#21 | Link |
My understanding is that this "Intelligent Auto Correction" legalization is only useful if you want to keep the out of gamut details visible. Of course, this requires you to change in-gamut values as well or you are simply clipping.
It is the difference between perceptual gamut mapping and absolute gamut mapping. IMO small differences in gamut should use absolute (clipped) while large differences in gamut need a perceptual method or you get banding. There are really a lot of possible perceptual methods developed for the graphic design field that are applicable to video, I do not know why Vidcheck thinks they are special. It did have more sense for analog but when using perceptual methods it isn't clipped even in the digital world. I suppose legalization could also be important if dealing with a bad/non-standard YCbCr to RGB converter that was willing to output RGB values below 0 or above 255. |
#22 | Link |
Well, yes. I assume it's for more advaced than simple clipping conversion, so actual look of the frame changes as little as possible.
Do they think they are special? Hmmm...maybe because their algorythm tries to preserve 'the look' as you mentioned. For example if you have some pure black frames (16) and auto correction happens than this may be raised to eg 20. They say this is desired, some place reject such a files, where 'pure' black is not at 16
#23 | Link | |
interesting post. I understand only partially the code what you wrote but would like to do something similar. My target is to analyse 4k HDR REC2020 clips to see what pixel lies outside REC709. For this, If I understood correctly, I need to: 1) Convert YUV to RGB 2) Convert non linear RGB to linear RGB 3) Convert REC2020 RGB to REC709 RGB I have created the matrix for the step 3, and everything which is outside REC709 should then get illegal RGB triplet. And I would like to give those illegal RGB triplet a certain value, like (0,0,0) to paint them black. Could you help me? My current code: Code:
loadplugin("C:\Users\flole\Downloads\ManualColorMatrix\ManualColorMatrix_26.dll")
loadplugin("C:\Users\flole\Videos\AviSynth\HDRTools\x86\Release_W7\HDRTools.dll")
Directshowsource("F:\Kodi\Demo 4k HDR\The World In HDR 4K Demo.mkv")
ConvertYUVtoLinearRGB(Color=1)
#isRGB()
ManualColorMatrix(1, 1.66049, -0.58764, -0.07285, -0.12455, 1.13290, -0.00835, -0.01815, -0.10058, 1.11873)
![]() Florian |
| Display Modes | |
