#3001 | Link |
Acid fr0g
@Dogway
When you have some time, would you please add to your scripts a "modern" version of finedehalo? It still needs dehalo_alpha.avsi and mt_xxpand_multi.avsi. Perhaps merging them and updating with latest AVS+ functions could make it a bit faster.
@turment on Telegram |
#3002 | Link |
Question:
Why below call for 1080p gives 3-3,5k bitrate SMDegrain(tr=3, thSAD=500, thSCD2 = 100,truemotion=false, rfilter=3, prefilter=1, search=5, contrasharp=false, LFR=true, DCTFlicker=true) and below call for 2160p gives 15-16k bitrate SMDegrain(tr=3, thSAD=500, thSCD2 = 100,truemotion=false, prefilter=1, UHDHalf=false, limit=255, search=5, contrasharp=false, LFR=true, DCTFlicker=true) X265 config has exaclty the same settings. I know that 4k is 4 time 1080p but i have feeling that SMDegrain reduces grain less for 4k than for 1080p. |
#3003 | Link |
4K naturally have more noise 'per sample' because it gets 4 times less photons per sample from same lit scene (via same aperture lens) and relative photon shot noise is 2 times larger. It also can cause worse motion estimation and higher SAD and lower denoising.
To shoot comparable 4K users need to set 4 times more light per scene (to keep same depth of field from lens) and use camera with same electrons per sample sensor capacity (or something like 4 times per frame reading and 'external accumulation') and externally it is looks like 4 time less ISO sensitivity rating. In that case the 4K digital footage expected to be only 4 times more in comparison with 1080 in data rate (sort of real scene data rate with zero noise). |
#3005 | Link | |
so is there any suggestion how to properly handle UHD noise? |
#3006 | Link |
Because it typically have more relative noise levels - increase 'denoising' settings like thSAD and tr and also may be double block size (it also may be useful for typically more soft UHD sources but may depend on source sharpness).
#3007 | Link |
Acid fr0g
My script
SetMemoryMax() SetCacheMode(0) SetFilterMTMode("DEFAULT_MT_MODE", 2) LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll") DGSource("M:\In\Mobile Suit Gundam - Il contrattacco di Char ~Dynit\contrattacco.dgi",ct=48,cb=48,cl=48,cr=48, dn_enable=3, dn_strength=0.1, dn_cstrength=0.05, dn_quality="best") DebilinearResizeMT(1598,862,threads=1) ConvertBits(16) ConvertFormat(fmt_in="420",fmt_out="444",cs_out="",UVrecon=true) libplacebo_Deband(iterations=5,temporal=true) fmtc_bitdepth (bits=10,dmode=3) Prefetch(2,6) I get Script error: There is no function named 'nnedi3_rpow2'. (D:/Programmi/Media/AviSynth+/plugins64/ResizersPack-12.1~Dogway.avsi, line 786) (D:/Programmi/Media/AviSynth+/plugins64/ResizersPack-12.1~Dogway.avsi, line 787) (D:/Programmi/Media/AviSynth+/plugins64/ResizersPack-12.1~Dogway.avsi, line 793) (D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 962) (D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 972) (D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 973) (D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 973) (D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 1323) (M:\In\Mobile Suit Gundam - Il contrattacco di Char ~Dynit\contrattacco.avs, line 15) In the TransformsPackMain script: ### ConvertFormat() ### ### Dependencies: AviSynth+ 3.7.3 and over ### ExTools ### GradePack (for show=true or 'sigmoid' scaling) ### MasksPack (for show=true) ### ResizersPack (for show=true or UVRecon=true or NN scalers) ### KNLMeansCL (for UVRecon=true) ### nnedi3(CL) (for UVRecon=true) ### Optional resizer plugins (check links) From ResizersPack: # nnedi3resize() # # Wrapper for nnedi3wrap() for simplified ____resize() style arguments. # Performant neural network based upscaler recommended for graphics or textureless images. # It accepts arbitrary dimension values, not only limited to powers of 2 # # Dependencies: # see nnedi3wrap() below # nnedi3wrap() # # Replacement wrapper for nnedi3(), nnedi3_rpow2() and NNEDI3CL() based on 'field' and 'gpuid' values. # Adds "_rpow2" functionality and its arguments to NNEDI3CL(). # Maintains frame properties when nnedi3() or nnedi3_rpow2() is used. # Decouples 'rfactor' into 'xfactor' and 'yfactor' and sets new reasonable defaults. # Finally it automatically fixes center shift for both plugins, set cshift="none" to disable. # # Dependencies: # ExTools # NNEDI3CL (requires at least AVS+ v3.7.3) # or # nnedi3 It should work fine with NNEDI3CL and NNEDI3CL_rpow2 too, right? Any idea?
