#2041 | Link |
Well, just updated SMDegrain mod to 4.0.0 with fully interlaced and YUY2 direct support for all clip type arguments (input, CClip, mfilter and prefilter).
I'm wrapping up my packs so unless something is really borked these will be final. SMDegrain requires now latest versions of the main packs specially LSFplus and SharpenersPack if using sharpening specially with interlaced content. I also fixed the remaining issues in ex_retinex() hopefully for the good and a few more updates and cosmetics, most important of all the Documentation is finished, so you can have a glance on how things work now although it's pretty much what I've been posting around here. It's labeled RC (Release Candidate), if I didn't brake anything in a week or two I edit it out. It's been long so this is my last presentation card for the release. ![]() I also made a heavy refactor of GrainFactory3mod called FilmGrain, I wanted to leverage the option that AddGrainC has to scale up "grain", although it didn't end too well since the grain shows up as big squares instead of round grain, so it's a proof of concept and still need to play with the bias between AddGrainC scaling and blur strength (scaling so to speak). Will upload soon. Now, I will be installing Windows 10, having a bit of a rest and from time to time improving TransformsPack. Also I have almost finished my research on HVS (Human Visual System) and surround environment for viewing conditions. It's a two part study with some final suggestions on my part. It's not AviSynth related but more like HTPC, so probably will post at General Discussion.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 23rd February 2023 at 07:25. |
#2042 | Link | |
21 years and counting...
![]() ![]() Btw I see you re-sorted prefilters again. You'd better give a heads up when doing that or people may wonder why their scripts behave strangely different. ![]() Code:
ex_Median(mode="IQMV", UV=Chr) |
#2043 | Link | |
Posts: n/a
As for SMDegrain, the pre-filter order was changed back at build 3.5.8. Code:
3.5.8 pref = !GlobalR ? preclip ? UHDhalf ? pref : prefilter : \ (prefilter==-1) ? pref : \ (prefilter== 0) ? pref.ex_MinBlur(0,Chr) : \ (prefilter== 1) ? pref.ex_MinBlur(1,Chr) : \ (prefilter== 2) ? pref.ex_MinBlur(2,Chr) : \ (prefilter== 3) ? pref.ex_Median(mode="IQMV",UV=Chr) : \ (prefilter== 4) ? pref.ex_FluxSmoothST(2,1,255,0,false,UV=Chr) : \ (prefilter== 5) ? ex_merge(dfttest(pref,sstring="0.0:4.0 0.2:9.0 1.0:15.0",tbsize=1,U=chroma,V=chroma,dither=1,threads=1,sbsize=12,sosize=6,swin=2),pref, \ pref.ex_lut(Format("range_max range_max {Lthres} ymin - / x ymin - * -"),UV=1,clamp_float=true), luma=chroma, UV=Chr) : \ (prefilter== 6) ? pref.ex_KNLMeansCL(a=2,s=2,d=1,h=7.0,wmode=1,chroma=chroma,gpuid=gpuid,LFR=600*(nw/1920.)).ex_boxblur(0.5, mode="weighted", UV=Chr) : \ (prefilter== 7) ? pref.ex_DGDenoise(str=0.10,LFR=nw/2.,UV=Chr). ex_boxblur(0.5, mode="weighted", UV=Chr) : \ (prefilter== 8) ? pref.ex_BM3D(10,1,"normal",UV=Chr,gpuid=gpuid,tv_range=!fsp) : \ Assert(false, "SMDegrain: Prefilter must be between -1~8: "+string(prefilter)) : \ pref 3.5.7 pref = !GlobalR ? preclip ? UHDhalf ? pref : prefilter : \ (prefilter==-1) ? pref : \ (prefilter== 0) ? pref.ex_MinBlur(0,Chr) : \ (prefilter== 1) ? pref.ex_MinBlur(1,Chr) : \ (prefilter== 2) ? pref.ex_MinBlur(2,Chr) : \ (prefilter== 3) ? pref.ex_FluxSmoothST(2,2,255,0,false,UV=Chr) : \ (prefilter== 4) ? ex_merge(dfttest(pref,sstring="0.0:4.0 0.2:9.0 1.0:15.0",tbsize=1,U=chroma,V=chroma,dither=1,threads=1,sbsize=12,sosize=6,swin=2),pref, \ pref.ex_lut(Format("range_max range_max {Lthres} ymin - / x ymin - * -"),UV=1,clamp_float=true), luma=chroma, UV=Chr) : \ (prefilter== 5) ? pref.ex_KNLMeansCL(a=2,s=2,d=1,h=7.0,wmode=1,chroma=chroma,gpuid=gpuid,LFR=600*(nw/1920.)).ex_boxblur(0.5, mode="weighted", UV=Chr) : \ (prefilter== 6) ? pref.ex_DGDenoise(str=0.10,LFR=nw/2.,UV=Chr). ex_boxblur(0.5, mode="weighted", UV=Chr) : \ (prefilter== 7) ? pref.ex_BM3D(10,1,"normal",UV=Chr,gpuid=gpuid,tv_range=!fsp) : \ Assert(false, "SMDegrain: Prefilter must be between -1~7: "+string(prefilter)) : \ pref And in that time, it has changed a couple of times. Last edited by FTLOY; 24th February 2023 at 05:44. |
#2044 | Link | |
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 21st February 2023 at 05:00. |
#2045 | Link | |
#2046 | Link |
RIFE-denoise is still sort of RIFE-MC only. It still require complex enough blending engine and simplest Average() may create significant blurring and very bad blends where RIFE fail to do ideal motion compensation. For better denoise activity it is require to set new task to developers of its neural-network to create as best possible motion compensated frames with 'current' frame as target. Currently it only hack-like usage of inbetween frame interpolator as motion-conpensation to 'current' timestamp using +N and -N frames only (a pair of frames only). For best results it need to analyse large sets of frames around current frame including current frame (and it will be even much more slower and may take much more memory).
