Old 2nd November 2024, 15:35   #1  |  Link
jay123210599
Webp < jxl
Check this out! I converted an APNG to a lossless animated webp using ffmpeg and a lossless animated jxl file using cjxl and the former was less than the latter! Amazing, right?
Test 1:
APNG: 470MB
Lossless animated WEBP: 131MB
JXL (effort 9): 194MB
Test 2:
APNG: 438MB
WEBP: 143MB
Lossless animated JXL (effort 9): 175MB
Commands used:
For WEBP:
For JXL:
cjxl input.apng -d 0 -e 9 output.jxl
The information from the videos I converted to APNG beforehand:
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Format Range@L4@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 10.1 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:4:4
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.203
Stream size                              : 1.67 GiB (87%)
Writing library                          : x265 3.0_Au+22-feec4bdf9866:[DJATOM's Mod][Linux][GCC 6.3.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=2 / numa-pools= / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / csv / csv-log-level=2 / input-csp=3 / input-res=1920x1080 / interlace=0 / total-frames=34120 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=240 / gop-lookahead=0 / bframes=9 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=2 / tu-intra-depth=2 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / limit-modes / me=2 / subme=5 / merange=48 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=4.00 / no-rd-refine / no-lossless / cbqpoffs=4 / crqpoffs=4 / rc=crf / crf=15.0 / qcomp=0.72 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=0.85 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / hevc-aq / no-svt / qp-adaptation-range=2.00
Language                                 : Japanese
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
The command I have used to convert them to APNGs:
ffmpeg -i  -vf format=gbrp -plays 0 -c:v apng output.apng
https://www.mediafire.com/file/oi7pv...Videos.7z/file
Well, what were the results? Did they all have the same colors? Were there any quality difference?
jay123210599 is offline   Reply With Quote
Old 2nd November 2024, 16:40   #2  |  Link
Z2697
WebP uses "differential" encoding.
see: webpmux -get frame 2 "Test 1.webp" -o 002.webp
Z2697 is offline   Reply With Quote
Old 2nd November 2024, 17:07   #3  |  Link
jay123210599
How was the webp different from the apng and jxl, exactly? Did you try extracting 1 frame from each of them as png files and comparing them that way?
Old 2nd November 2024, 17:57   #4  |  Link
Z2697
If you do the extraction I told you you'll see.
I can only assume it's exactly the same based on the "lossless" because well the convenient way of converting from Animated WebP is basically non-existence, what worse is that differential coding just make it more difficult.
OK I'll just upload 2nd frame of that webp
Old 3rd November 2024, 03:39   #5  |  Link
jay123210599
I used ImageMagick's identify and this is what I got.
APNG:
https://imgur.com/JM9NvuI
JXL:
https://imgur.com/YGGod09
WEBP:
https://imgur.com/13x4vRC
Old 3rd November 2024, 04:33   #6  |  Link
poisondeathray
The posted apng, jpeg-xl , and webp are lossless for a converted to 8bit RGB format; but technically not lossless for a source 10bit444 YUV video
anim_dump can decode animated webp to an image sequence. ffmpeg still cannot do it but there are open tickets for this
lossless avif in RGB should be smaller e.g. using cpu-used 2 (lower values offer higher compression with diminishing returns, but slower to process)
lossless avif in 10bit444 YUV would be truly lossless for the source , and smaller . YUV also compresses better than RGB in general - that's why it's used for video . This plays ok in browsers, but higher overhead. Slow computers might lag, and legacy computers/browsers might not support avif
All of them are silly because you're making the filesize many times larger. If you wanted to share something... post the video
Test 1
source yuv444p10 4,496,079 bytes
apng rgb lossless 493,816,568 bytes
webp rgb lossless 137,974,458 bytes
avif rgb lossess (cpu-used 2) 95,375,685 bytes
avif yuv444p10 lossless (cpu-used 2) 73,163,539 bytes
Old 3rd November 2024, 11:25   #7  |  Link
jay123210599
What where the commands you used to convert the apng and/or video to lossless rgb avif and lossless yuv444p10 avif?
Old 3rd November 2024, 12:52   #8  |  Link
Z2697
Test 1
Thanks for the tip. Somehow the anim_dump saves bgr directly as rgb LOL.
edit: probably WIC's fault, save to TIFF or PAM is safe.
Old 3rd November 2024, 15:11   #9  |  Link
poisondeathray
There were some avif bugs in ffmpeg libavif about a year ago , but they look fixed now. You can squeeze out more compression by using lower cpu-used. Or if it's too slow for you, use higher values for less compression, higher speed
For yuv444p10
ffmpeg -i "Test 1.mkv" -c:v libaom-av1 -crf 0 -cpu-used 2 test1_yuv444p10.avif
For rgb, I used avs script input because the timestamps and timebase on that apng production are a bit off . If you're measuring "quality" using metrics, slightly off timestamps can produce different values and be detected as "different quality" (even if the decoded images are the same)
I used the apng instead of the video for the RGB source, because there are different ways of converting YUV to RGB, and even an tiny tiny fraction off will show up as "not lossless"
FFVideoSource("path\test 1.apng")
AssumeFPS(24000,1001)
ffmpeg -i test1apng.avs -c:v libaom-av1 -crf 0 -cpu-used 2 test1apngavs_ffmpeg_cpu2.avif
Old 3rd November 2024, 16:10   #10  |  Link
jay123210599
For yuv444p10
What were those bugs? What is the maximum value you can put in for cpu-used? It won't affect the quality of the avif?