@turment on Telegram Last edited by tormento; 16th October 2024 at 14:40. |
#3008 | Link |
Big Bit Savings Now !
DeblockPack 2.8.avsi function oyster_Deringing was throwing error: I don't know what "UV" means.
Added missing line 468: Code:
UV = color ? 3 : 2 # Emulgator 2024 10 16: Missing line added
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 16th October 2024 at 15:22. |
#3010 | Link |
No, this was just a find to help all Dogway filter users, not connected to your script.
#3011 | Link |
Acid fr0g
I am fighting with a hard compromise between denoising and details loss.
Some animation studios, even when producing in digital, add some very fine digital noise to the final product. These two clips come from a very recent anime. The first one is about the details of the garnment of the girl, mostly the knitting close to the hairs and the hood. ![]() The second one is where you can clearly see the digital noise lurking in the dark. You can see in light scenes too but here is more evident. ![]() I have tried many many parameters to delete the noise, preserving the knitting, but it's really hard. Any help is welcome.
#3012 | Link | |
Should clean it up very nicely. 2x_AniScale2S_Compact_i8_60K should work, too. |
#3013 | Link | |
I would start with something like mcdegrainsharp and then try to filter flat areas differently using some masking. Last edited by Selur; 18th October 2024 at 13:54. |
#3014 | Link | |
Acid fr0g
I'd like to use a much more replicable and automated process.
#3015 | Link | |
Acid fr0g
And I doubt it could performe nicely on my 1660 Super too. What GPU do you have and how many fps can you achieve?
#3016 | Link | |
Mhh yeah it does.
I don't remember the exact FPS. But I think it was almost realtime, depending on the resolution, on my Radeon RX 6950 XT. Relative performance has my GPU 3 to 4 times faster. BUT if you can find the filter with cuda, that gap should be smaller. Last edited by takla; 19th October 2024 at 00:51. |
#3017 | Link | |
Acid fr0g
Very short script indeed.
#3018 | Link |
@tormento: Have you tried using simple fft3dfilter? (https://imgsli.com/MzA5NDk4)
#3019 | Link | |
Acid fr0g
#3020 | Link |
I just called FFT3DFilter with the default parameters. (you can tweak the setting for stronger denoising and add deband to add some noise in places that otherwise will might cause banding when encoding with 8bit)
ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LoadDll.dll") LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\FFT3DFilter.dll") LoadDLL("F:\Hybrid\64bit\Avisynth\avisynthPlugins\libfftw3f-3.dll") LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll") Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi") # loading source: C:\Users\Selur\Desktop\Girl_01_14828-14882.mkv # color sampling YV12@8, matrix: bt709, scantyp: progressive, luminance scale: limited LWLibavVideoSource("C:\Users\Selur\Desktop\Girl_01_14828-14882.mkv",cache=false,format="YUV420P8", prefer_hw=0,repeat=true) # current resolution: 1920x1080 FFT3DFilter(interlaced=false) # Converting from 8 to 10bit for encoder ConvertBits(10) # setting output fps to 23.976fps AssumeFPS(24000,1001) PreFetch(16) # output: color sampling YV12@10, matrix: bt709, scantyp: progressive, luminance scale: limited return last |
avisynth, dogway, filters, hbd, packs |