So it is required to go to RIFE core developers, present current state of RIFE-denoise system and its current issues and ask for may be new RIFE core mode for denoise action specifically. Finally you can try DX12-ME with post-2.7.45 mvtools builds and your GTX1070 card. Last edited by DTL; 21st February 2023 at 07:51. |
#2048 | Link |
@LeXXuz: Updated with absolute string preset names. Now you can do prefilter="DFTTest". IQMV is very similar to ex_MinBlur(3) but faster, and FluxSmoothST is a spatio-temporal version of MinBlur (only spatial).
I also added "RIFE" as 'mode' denoiser, but I didn't see much value in it, it doesn't denoise much, and warps content a little bit. EDIT: I'm not convinced enough, so if nobody opposes I remove it in the next revision. Maybe if I have time, I also want to run some AI scaling and delogo on personal projects. My card is not that much but nvidia releases have been a train-wreck lately so...
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 21st February 2023 at 19:11. |
#2049 | Link | |
Because of that I'm fiddling around with a custom prefilter an I was wondering what I have to set for tv_range (true or false) when calling ex.BM3D()? In SMDegrain it's set to tv_range=!fsp but I couldn't make out the syntax how the fsp variable is set. My Avisynth knowledge is too elementary. ![]() |
#2051 | Link |
I was playing a moment ago with 21 grams and found another good prefiltering with a single SMDegrain pass, haven't updated the docs as I'm keeping it for next (final?) revision and overall feedback.
pre=ex_bm3d(60,3,preset="noisy") SMDegrain(tr=2,mode="TemporalSoften",blksize=32,prefilter=pre,thSAD=600,refinemotion=true) ex_unsharp(0.2,Fc=width()/2) # Remove the dreamy/softness look Also added a new 'mode' called TemporalGauss, it's like TemporalSoften but with binomial weighting, so it keeps more details, the main difference with TemporalSoften is that you can use recursion on it with rTemporalGauss so further cleanup is possible. It all depends on the content. At first I wasn't getting any denoising and realized I broke it when fitting thSCD1, so for these two I added a new fit and also tweaked DCTR and scaleUV, the problem is only when RefineMotion=true. So now I can get back the results I was having with 21 grams sample, Carrie, etc. You don't need to set tv_range as my example above as it will be read from frameprops, but if you are unsure simply set tv_range=true if your source is in tv_range. fsp is a handler for 'Fulls', so if frameprops is not 'Fulls' (!fsp) it means it's tv_range=true.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#2052 | Link | ||
![]() ![]() Quote:
![]() Ah thanks. I didn't know it will be read from frameprops. So I can safely remove that from the call. |
#2053 | Link | |
I have tried to repair the ghosting/smearing problem with mocomped temporalsoften using repair(mode=13) with good results. Do you have any ideas regarding this method? |
#2054 | Link | |
I was checking visually and it didn't stop filtering grain until 60, but I was using a 21 grams sample which is the grainiest example I have ever seen. It had a sort of a Kuwahara median look, but it worked fine as prefiltering.
Try with: Code:
SMDegrain(3,mode="rTemporalGauss",thSAD=700 or more, refinemotion=true)
#2055 | Link |
I get a script error with 4.0.0d RC3.
It states ConverttoYUV444 does not have a named argument 'param1' in line 1171 ![]() I think I've updated every package with switching to 4.0.0d from 3.6.0d. Any idea what I may have missed? ![]() |
#2056 | Link |
Try to download latest pinterf AVS+ version, test6.
I just uploaded RC4 of SMDegrain, mainly cosmetics but you can check the docs as I added the above ex_bm3d() example. I think this might be a good candidate for final.
#2057 | Link | |
#2060 | Link |
Thanks, yes an oversight, updating in a few moments.
By the way I'm experiencing some memory leaks using QTGMC+, I'm debugging but not sure if it was a commit on my side or simply a recent AVS+ issue.
avisynth, dogway, filters, hbd, packs |
