2014, 18:41   #2172  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5114 Dev.:
MPC-BE 1.4.3.5114 Dev (sourceforge.net)
MPC-BE 1.4.3.5114 Dev (dev.mpc-next.ru)
Old 13th July 2014, 09:58   #2173  |  Link
mysterix
Please, can you add support for dslibbluray directshow blu-ray navigator filter? And, if it is possible, Arcsoft BDAV Navigator too.
Link
mysterix is offline   Reply With Quote
Old 19th July 2014, 21:19   #2174  |  Link
xiringu
Thanks for the changes.
I did a fresh win install,so I can't replicate my no sound problem. Everything is working ok now.
Is is possible to copy the shader preset feature from mpc-hc? I use it all the time, and it's the only thing that's keeping me from using mpc-be as my only player.
To make myself clear, what i miss is the option of saving combinations of shaders and being able to quickly try them while playing a movie, to see which one I like best.
There's another preset feature, that's even better and that's that on Splash player Pro, where you can make presets including brightness, contrast, saturation, sharpness, vibrance, and others, so you can have a preset for different series, or low-res movies vs high-res movies, etc.
That feature in Splash Player Pro is the best in my opinion.
Thanks for listening
Old 19th July 2014, 21:39   #2175  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5151 Dev.:
MPC-BE 1.4.3.5151 Dev (sourceforge.net)
MPC-BE 1.4.3.5151 Dev (dev.mpc-next.ru)
Old 20th July 2014, 15:52   #2176  |  Link
xiringu
Maybe I'm just being dumb here, but I just can't find where to add extra shaders.
I use vibrance and luma sharpen on mpc-hc, but I can't add them to mpc-be. I tried copying them as .hlsl, then renaming as .psh, I also looked for a button to add them. Nothing.
They never show in Select or Edit Shaders.
Can anyone explain to me how to do this on mpc-be?
Thanks
Old 24th July 2014, 21:57   #2177  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5157 Dev.:
MPC-BE 1.4.3.5157 Dev (sourceforge.net)
MPC-BE 1.4.3.5157 Dev (dev.mpc-next.ru)
Old 27th July 2014, 14:43   #2178  |  Link
Aleksoid1978
Thanks
Filename must be a *.psh
And - you must place it's files in %APPDATA%\MPC-BE\Shaders directory.
Old 28th July 2014, 06:08   #2179  |  Link
Dion
Streaming over UDP/HTTP seems kind of broken. It buffers the whole file instead of streaming it. Like if I skip to the middle of a movie over streaming. It doesn't do anything till its done buffering. Which can be over a minutes. MPC-HC doesn't seem to have an issue with this and skips right to the spot.
Dion is offline   Reply With Quote
Old 28th July 2014, 15:21   #2180  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.5161 Dev.:
MPC-BE 1.4.3.5161 Dev (sourceforge.net)
MPC-BE 1.4.3.5161 Dev (dev.mpc-next.ru)