Old 3rd November 2024, 16:32   #11  |  Link
Z2697
In fact the lossless compression ratio of x264 is higher than x265 and x265 is higher than libaom-av1
You get 70,896,451 bytes from the provided apng.
command line: ffmpeg -r 24 -i apng -c:v libx264rgb -qp 0 -preset 9 264
You can use -r before -i to force the framerate, if you like 24000/1001 you can do it as well. Not necessary to go AVS.
You can and probably should always force the framerate for both files when you calculating metric using FFmpeg.
Old 3rd November 2024, 17:36   #12  |  Link
poisondeathray
The bugs were posted in your other threads on the other forum about a year ago.
  -cpu-used          <int>        E..V....... Quality/Speed ratio modifier (from -8 to 8) (default 1)
"Lossless" is always the same quality . -crf 0 is lossless for aom-av1 , so cpu-used only affects compression ratio (and processing speed)
He wants an animated image format for some reason (there is a bit of history on this, use search if you're interested, there are dozens of his threads with overlapping content on this topic). So that rules out x264, x265 . There is some work with HEIC, but it's poorly supported
Yes, normally I do (if you read his old threads on the other forum, examples are posted) but it's necessary in this case because the you get garbage results with metrics like PSNR like 11db, even with forcing -r , with setpts and settb to normalize timebase for different containers. Try it . When you match the timestamps, timebase with avs input it's infinity for everything - the latter is the true result because when you decompress to raw RGB and compare they are identical
ffmpeg -r 24000/1001 -i "test 1.apng" -r 24000/1001 -i "test1apng_ffmpeg_cpu2.avif" -lavfi  "[0:v]settb=1/AVTB,setpts=PTS-STARTPTS[main];[1:v]settb=1/AVTB,setpts=PTS-STARTPTS[ref];[main][ref]psnr" -f null -
Input #0, apng, from 'test 1.apng':
  Duration: N/A, bitrate: N/A
  Stream #0:0: Video: apng, rgb24(pc, gbr/bt709/bt709), 1920x1080 [SAR 1:1 DAR 1
6:9], 100k tbr, 100k tbn
[mov,mp4,m4a,3gp,3g2,mj2 @ 00000022c3d23200] Stream #0: not enough frames to est
imate rate; consider increasing probesize
Input #1, mov,mp4,m4a,3gp,3g2,mj2, from 'test1apng_ffmpeg_cpu2.avif':
  Metadata:
    major_brand     : avis
    minor_version   : 0
    compatible_brands: avisavifmsf1iso8mif1miafMA1A
  Duration: 00:00:06.51, start: 0.000000, bitrate: 117268 kb/s
  Stream #1:0[0x1]: Video: av1 (libdav1d) (High) (av01 / 0x31307661), gbrp(pc, g
br/bt709/iec61966-2-1), 1920x1080 [SAR 1:1 DAR 16:9], 1 fps, 1 tbr, 1 tbn (defau
lt)
    Metadata:
      title           : Color
  Stream #1:1[0x1](und): Video: av1 (libdav1d) (High) (av01 / 0x31307661), gbrp(
pc, gbr/bt709/iec61966-2-1, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 117264 k
b/s, 23.98 fps, 23.98 tbr, 24k tbn (default)
[Parsed_psnr_4 @ 00000022c3d21e80] PSNR r:11.493180 g:11.701276 b:12.875624 average:11.982098 min:9.587521 max:inf
Normally the -r with settb and setpts will "fix" everything even between MP4, MKV containers . In this case you get garbage results
Old 3rd November 2024, 18:19   #13  |  Link
Z2697
I know his mind is set on this, I had replied to his old threads.
I just found the problem, FFmpeg recognizes the thumbnail of animated avif as the first stream and passes it to metrics filter. Use [1:v:1] in your example command line fixes that.
(AVIF or other animated HEIF is just a "plain" MP4 video file with a "image item" like thumbnail added to it.)
edit: But, how was the AVS script able to fix it?
By the way
What bugs? I'm curious too. Also I don't think FFmpeg ever uses libavif, they implemented the (de)muxer natively. (mudem? as an anology to codec - coder/decoder LOL)
Last edited by Z2697; 3rd November 2024 at 18:53. Reason: thumbnail of avif -> thumbnail of animated avif
Old 3rd November 2024, 18:47   #14  |  Link
poisondeathray
Yeah, but not the dozens(!) of other similar threads on the videohelp forum. I think he's here because he got banned for that... In the old days with the old mods - he would have been banned here for numerous rule violations. They used to be waaay more strict at d9
I just found the problem, FFmpeg recognizes the thumbnail of avif as the first stream and passes it to metrics filter. Use [1:v:1] in your example command line fixes that.
nice
It works for avs, because only 1 stream is frameserved to ffmpeg
The problem before was the ffmpeg produced avif's didn't animate in browser - IIRC there was some tags missing that broke libavif spec
image-quality
