Old 21st March 2022, 21:31   #1041  |  Link
Dogway
The isoparam mode is only for visualization but it serves well to illustrate the concept.
The rugged remap helps pick up shading differences, but it needs to be applied on a lowpassed prefiltered clip and ideally on HBD.
This is better than per frame normalization which is inconsistent, here x remaps always to the same y.
@anton_foy: I don't think it's going to be night and day but you'd most likely get a bit better while a bit faster.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 22nd March 2022, 12:23   #1042  |  Link
mp3dom
Hi, I'm trying to use deep_resize going from a UHD to SD, but I'm getting these errors (actually even from UHD to HD):
Select: index value out of range
transformspack.avsi, line 3479
transformspack.avsi, line 539
resizerspack.avsi, line 163
resizerspack.avsi, line 214
Any idea? All the "packs" and "extools" are so far up to date and avs+ is 3.7.2.
Thanks!
Old 22nd March 2022, 18:35   #1043  |  Link
Ceppo
@mp3dom
For UHD to SD I did CReasize in CTools.avsi to get the least amount of aliasing and the least amount of blur, that you can find here. You can look at the idea and mod it to your taste, if you want to give it a shot.
@Dogway
Sorry for the advertising
Ceppo is offline   Reply With Quote
Old 22nd March 2022, 19:15   #1044  |  Link
Dogway
My above luma remap worked well in some places, and bad in many places, I think probably due to the null points as I feared. An alternative would be to do it gentler, add a mix of sigmoid contrast with ex_luma_rebuild(), kind of a camel hump shape. In any case probably not as worth it as my current ex_unsharp() solution.
@mp3dom: Probably a TransformsPack regression from my last update, it's working fine on my internal version so will try to update later, with some deep_resize() tweaks.
@Ceppo: Yeah, that's fine, I don't think downsizing is such a problem aliasing wise, the problem has more to do with local contrast. 'Zopti2' does a great and fast job but it adds low freq sharpening that you have to deconvolute, 'DPID' is also great and a reference, it doesn't add much of a local contrast, and finally 'SSIM2' has a great balance between local contrast (actually 0 added) and sharpness. Local contrast is fine if you are not going to upscale later, but for SD you surely will. For intermediary purposes I normally use 'Didée', has a great balance of sharpness, speed and local contrast.
For synthetic tests like zone plates, etc the best all around are Robi and RobiSharp as they approach a 2 taps EWA filter.
Old 22nd March 2022, 19:34   #1045  |  Link
Ceppo
After the update I will give it a try, your point made me curious. Also, I meant to ask but I always forget:
The ancient QTGMC version doesn't use vinverse, your does, can you please explain what is the function of vinverse in QTGMC?
I'm working on my own bob, starting from scratch I got good results with less shimmering and blending, but it still has some problems in particular cases which QTGMC doesn't have, so I thought to just mix it with QTGMC and see if get better.
Old 22nd March 2022, 20:25   #1046  |  Link
Dogway
I haven't delved too deep into QTGMC internal logic, you might ask real.finder for that. My work there was to optimize filters, expression and small blocks of code, and some logic flow besides adding the customary HBD and frameprops support. I plan to update MVTools related settings with the Zopti outcomes but no further.
I recommend you to check initial versions of QTGMC to understand the core principle and have a look at the deshimmer filter. For a simple antialiased dumb bob I implemented nnedi3 into ex_bob(), might help for ideas.
For deep_resize() I'm now adding a regrain option as a cheap hallucination option and fixing some low ratio resize bugs.
Old 22nd March 2022, 22:56   #1047  |  Link
mp3dom
@Ceppo and Dogway: Thanks to both of you, I'll try both the solutions.
Old 22nd March 2022, 23:46   #1048  |  Link
Dogway
@mp3dom: Please, test now with updated TransformsPack
I updated deep_resize(). Many changes, mainly functionality, now there's a 'show' arg so you know what's going on underneath. Also added a 'grain' arg to add grain for some hallucination (psychovisual detail) for SD to HD and HD to UHD.
I changed back 'flat' kernel to 'sinc', but only when HD to UHD, since at these sizes the faint halo is not visible, less so with grain. For SD to HD now I changed from Blackman8 to Lanczos8 as it's sharper and faster than Blackman16, halos are not visible.
Also fixed apparently a few bugs with low ratio resizes, and remapped 'deconv' to be higher for higher ratios.
Original 1080p
Upscaled to 1080p (x2)
spline36 HD to UHD
deep_resize HD to UHD (grain=0)
Old 23rd March 2022, 09:46   #1049  |  Link
mp3dom
Hi Dogway,
I'm getting the same error but at different lines now (probably because you added lines and the previous ones shifted a bit):
transformspack.avsi, line 3489
transformspack.avsi, line 548
resizerspack.avsi, line 178
resizerspack.avsi, line 229
What I try so far:
colorbars(width=1920,height=1080,pixel_type="yv16")
deep_resize(3840,2160)
This works
colorbars(width=3840,height=2160,pixel_type="yv16")
deep_resize(1920,1080)
Same errors as above
deep_resize(720,576)
This works
I'm currently trying to downscale from UHD to SD.
Old 23rd March 2022, 16:12   #1050  |  Link
Ceppo
@Dogway
I updated the whole repository and I get the same errors as mp3dom, something is off
EDIT:
There are any dll/avsi external requirements to use deep_resize??
EDIT:
With yv12 8bit source works fine.
Old 23rd March 2022, 17:21   #1051  |  Link
Dogway
I will have a look now. Thanks for the call snippets!
EDIT: Test now, only need to update TransformsPack.
Old 23rd March 2022, 20:23   #1052  |  Link
real.finder
it happened here http://forum.doom9.net/showthread.ph...44#post1921844 (read until #72 post) and it's not mandatory
See My Avisynth Stuff
Old 23rd March 2022, 23:47   #1053  |  Link
mp3dom
Yes, it works now, thank you!
However, I'm facing another issue. Using colorbars as a source "reference" I see this:
yuv444p16/p10/p8 sources -> output is OK
yuv422p16/p10 sources -> lower part of the bars seems wrong
yuv422p8 sources -> output is OK
yuv420p16/p10/p8 sources -> output is OK
Old 24th March 2022, 00:11   #1054  |  Link
Dogway
Thanks, yes a typo, 'src_width' and 'src_height' should default to 0.0 I think. Fixed!
Old 24th March 2022, 08:28   #1055  |  Link
Ceppo
I still get an error:
line 828:
            Y    = Eval("Y." + resampler + cplaceY + (noring ? Ynr : ""))
line 832:
line 1072:
@real.finder, thanks!
Old 24th March 2022, 09:11   #1056  |  Link
mp3dom
DPID is an additional (external) DLL, but even with that you still need z.lib DLL (avsresize)
@Dogway: Thanks!
Old 24th March 2022, 14:27   #1057  |  Link
Ceppo
@mp3dom
Thanks, it works now!
Old 24th March 2022, 15:04   #1058  |  Link
Ceppo
@Dogway, I need your opinion:
Source
deep_resize(720,480).spline36resize(1920,1080)
CResize(720,480).spline36resize(1920,1080)
Default deep_resize is too aliased for my tastes, is possible to tune it to get it aliasing free like CResize, and save more details?
Old 24th March 2022, 19:15   #1059  |  Link
Dogway
Use a better upscaler:
deep_resize(1920,1080,grain=0)
By the way, I updated ScenesPack v1.0 final. I merged SceneRange() and SceneStats() so performance is not harmed. I also included 'mode', as I added an option for '_SceneMotion' frameprops. Now you can do crazy things like the following:
Level normalization
SceneStats() or ReadStats("D:\Stats.log")
ScriptClip(function [] () {
sts = propGetAsArray("_SceneStats")
ex_levels(max(16,sts[0]),1.0,min(235,sts[1]))
Higher Temporal Radius for calm scenes
SceneStats("Motion") or ReadStats("D:\Stats.log")
mo = propGetFloat("_SceneMotion")
mo = -5*mo+0.85
SMDegrain(tr= round(mo*10))
I see a rise in ScriptClip abusing, sadly all filters need to pass through ScriptClip as frame properties at frame#0 are not dynamic, details here by pinterf.
Old 25th March 2022, 07:09   #1060  |  Link
Ceppo
I can't see why it is related to the upscale filter, it is just to make easier the comparison, and spline36 is pretty much neutral, if I upscale with like nnedi it would end up fixing the aliasing, which is pointless cuz TVs don't use nnedi or deep_resize for the upscaling, at least not mine.
avisynth, dogway, filters, hbd, packs
